[Solved] Philips EP5310 Espresso Machine - Service Key Error Code 2: Solve & Share Experiences
m.dudzinski 29658 4
  • #1 18714777
    m.dudzinski
    Rate: 48
    I have a Philips EP5310 espresso machine and unfortunately I cannot find information about error 2 anywhere. Has any of you had experience with this error? Philips EP5310 Espresso Machine - Service Key Error Code 2: Solve & Share Experiences
    robsons10
    Help: 73
    Rate: 401
    Hello. Grinder problem.
  • #3 18717883
    m.dudzinski
    Rate: 48
    Thank you, yes you are right it is a problem with the grinder. I have a symptom now that when I gently move the engine and turn it on, the coffee machine works all the time, i.e. they had coffee when I turn it off with the power button and turn it on again, the grinder function no longer works and the same error appears. Is the fault of the engine itself?
    robsons10
    Help: 73
    Rate: 401
    Described a little chaotically ..., but from what I deduced there may be a problem with the power supply circuit of the grinder, and rather in the control circuit of the actuator system. There may be an interesting flaw in electronics - rather manageable but knowledge needed?. I propose to substitute a working engine and then it will turn out. If there is still a problem, I invite you to priva.
  • #5 18718120
    m.dudzinski
    Rate: 48
    Thank you in advance for your willingness to help, but I solved the problem. I cleaned the commutator and replaced the brushes, the grinder now works every time.
