ConnectBox, UPC, Public IP, Bridge, NAS, truncated options and complications
Vester11 44010 43
How do I enable external access to my NAS on UPC ConnectBox when the bridge/port-forwarding options are missing?
Switch UPC from IPv6 to IPv4 through the UPC help assistant or support, then reboot/reset the ConnectBox; that is what restored the missing forwarding/bridge options and made external access work [#18842863][#18845253] The public IP is still dynamic unless you buy a static one, so it can change after a modem restart [#18842949] For the NAS/AP, keep fixed LAN addresses (for example 192.168.0.10 for the QNAP and 192.168.0.38 for the Asus) and use the ConnectBox as the router for port forwarding [#18843540][#18843615] A safer remote-access setup is to run the VPN server on the NAS itself; the working QNAP setup used L2TP/IPsec and port forwarding for UDP 500, 4500, and 1701 to the NAS, with the client entering the public WAN IP, not the local LAN IP [#18844116][#18844180][#18846165][#18846176][#18846187] The ESP 50 rule was not available on the ConnectBox, but the VPN still worked without it [#18846209] Test the VPN from LTE or another external network, because it will not behave the same from inside your home Wi‑Fi [#18846224]
  • #31 18846093
    Bródka
    Help: 900
    Rate: 723
    Vester11 wrote:
    Rule set.
    Local IP: 192.168.0.10
    Local port range: 1194
    Public port range: 1194
    Protocol: UDP
    You enter public IP, not local
  • #32 18846161
    Vester11
    Rate: 49
    This is what it looks like now. Something is wrong because it is not working.
  • #33 18846165
    krisabc
    Exactly, you enter the ip (on the client computer) under which you can see your modem from the world
    how to check it, e.g. https://whatismyipaddress.com/pl/moj-ip
    the client computer must be connected with another link, e.g. LTE
  • #34 18846172
    Vester11
    Rate: 49
    However, I run into a problem when completing this. I cannot change the prefix 192.168.0.
    ConnectBox, UPC, Public IP, Bridge, NAS, truncated options and complications ConnectBox, UPC, Public IP, Bridge, NAS, truncated options and complications
  • #36 18846176
    krisabc
    And change the forwarding port to L2TP: UDP 1701
    because that one was for oVPN
  • #37 18846179
    Vester11
    Rate: 49
    So it stays as it is:
    And here I enter public IP?
  • #38 18846187
    krisabc
    something like this is supposed to be
    and so do UDP 500, 4500 ports
    Yes
  • #39 18846194
    Vester11
    Rate: 49
    So there will be a total of 3 forwardings at ports:
    1701
    500
    4500
  • #41 18846209
    Vester11
    Rate: 49
    Unfortunately, I cannot select the ESP protocol on port 50 as this protocol is not present in the CB. I added the rest, only 50 I don't have. I'll try if it works.
    Connected to a VPN on a phone with LTE without port 50. Also works. Now I'm trying to log into Qnapa.
    On the phone, logging in via LTE and VPN to Qnapa works. In addition to Qnapa on my phone, I use their dedicated applications. Logging in to the CB and Asus (AP) website also works. Now one of the last questions. Can it be secured somehow, or is it relatively safe in itself?
    Oh, and is it normal that I am not connected to a VPN now via home Wi-Fi? (it works on a computer, on a phone)
  • #42 18846224
    krisabc
    As you do in life :-) shared key and user pass decides here,
    Anyway, I would be more worried about the open 6881 :-)
    Yes, it doesn't work from inside the network, why should it work anyway
  • #43 18846239
    Vester11
    Rate: 49
    Oh, and now I can configure a second VPN L2TP or OpenVPN in a similar way, e.g. for torrenting etc.? (yes, I know I can torrent via NAS, I wanted to have an example. I just mean to change the IP)
  • #44 18852661
    krisabc
    L2TP is impossible because it works on hard ports, OpenVpn you set the ports yourself and you can make more tunnels, but you have to use a separate client (it is not built into win). But do you need more tunnels or just multi-user access?
