JBL TUNE 500bt Wireless Headphones: Connectivity Issues and Unresponsive Power Button
Alex110 49947 5
  • #1 18897972
    Alex110
    I've been using these headphones for the second year and have never had a problem with them. About two days ago I got a call on the messenger and I didn't want to talk to the headphones on my ears and tried to turn them off, but apparently it didn't work. Since then, I can not turn them off, and when I hold down the on button, I do not hear anything the first time, and the second time I hear the sound of turning on. The light is white and it does not go out at all. I charged it and it did not help, and by the way I cannot find them in Bluetooth. Anyone had this problem? They broke or just jammed. Thank you in advance for each tip and advice. :)
  • #2 18898076
    tomtim123
    Level 37  
    Help: 423
    Rate: 762
    Try holding down the power button for a longer time like about 30sec. and watch what happens. Sometimes the headphones seem to freeze. Perhaps it happened to you.
  • #3 18898131
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    You need to reset the headphones, it should write about it in the manual.
  • #5 19551344
    reyalP
    Level 4  
    Rate: 34
    Hello, is the problem solved? I have a similar problem with these headphones and am trying to figure out how to reset them to factory settings.
  • #6 19835453
    Zigg
    Rate: 22
    With the headphones turned on, you hold down the + and - buttons simultaneously for about 5 seconds and the headphones reset.
