Protecting Car Rubber Parts from Aging: Acid-Free Vaseline for Brake Hoses & Joint Covers
GK 17970 14
Can I protect car rubber parts from aging by coating them with technical acid-free Vaseline?
No, technical acid-free Vaseline is not a good way to protect car rubber parts from aging. It will mostly attract sand and dust, and it can also remove plasticizers from the rubber surface, which may make it stiffer over time [#16510912][#16511131] Several replies say it will not really stop aging; at best you can use a rubber varnish or a dedicated rubber care product, and even then compatibility matters so you do not damage the part [#16511426][#16512253] The thread also notes that good-quality original rubber can last around 15 years, while low-quality rubber ages quickly regardless of treatment [#16511358][#16511209] In practice, worn rubber parts should be replaced rather than “regenerated” [#16511347][#16511426]
  • #1 16510878
    GK
    Help: 60
    Rate: 154
    Needs to protect the rubber parts in the car from aging (brake hose hoses, joint covers, steering knobs and other rubber elements). I intend to use technical acid-free Vaseline. What do you think about this idea?
  • #2 16510912
    ladamaniac
    Help: 724
    Rate: 2078
    Theoretically, it will give advice, in practice petrolatum will catch sand and dust. There are many measures typical for rubber preservation, from those for PLN 5 to Forch or Wurth.
    Good quality rubber parts without maintenance last a dozen or so years, the bad even holy water will not help.
    Some ancient monument?
  • #3 16511112
    telecaster1951
    Help: 829
    Rate: 818
    No way. Vaseline will not give you anything.
    Painting can help a little, but not too much.
    As rubber has few antioxidants, nothing will help.
  • #4 16511131
    Robert B
    Help: 2027
    Rate: 1412
    Of course. In addition, it removes plasticizers from the rubber surface, which after some time will cause even more stiffness.
  • #5 16511209
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    After 2 years of practice, I will tell you that it will not help. Simply low quality rubber is aging fast.
    It's easy to get to know the original elements and very cheap toys.
  • #6 16511266
    stanislaw1954
    Help: 2013
    Rate: 4673
    And I will add such an example - many older electricians, probably remember the Polish three-finger dielectric gloves. Which bad rubber were made of. After a few years they crumbled. Later, French and English appeared. There,% rubber in rubber was just right.
  • #7 16511304
    Robert B
    Help: 2027
    Rate: 1412
    I remembered an old piece of rubber:
    A lot of feces, not much of a chuk :)
  • #8 16511347
    GK
    Help: 60
    Rate: 154
    I am not talking about the regeneration of rubber, but about slowing down the aging process.
    It is known that used rubber parts should be replaced. The car is Skoda Fabia 2008
  • #9 16511358
    Help: 1405
    Rate: 6430
    If you have the orginalne, they will calmly reach 15 years. Unless the metal is worn out earlier.
  • #10 16511426
    telecaster1951
    Help: 829
    Rate: 818
    I'll tell you that. The rubber content in the mix does not have a big influence on the durability of the rubber. In order for the rubber to not sweat, antioxidants and preservatives are needed. Without it, the gum is rubbing, no matter what rubber was.
    Nothing will give. It can only help varnish the rubber, but you need to know what rubber is, so as not to damage it. In short, it does not make sense.
  • #11 16511571
    stanislaw1954
    Help: 2013
    Rate: 4673
    The rubber content in the mix does not have a big influence on the durability of the rubber. In order for the rubber to not sweat, antioxidants and preservatives are needed. Without it, the rubber is rubbing
    I do not know what ingredient in those gloves was missing, because I do not know the composition of the rubber, but you can see something missing, because those gloves were unstable, in contrast to the aforementioned new ones.
  • #12 16511590
    telecaster1951
    Help: 829
    Rate: 818
    Antioxidants were missing and there was too much chalk. Oh what.
  • #13 16512253
  • #14 16512636
    tomek_602
    Help: 51
    Rate: 61
    I do not care for efficiency, but once it was recommended to protect the rubber by coating with silicone grease.
  • #15 16512709
    telecaster1951
    Help: 829
    Rate: 818
    Not everyone, not everywhere.
The discussion centers on the effectiveness of using acid-free Vaseline to protect rubber components in vehicles, such as brake hoses and joint covers, from aging. Several participants express skepticism about this approach, citing that Vaseline may attract dust and sand, potentially exacerbating wear. They emphasize that the longevity of rubber parts largely depends on their quality, with low-quality rubber aging rapidly regardless of treatment. Alternatives such as specialized rubber varnishes and silicone grease are suggested, as they may provide better protection by incorporating antioxidants and preservatives. The conversation also touches on the importance of using original parts, as they can last significantly longer than inferior substitutes.
