1978 Władimirec T25 Tractor - Stuck Gearbox Solutions: Gear Rods, Slides, Wheels & More
Rolnikmiasta 10995 6
  • #1 18763699
    Rolnikmiasta
    Hello everyone, I am a young farmer who bought a T25 tractor from 1978 with two couples. I need help because the gearbox is stuck. Of the four rollers, the first two are reared and no force moves them. Unscrewed slides, gear rods extended. I don't know what to do next, all that's left is to unscrew the top sheet under the wires. Please help. I will add that after blocking I pulled him with a second tractor, wheels one to the right and the other to the left. I greet arthur
    ftp.kowal
    Level 36  
    Help: 329
    Rate: 1841
    The lock rod has broken. On the right hand side of the gearbox you have a lever which pulls the rod out of the gearbox when you press the clutch. It often happened that the rod broke in the middle and only some gears could be shifted. Have someone push the clutch in for you and watch what starts to go. That way you will find out what is going on.
  • #3 18764008
    Rolnikmiasta
    Thank you very much for the hint. To get to this fight lock rod do you have to remove the upper box housing? I'm just learning to operate the T 25 and it's throwing me into deep waters.
    Regards Artur
  • #4 18764103
    ftp.kowal
    Level 36  
    Help: 329
    Rate: 1841
    Type "T25 gear lock" into Google and drawings and several topics will pop up. You're sure to find something.
  • #5 18765987
    Rolnikmiasta
    Hi there, partly successful, now a problem with the gearbox, the gearbox is unlocked, but the stick from the reverse gear cannot be changed from reverse to front as if something is blocking it. Is it the rods blocking it or something else. Regards Artur
  • #6 18776836
    piotr-kaczmarek
    You twisted something but maybe try to adjust the gear block
  • #7 18777106
    Rolnikmiasta
    Hello. Thank you for all the hints, I check everything by defending myself against unscrewing the top cover of the gearbox.
✨ A young farmer seeks assistance with a stuck gearbox on a 1978 Władimirec T25 tractor. The issue involves four rollers, with the first two being unresponsive despite attempts to adjust the gear block and unscrew the slides and gear rods. The farmer is considering removing the top cover of the gearbox for further inspection. Previous attempts to free the gearbox included pulling the tractor with another vehicle, but the problem persists.
