[Solved] Who Connects WLZ to Power Box: Investor or Tauron? Scope of Responsibility Discussion
Matikqw 19689 16
Who is responsible for connecting the WLZ cable to the power box: the investor or Tauron?
The WLZ is normally connected by the investor’s side, usually by an authorized electrician hired by the investor; Tauron/supplier typically only installs and seals the meter [#18820910][#18820971] In the thread, it is also stated that the supplier’s meter installer will not even touch the WLZ connection in some areas and will not energize the object [#18820983] If the implementation documents say to make the WLZ from the measuring connector to the TG “on the side of the connected entity,” that means it is your responsibility [#18821084][#18821091] In practice, the supplier may only open the connector temporarily if there is no access/keys, but the actual connection still belongs to the investor’s electrician [#18820971][#18821084]
  • #1 18820901
    Matikqw
    Rate: 15
    Who usually plugs the WLZ into the power box? Is it within the scope of the investor or Tauron?
  • #2 18820910
    kkas12
    Help: 1076
    Rate: 4312
    Of course, the investor.
    The supplier installs the meter.
  • #3 18820946
    Matikqw
    Rate: 15
    I had a situation where an electrician came to plug in, but he did not have a universal key. I note that the lock in the box is like a house, not any square or other figure. I called the ZK fitter and he said the keys are in the box. There was no way to get to it so there is no wlz connected. Tomorrow the box fitter (tauron's guy) will be passing by me, so he will open the box and give the keys. Should give during assembly? Who Connects WLZ to Power Box: Investor or Tauron? Scope of Responsibility Discussion
    Pay attention to point 1.5
  • #4 18820957
    kkas12
    Help: 1076
    Rate: 4312
    Leave one key in the connector and take the rest. Are yours.
    And installing the meter and putting seals on it and on the protections is connection to the network.
  • #5 18820963
    Matikqw
    Rate: 15
    First you have to get to the box. I know that the energy industry assumes a meter. But who plugs the WLZ cable into the connector in the power box?
  • #6 18820971
    jann111
    Help: 180
    Rate: 507
    Matikqw wrote:
    who usually
    Usually an authorized electrician hired by the investor.
    This is the practice but not the rule.
    This can also be done by a person from the energy supplier.
    It's a matter of "getting along".
    In the notification of the installation's readiness for connection, the supplier asks the investor about this issue.
  • #7 18820979
    Matikqw
    Rate: 15
    Do they do it for free or do you have to pay them? What to do when I have a trench done, cables stretched, an invoice unpaid because it didn't come and it was supposed to be 2 months ago, the technical card is the same, and the electrician won't get in because he doesn't have a key.
  • #8 18820983
    kkas12
    Help: 1076
    Rate: 4312
    No guy who assembles wlz counters will even touch it.
    At least that's what Tauron does in my area.
    It won't even give voltage to the object.
  • #9 18821003
    Matikqw
    Rate: 15
    I sent an attachment earlier and it says in point 1.5 that tauron undertakes to plug the wlz into the box.
  • #10 18821007
    mawerix123
    Help: 482
    Rate: 951
    Electrician for you.
    You don't get the keys from the person installing the meter, it's probably about the possibility of electricity theft or electrocution of unauthorized persons.
    Matikqw wrote:
    unpaid invoice
    So no one bothers to set up a counter.
  • #11 18821015
    Matikqw
    Rate: 15
    You don't get the keys from the person who assembles the meter, it's probably about the possibility of electricity theft or electrocution of unauthorized persons.
    Matikqw wrote:
    unpaid invoice
    Electrician plugs in but no keys. I don't care about it.
    In general terms, it says that Tauron undertakes to plug in and you say that the electrician from the investor.
    You pay as soon as you plug into ZK and want to sign a transmission contract.
  • #12 18821019
    kkas12
    Help: 1076
    Rate: 4312
    It's just your interpretation, my friend.
  • #13 18821033
    mawerix123
    Help: 482
    Rate: 951
    There are no keys because there are no PPN permissions :)
  • #14 18821074
    Matikqw
    Rate: 15
    quote="kkas12"]
    It's just your misinterpretation mate.[/quote]
    If you have time, expand it.
    Where is the clear record that connecting WLZ to zk is on my side?
    In the implementation schedule, it is supposed to say that on the side of the connected entity, perform the LLZ from the measuring connector to the TG. Does that mean I have to do it?
    I don't want to misinterpret.
    Also "on the side of the connected entity" can mean "on my plot"
    I'm doing an investigation because the electrician showed me this point and says that tauron will connect the wlz.
    I am asking for more info what to do because it is dug up, ready to connect and there is no way.
  • #15 18821084
    kkas12
    Help: 1076
    Rate: 4312
    What should I develop for you as you think you know better.
