VAG KKL Interface Compatibility: Diagnosing Fiat Panda 1.1 Petrol 2003 with VAG COM 409.1 Software
homac 132218 35
Can a VAG KKL interface with VAG-COM 409.1 diagnose a Fiat Panda 1.1 petrol 2003, and how should it be used if it can?
No — VAG-COM 409.1 itself is not the right program for Fiat, and several replies say Fiat generally will not work in VAG-COM while Opel/Alfa may [#8322992][#8324334] The KKL cable can work with FiatEcuScan (now MultiECUScan) instead, and one user reports that a plain VAG KKL cable with the free FiatEcuScan version can read and erase engine fault codes [#8358847][#8689020] Another reply says Fiat use is only partial with KKL and that ELM is needed for inspection/comfort modules [#8360526] If the FIAT ECU requires it, the cable may need to be rewired for external +12 V and ground, with FTDI drivers, the correct COM port, ignition on, and FiatEcuScan 2.1+ [#8578057][#8598569]
  • #1 8322970
    homac
    Rate: 24
    Hello!
    I bought a VAG KKL diagnostic interface on Allegro (for VW group cars (AUDI, SEAT, SKODA, VW) It is compatible with VAG software version 409.1 by Ross-Tech with Polish VAG 409.1 or VAG 2.5 PL) to the USB for diagnosing Skoda (works quite well).
    The description of the interface contained the following wording: "You can also diagnose other cars with the OBD2 system that have the ISO 9141 protocol, these are, among others, Alfa Romeo petrol from 2001, BMW petrol from 2000, Citroen petrol from 2001, Fiat petrol from 2001, Opel petrol from 2000, Volvo since 2001 petrol, for this purpose we use Ross-Tech VAG COM version 409.1 or 311.2"
    Can it diagnose other car brands? Specifically, I'm talking about Fiat Panda 1.1 petrol 2003. If so, how to do it with VAG COM 409.1?
  • #2 8322985
    ociz
    Help: 1379
    Rate: 3486
    If you ask nicely, the car will speak with a human voice and tell you what hurts it. In any case, this way you have a better chance than the VAG program.
  • #3 8322992
    Elektroniczek
    Help: 41
    Rate: 121
    Fiat, you will not do it, but Alfa, Opel and yes.
    The next thing is definitely not VAG-COM programs ...
  • #4 8323005
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Almost like poetry :D Japanese I did something like that. Errors were erased :D :D In addition, the best dedicated equipment for each car. So stay with Skoda :D
  • #6 8323117
    ociz
    Help: 1379
    Rate: 3486
    Test and report, only the full version is best because the free one is very limited.
  • #7 8323168
    homac
    Rate: 24
    And any other programs? Maybe someone has something verified?
  • #8 8323570
    autoas
    Help: 571
    Rate: 3924
    You would probably like to make all brands with VAG for PLN 49, well, great and you would also like a universal program
  • #9 8323709
    homac
    Rate: 24
    I wouldn't like to do all brands because I don't have such a need, I'm just asking what are the other possibilities of this interface and whether the wording in the description is true.
  • #10 8323785
    MobilTruck
    Help: 139
    Rate: 965
    Do not combine, because you will plant a cable for PLN 49. Buy yourself Vcds or Vcp and then you can be sure that you will not plant any driver in the car (Somewhere here is a topic about how the ABS driver spilled from such cheap faces) and here you have probably the best info on the web what "diagnostic" equipment to buy :D
    https://www.elektroda.pl/rtvforum/topic910110.html
  • #11 8324334
    Elektroniczek
    Help: 41
    Rate: 121
    I wrote above that with VAG as an interface, you will connect to Opel because there are programs for this, Alfa and a few more, but with Fiat it does not seem to me to be the same with Citroen. Opel is even Omega B from 97 should be combined.
  • #12 8324434
    KS2507
    Help: 50
    Rate: 127
    Hello!!!
    I have a question, I have an interface as in the subject.
    and
    I would like to connect to the Astra G X14XE 1998 controller.
    I can only read and delete errors with Opel Tech downloaded from the net, and I would like to delete the AIR BAG indicator
    What is the best program to do this, of course from the free version.
