Lenze 9400 HighLine Inverter: Resolving DC-Bus Undervoltage DRIVE ERROR at 563V
myacine 16551 2
  • #1 18753308
    myacine
    Hi all.
    I have a problem 9400 highline inverter Lenze ,
    The "DC-bus undervoltage" error with the response "Trouble" occurred in the "Diagnostic" of "Engineer"
    how i can resolve this problem knowing that the real dc-bus voltage is 563 volt
    • the mains voltage is OK
    • the setting in C00173 is 285 volt
    I am looking to service or repair manual of 9400 highline if possible
    Could you please help me fix this error
    Many thanks
    https://obrazki.elektroda.pl/2805455200_1591888820.jpg
  • #2 18781542
    krzysiul
    Help: 36
    Rate: 31
    Try to measure DC voltage on UG+ and UG- terminals. When supplied (400V on L1-L2-L3) there should be ~565V DC.
    Then, in diagnostic (kepad or PC program "Engineer"/"Easy Starter") check the value of DC Bus shown (code C0053) - if there is 0V then you have probably a rectifier (or voltage measurment system) broken. In this case the inverter should be sent for a repair.
    If the value in C0053 is OK then check the setting in C0174 for monitoring the undervoltage (but if it was working earlier and there is mains, I would suspect an inverter damage)
    Best regards
  • #3 19222603
    qcw99a
    It's a hardware fault, you must repair the DriveBoard