    And don't investigate, find the ER guys and ask them to open the connector for you for a while.
    Then you will take what is yours and you will get to the meter.
    Matikqw wrote:
    ... it is written that on the side of the connected entity, make a wlz from the measuring connector to the TG. Does that mean I have to do it?
    That's exactly what it means.
  • #16 18821091
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    Buddy Matikqw, you are to perform everything that is included in point 2.2 - that is, from the property border to the installation towards the recipient.
  • #17 18821105
    Matikqw
    Rate: 15
    Approx. Thank you very much. you helped :D
The discussion revolves around the responsibility of connecting the WLZ (main power cable) to the power box, specifically whether this task falls to the investor or the energy supplier, Tauron. Responses indicate that typically, an authorized electrician hired by the investor performs the connection, although it can also be done by a representative from Tauron. The conversation highlights issues such as access to the power box, the need for specific keys, and the complications arising from delays in installation and the lack of necessary permissions. Participants emphasize the importance of clear communication regarding responsibilities and the need for proper access to complete the connection.
TL;DR: One readiness notification decides who connects WLZ; "Usually an authorized electrician hired by the investor." The supplier can connect if agreed. [Elektroda, jann111, post #18820971]
Why it matters: For investors/homeowners wiring a ZK with Tauron, this clarifies who does what, avoids access issues, and prevents delays.
Who actually connects the WLZ to the ZKme or Tauron?
Typically, an authorized electrician hired by the investor connects the WLZ. The supplier can also do it by arrangement. The readiness notification asks who will perform this work. Choose and confirm it there. "Usually an authorized electrician hired by the investor." [Elektroda, jann111, post #18820971]
What does Tauron actually do at the connection point?
Tauron’s technician installs the meter and places seals on the meter and protections. This work is treated as the connection to the network. They do not manage your internal WLZ. [Elektroda, kkas12, post #18820957]
Will Tauron connect my WLZ or energize the building?
No. The meter installer will not touch your WLZ and will not energize the object. This division prevents unauthorized work on your installation. Arrange WLZ by your electrician first. [Elektroda, kkas12, post #18820983]
How should I interpret on the connected entity side, perform WLZ from the measuring connector to the TG?
It means you, as the connected entity, must build the WLZ from the meter connector to the main switchboard (TG). Your electrician performs this scope before the meter installation. [Elektroda, kkas12, post #18821084]
What is my responsibility from the property border?
You are responsible for everything from the border point to your recipient installation. Plan and execute that work so the connection can proceed without delays. [Elektroda, elpapiotr, post #18821091]
How do I get WLZ connected and the meter installedstep by step?
  1. Hire an authorized electrician to build the WLZ and prepare the site.
  2. Submit the readiness notification and indicate who will connect the WLZ.
  3. The supplier schedules meter installation and sealing per your indication. Note: the notification captures who does the WLZ. [Elektroda, jann111, post #18820971]
My electrician cant open the ZK (no key). What should I do?
Contact the energy response crew and ask them to open the connector temporarily. Retrieve your keys and ensure future access for your electrician. Then the meter area remains sealed separately. [Elektroda, kkas12, post #18821084]
Will the meter installer give me keys or a universal key?
No. You do not get keys from the person installing the meter. Restricting access reduces theft risk and protects unauthorized persons from electric shock. Arrange access yourself ahead of time. [Elektroda, mawerix123, post #18821007]
Who owns the connector keys, and how many stay inside?
They are yours. "Leave one key in the connector and take the rest." Keep spares securely for authorized electricians. This supports access without compromising sealing. [Elektroda, kkas12, post #18820957]
Can Tauron connect the WLZ for me, and will I be charged?
It can happen by arrangement. The readiness notification asks who will connect the WLZ. Confirm scope and any fees directly with the supplier before scheduling. [Elektroda, jann111, post #18820971]
What if my invoice isnt paidwill they install the meter?
No. Without settling the invoice, the supplier will not install the meter. Pay outstanding amounts before requesting the meter appointment. This prevents scheduling dead-ends. [Elektroda, mawerix123, post #18821007]
Are paperwork delays possible (technical card or invoice)?
Yes, delays can stall work. One user reported a two-month delay while trenches and cables were ready. Such delays can affect connection timing. [Elektroda, Matikqw, post #18820979]
Is connecting the WLZ part of the DSO connection to the network?
No. The DSO treats meter installation and sealing as the network connection. Your WLZ remains your responsibility outside that scope. [Elektroda, kkas12, post #18820957]
My paperwork point 1.5 seems to say Tauron connects WLZam I misreading it?
Yes. That interpretation is incorrect. It means you perform the WLZ from the measuring connector to your main switchboard. "That’s exactly what it means." Confirm scope on the readiness form. [Elektroda, kkas12, post #18821084]