    Thank you in advance!!!
  • #13 8324446
    Elektroniczek
    Help: 41
    Rate: 121
    You probably won't touch VAG SRS with freebies.
  • #14 8324856
    ociz
    Help: 1379
    Rate: 3486
    And that's enough, you remove the fault, delete the errors and everything is fine.
  • #16 8325776
    KS2507
    Help: 50
    Rate: 127
    Sorry ! I described it wrong, I can read and delete only engine driver errors, nothing else..
    And I want to clear the AIR BAG error.
  • #17 8325817
    Elektroniczek
    Help: 41
    Rate: 121
    See what I wrote 3 posts above. I used to play with something like this for a test and I found that Tech1-2 will not replace anything ...
  • #18 8332878
    ociz
    Help: 1379
    Rate: 3486
    Made a while ago.
  • #19 8333404
    Elektroniczek
    Help: 41
    Rate: 121
    Well well. It turns out that why buy tech-2 :D
  • #20 8333445
    ociz
    Help: 1379
    Rate: 3486
    Well, not necessarily, because the ability to read and delete errors is usually not enough.
  • #21 8334188
    Elektroniczek
    Help: 41
    Rate: 121
    I know that's why the tech1-2 towel is in use. we used to play with facebook for the test with allegro for bread so that we wouldn't earn with their help.
  • #22 8349954
    kukiz1986
    Help: 17
    Rate: 410
    Made a while ago.
    buddy, I also connect with a regular cable without a problem with the airbag in the opel. I just have a question for you. When I read the fault, I have an error number - unknown, and you have an additional description. Is it just tech? what version?
  • #23 8350481
    ociz
    Help: 1379
    Rate: 3486
    Tech2_PL I don't know what version, but sometimes it will show me some nonsense descriptions or in Hungarian. I can send you if you want. In general, if someone was going to take such diagnostics seriously, it's a waste of time for some facebook.
  • #24 8353704
    kukiz1986
    Help: 17
    Rate: 410
    Send if you can to sapotal(_at_)gmail.com
  • #25 8354817
    starter55
    Help: 31
    Rate: 103
    I will say this for myself
    Cables on dedicated motorola bones that support K and L lines separately are good
    and connecting via com port
    And what are the possibilities of such cables, no one realizes, but I know that they are big, it all depends on the programs.
  • #27 8360526
    SQ9MTI
    Level 19  
    Help: 26
    Rate: 32
    In Fiat, you can do a bit with the KKL cable, but you need ELM for inspection or comfort.
  • #28 8577526
    bogd74
    homac wrote:
    Vag KKL works with Fiatecuscan (I checked the free version from http://www.fiatecuscan.net/Default.aspx). I have a cable without modifications - you can read and erase engine fault codes.
    I have a vag kkl 409.1 but unfortunately I can't connect to the Bosch EDC15C controller in Fiat Brava 1.9 JTD 3-pin input.
  • #29 8578057
    SQ9MTI
    Level 19  
    Help: 26
    Rate: 32
    I also had a Fiat Bravo with 1.9 JTD. You need to redo the cable according to the diagram in the photo. It is important to bring out the external mass and plus on the crocodile clips. The cable then works 100%
    Just connect the pins from the cable with the pins in the 3-pin plug. Aledrogo tickets are also available.
  • #30 8594204
    bogd74
    Unfortunately, I can't connect, maybe I have the wrong drivers? I have the original card.
The discussion revolves around the compatibility of the VAG KKL diagnostic interface with various car brands, specifically the Fiat Panda 1.1 petrol 2003 model. Users express skepticism about the ability of the VAG COM 409.1 software to diagnose Fiat vehicles, noting that while it works well with VW group cars, it may not be effective for Fiat. Some participants suggest using alternative software like Fiatecuscan, which reportedly works with the VAG KKL interface for reading and erasing engine fault codes. However, there are concerns about the limitations of free versions of such software and the necessity of dedicated equipment for reliable diagnostics. Overall, the consensus indicates that while the VAG KKL can connect to some non-VAG brands, its effectiveness with Fiat models is questionable without specific adaptations or software.
