WLZ in Post-German Buildings: Does It End at the Meter or Apartment Switchboard?
adri9225 45957 7
  • #1 9159802
    adri9225
    I live in an old post-German building, in which the main security of the building, pre-meter protection and meters are located in the staircase. The apartments are located on a long balcony, not in the staircase as in most apartments. And now where does WLZ end - is it on the meter or is WLZ drawn to each of the tenants' flats to the switchboard? I have books with 2 definitions?
  • #2 9163256
    migurak
    Rate: 12
    Internal power line (building object) WLZ
    an electrical circuit which supplies power to the instrument panel. These lines can supply power to the main switchboards, floor boards, apartment boards, etc. In multi-family buildings, the installation between the connector and measuring systems in apartments can be used as WLZ.
    This is a case-by-case definition and cannot be used to describe all CRLs.
  • #4 9167608
    MateuszJ1982
    As a colleague WLZ wrote above in multi-family flats, it is an installation from the Cable Connector (supplying power) to a given building to the main switchboard of this building.
  • #5 9168107
    Miniax
    Electrician specialist
    Help: 173
    Rate: 290
    So how are we going to name the sections of the installation between the main switchgear of the building and the residential switchboards?
  • #6 9168273
    adri9225
    this episode is probably treated as a receiving installation ... ??
  • #7 9168387
    Miniax
    Help: 173
    Rate: 290
    In the study published by my colleague Krzysztof, the definition is different. I recommend you to read.
  • #8 9171475
The discussion revolves around the definition and scope of WLZ (Wewnętrzna Linia Zasilająca), which refers to the internal power line supplying electricity to various switchboards in a building. Participants clarify that in multi-family buildings, WLZ typically extends from the cable connector to the main switchboard, and may also include the installation between the main switchgear and residential switchboards. There is some debate regarding the terminology used for sections of the installation, with suggestions that these may be classified as receiving installations. The conversation emphasizes the need for precise definitions in electrical contexts.
