[Solved] Rexroth IndraDrive HMS-01.1N-W0020 Servo Amplifier: Resolving Error F8069 Display Issue
Maciej B. 15642 7
  • #1 7024563
    Maciej B.
    Rate: 38
    I have a problem with the Rexroth IndraDrive HMS-01.1N-W0020 servo amplifier, the error F8069 has appeared on the display.
  • #2 7028705
    noplis
    Help: 36
    Rate: 49
    Masz pecha:
    F8069 +/-15Volt DC error
    An error has occurred in the internal ±15 V supply of the supply unit.
    Cause: Supply unit defective
    Remedy: Replace supply unit
  • #3 7030249
    Maciej B.
    Rate: 38
    Thanks for the hint, or maybe someone has documentation for this?
  • #4 7032645
    noplis
    Help: 36
    Rate: 49
    If the device is younger than 1.5 years, please report the complaint to Rexroth.
  • #5 7057170
    Maciej B.
    Rate: 38
    Unfortunately, she is about 2 years old.
  • #6 7057491
    noplis
    Help: 36
    Rate: 49
    I'm afraid you will not remove this error alone :cry:
  • #7 7070993
    Maciej B.
    Rate: 38
    Ok, but I will try, the machine is already working in a new one.
  • #8 17714580
    Maciej B.
    Rate: 38
    IndraDrive has been replaced by another one.
The Rexroth IndraDrive HMS-01.1N-W0020 servo amplifier is displaying error F8069, indicating a fault in the internal ±15 V supply of the unit. The likely cause is a defective supply unit, which may require replacement. If the device is under 1.5 years old, users are advised to report the issue to Rexroth; however, the user indicated that their unit is approximately 2 years old. There is a consensus that resolving this error may not be feasible without professional assistance, and the user has mentioned that they have replaced the IndraDrive with a new unit.
