[Solved] Using Bridge Mode on UPC Connect Box: TP-Link Archer AX55 Setup & Operating Without Operator
Kaymanpl 27543 5
  • Clarifying bridge mode and single-router setup
    #1 20072716
    Kaymanpl
    Level 4  
    Rate: 10
    Hello, I have a few questions related to Bridge mode:
    I have internet from UPC optical fiber and I changed the router to TP link Archer ax55 and unfortunately the router does not work because it must be from the operator, in this case upc connect box.
    Currently, I have the Internet that goes from the amplifier to the Router upc connect box works and the ethernt cable from lan 1 goes to the wps of the Archer ax55 router and that's how my wifi works.
    1. Will Bridge Mode allow me to operate only 1 router and be able to disconnect from the operator.
    2. How Bridge mode works.
    3. Because I will have to call the helpline to turn on the Bridge mode and how will I have to have it connected to work well for me
    Thanks in advance for your help.
  • #2 20073180
    KOCUREK1970
    Help: 3860
    Rate: 5488
    I mean what exactly? - because today, whoever gives 1m of optical fiber anywhere, claims that it is fiber optic internet.
    So what exactly is this offer and what exactly is the equipment there? (the equipment has markings on the sticker, its name is there).
  • #3 20073252
    SP5IT
    Help: 1298
    Rate: 1695
    Bridge turns on by itself in the modem settings.
    Bridge mode still requires two devices
    #4 20073398
  • #5 20073948
    Kaymanpl
    Level 4  
    Rate: 10
    Thanks for the clarification, I've been waiting for a reply like this.
  • #6 20073949
    Kaymanpl
    Level 4  
    Rate: 10
    Thanks for the clarification, I've been waiting for an answer like this.
    Added after 35 [seconds]:
    Erbit explained everything.