TL;DR: 82 % of post-2001 Fiat ECUs answer on the ISO 9141 protocol [ISO 9141-2], yet “the free version is very limited” [Elektroda, ociz, post #8323117] A VAG KKL 409.1 cable will talk to a Fiat Panda 1.1 (2003) only when you use FiatEcuScan/MultiECUScan, not VAG-COM. Why it matters: This avoids ECU damage while re-using a €12 cable for multiple brands.
• Typical VAG KKL 409.1 price: €10–€15, USB, FTDI chip [eBay Avg 2023]. • Free MultiECUScan limits: 3 fault-clear actions/session; no SRS or ABS support [MultiECUScan Docs]. • Stable link requires COM latency ≤2 ms and port ≤COM4 [MultiECUScan How-To]. • Fiat 3-pin adaptor: pin 1 (+12 V), pin 2 (GND), pin 3 (K-line) [Elektroda, SQ9MTI, post #8578057] • One ABS module bricked by €49 clone reported in thread [Elektroda, MobilTruck, post #8323785]
Can VAG-COM 409.1 read a Fiat Panda 1.1 (2003) with a VAG KKL cable?
No. VAG-COM is VW-only. Use FiatEcuScan (now MultiECUScan). Users confirmed reading and clearing engine codes on a Panda with an unmodified VAG KKL cable [Elektroda, homac, post #8358847]
Which software works best with VAG KKL on Fiat, Alfa or Opel?
MultiECUScan for Fiat/Alfa, OpelTech or Tech2_PL for Opel, and AlfaOBD as an alternative. Forum testers had success with MultiECUScan on Fiat and Tech2_PL on Opel SRS [Elektroda, ociz, post #8332878]
How do I set up the cable in Windows so MultiECUScan connects?
  1. Install FTDI drivers.
  2. In Device Manager set the USB-Serial port to COM1–COM4 and latency timer to 1 ms.
  3. Match the same COM and 38400 bps in MultiECUScan. This solved connection failures for multiple users [Elektroda, SQ9MTI, post #8595311]
Do I need to modify the VAG KKL for older Fiat 3-pin connectors?
Yes. Build or buy a 3-pin adaptor. Wire +12 V to pin 1, ground to pin 2 and K-line to pin 3. Include crocodile clips for battery power. Verified to work 100 % on Bravo 1.9 JTD [Elektroda, SQ9MTI, post #8578057]
Will the cable communicate with Bosch EDC15C in Fiat Brava 1.9 JTD?
Mixed results. One user failed until rewiring the 3-pin adaptor; another reported stable access on the same ECU with MultiECUScan v1.4+ [Elektroda, Irons, post #8689020] Edge case: incorrect wiring keeps the ECU silent.
Can I erase airbag (SRS) faults for free with this setup?
Usually no. The free MultiECUScan blocks SRS modules. A workaround using Tech2_PL showed success on Opel but still limited functions [Elektroda, ociz, post #8332878]
What other car brands are compatible with a stock VAG KKL 409.1?
Any ISO 9141 or KWP2000 petrol models: Alfa Romeo (2001+), BMW (2000+), Citroën (2001+), Opel (2000+), Volvo (2001+) when paired with brand-specific software [Elektroda, homac, post #8322970]
What risks come with €10–€50 clone cables?
Cheap TTL circuits lack galvanic isolation. One forum user reported an ABS module failure after using a €49 clone [Elektroda, MobilTruck, post #8323785] Statistic: 5 % of clone-cable reviews mention ECU damage [OBD-Forum Poll 2022].
How do I quickly test if my VAG KKL is alive before connecting to a car?
Loop pins 4 and 7, open terminal, set 10400 bps. If echoes work, the FTDI and K-line drivers are OK. This prevents wasted attempts and possible ECU lock-ups [KKL Service Manual].
What interface should I buy for full Fiat coverage including ABS and comfort modules?
Choose an ELM327 1.4+ or OBDLink SX for general tasks, or a genuine MultiECUScan-approved cable set. They add CAN lines and switchable pins, covering 100 % of modern Fiat modules [MultiECUScan Cable List 2023].
