Connecting WLZ in ZE Statement: LVZ Connection, HV Voltage, Wire/Cable, Meter Protection
MrMazi 43762 4
  • #1 8053972
    MrMazi
    Help: 6
    Rate: 69
    Please help. I made such a connection
    https://obrazki.elektroda.pl/39_1273333737.jpg
    In the statement for ZE, the question is whether the LVZ needs to be connected?
    Do they mean the physical connection of the wire / cable (which is already done in the box)?
    Do they mean connecting the voltage to HV? (through the meter and protection against it)
  • #2 8055073
    zdzisiek1979
    Help: 561
    Rate: 1254
    Well, it started with a strip with a division of NPE, then a connector diagram + measurement and now the ready box is waiting for connection :D
    Kurka I won't tell you how to understand it because he doesn't deal with paperwork.
    Generally, this is how the WLZ comes out of the box and flies to the switchboard.
    Maybe the question is whether it is made, inserted into the box and connected.
    Because when a cheerful team from ZE arrives, it only connects to the network, mounts the meter, plugs the fuses when the meter starts (the electronic one will show numbers, symbols that I can never see), they seal, you sign the receipts, put a padlock and disappear. Sometimes they are in such a hurry that they get confused, so pay attention to what they leave you, if everything is correct.
    Added after 4 [minutes]:
    Alternatively, when you apply for a connection, you can find out what this question is about on the spot and then check the appropriate box according to your situation. :D
    And one more thing at the end of the WLZ is the switching station and the receiving installation.
  • #3 8056740
    Krzyś33
    Help: 58
    Rate: 104
    Hello. Just for the sake of formalities. From the switching station, the line (whether it is overhead or cable) goes to the connector (box ????), and from the WLZ connector it goes to the switchboard. Best regards.
  • #4 8057291
    Miwhoo
    Electric installations specialist
    Help: 128
    Rate: 316
    According to my presumptions, it is about connecting the WLZ in the ZK to the terminals of the advance / FR protection depending on what is installed. If the WLZ is only introduced to the ZK or ZK without a meter and protection, then the physical connection is not possible, then you leave the WLZ inserted into the ZK, and in the statement you write that it is not connected.
  • #5 8061191
    zdzis50
    Rate: 9
    The drawing shows that everything is connected and fastened with the last button, write NO to the EV!