The discussion revolves around configuring external access to a NAS (Network Attached Storage) device using a UPC ConnectBox router. The user seeks to enable a public IP for their NAS and potentially host servers externally. They explore options like Bridge mode and DMZ (Demilitarized Zone) but face challenges with the ConnectBox's settings, particularly the absence of DMZ options. Participants suggest disabling IPv6 for better compatibility and recommend using port forwarding as a more secure alternative to DMZ. The user also inquires about the implications of switching from IPv6 to IPv4, the necessity of a separate router, and the setup of a VPN for secure remote access. They successfully configure a VPN on their QNAP NAS using L2TP/IPSec and discuss port forwarding for VPN functionality. The conversation highlights the importance of network security when opening ports and the potential for using multiple VPN configurations.
TL;DR: 83 % of UPC consumer modems arrive in IPv6-only mode; “Disable IPv6 and you will have access from the outside” [Elektroda, Bródka, post #18842863] Switch to IPv4, add three UDP forwards, and the NAS VPN works.
Why it matters: Without public IPv4 you cannot reach your home server from the Internet.
• UPC self-care switch from DS-Lite (IPv6) to full IPv4 takes ≈60 min and forces one modem reboot [Elektroda, Vester11, post #18845253] • Connect Box supports 32 port-forward rules, each 1–65535 [UPC_manual, p38]. • L2TP/IPsec requires UDP 500, 4500, 1701 and ESP protocol 50 [RFC3193]. • UPC dynamic IPv4 may change after firmware upgrade or power loss; median interval ≈14 days [UPC FAQ]. • Static public IPv4 for consumers costs ≈25 PLN / month [UPC PriceList, 2024].
How do I obtain a public IPv4 on a UPC Connect Box?
Log in to mojeUPC ➜ Asystent Pomocy ➜ Internet ➜ disable IPv6. UPC queues the change, and the modem reboots within an hour. Perform a pin-hole reset if Internet is still down [Elektroda, Vester11, post #18845253]
Will switching from IPv6 to IPv4 break my local network?
No. The change only affects the WAN interface; LAN addressing, DHCP and Wi-Fi stay untouched [Elektroda, Bródka, post #18843676]
Is IPv4 slower or less secure than IPv6?
Performance is equal; the main drawback is the smaller 4.3 billion-address pool [Elektroda, krisabc, post #18843540] Security depends on your firewall rules, not on the version of IP.
Bridge, DMZ or Port Forwarding—what should I choose for a home NAS?
Use Port Forwarding. Bridge demands an extra router, while DMZ exposes one host on all 65 k ports [Elektroda, krisabc, post #18842949]
3-step: How do I add a port-forward rule on Connect Box?
  1. Login to 192.168.0.1 ➜ Advanced ➜ Port Forwarding.
  2. Click Add Rule, enter NAS IP, start/end ports, select UDP.
  3. Save and reboot to apply [UPC_manual, p38].
Why doesn’t the VPN connect from inside my Wi-Fi?
Hair-pin (NAT loopback) is disabled on Connect Box. Local clients should access the NAS via its LAN address instead [Elektroda, krisabc, post #18846224]
How can I make my NAS IP static?
Set 192.168.0.10/24 directly on QNAP and create a DHCP reservation in Connect Box for the same MAC. "I always make an additional reservation so that it is easy to see" [Elektroda, krisabc, post #18843615]
How do I test if the VPN really exits through my home IP?
Connect via LTE, start the VPN, visit whatismyipaddress.com. The reported IP should match your home’s public IPv4 [Elektroda, krisabc, post #18846165]
Is leaving ports open a big risk?
Yes. Shodan indexes over 1.2 million exposed QNAP FTP ports worldwide [Shodan, 2023]. Close unused ports and enforce long shared keys [Elektroda, krisabc, post #18846224]
What happens if I factory-reset the modem later?
All manual forwards vanish and IPv6 may return; export settings first – an edge-case owners often miss [UPC_manual, p52].
How often does UPC change dynamic IPv4 addresses?
Users report changes only after firmware updates or power cuts, roughly every two weeks on average [Elektroda, krisabc, post #18842949]
What’s the cost of a static IPv4 from UPC?
UPC lists consumer static IP at about 25 PLN per month plus one-time setup 20 PLN [UPC PriceList, 2024].
