Electrolux EWM 2100 - Need to know what a component is on the EWM 2100 board
Electroniik 18333 7
  • #1 18907806
    Electroniik
    Label with barcode and serial number ST100X AUS. Hi Everyone,
    Does someone know what the component circled on the picture is (a choke coil?, a transformer?)?
    My washing machine does not get any power anymore and this component, and a few others around it, are blackened. I would like to replace this component but I'm not sure what it is, I don't know how to find it and where I can order it.
    Does anyone know what the E47 x 1042 writing mean?
    I've spent a couple of hours on Google searching for it but was unsuccessfull.
    Thanks for your help. Washing machine circuit board with a highlighted component. Close-up of a circuit board with a marked component labeled E47 x 1042. Close-up of an electronic component on a circuit board labeled E47 x 1042, circled in red.
  • #2 18910848
    Electroniik
    I found information once I searched on Google using "Zanussi" instead of "Electrolux". The component is a transformer.
  • #3 18912971
    Loker
    Help: 575
    Rate: 721
    Inverter transformer. Don't move - it practically never breaks down. Besides, you can't buy it anywhere.
    Check the fuse resistor, post a photo from the bottom of the board in the vicinity of this transformer.
  • #4 19227427
    scott__
    Rate: 25
    Hi Electroniik.
    I have the same problem. Do you know which part is faulty? Did you find a solution?
    Thanks.
    Scott
  • #5 19227579
    Electroniik
    I'm afraid I haven't found a solution because the washing machine belonged to a friend who gave up on it.
  • Transformer markings and resistance measurements on EWM 2100 board
    #6 19227589
    scott__
    Rate: 25
    That's a shame. My circuit is exactly the same as yours - same black soot in the same places. My transformer has the markings E47 x 1116. I don't know what they mean (except E is the type of ferrite core).
    Thanks for getting back to me.
    Did you measure your transformer with a multimeter? Mine measures 8 ohm on the primary and a short circuit on the secondary (I think - I haven't removed it from the board so other parts of the circuit could be interfering with the reading).
  • #7 19235782
    Loker
    Help: 575
    Rate: 721
    This is a flyback converter transformer - the secondary winding has several turns so it's normal for the meter to show a short circuit.
  • #8 19250679
    scott__
    Rate: 25
    Thanks Loker. Yes, turns out the flyback transformer was fine. The black soot must just have been attracted to the magnetic fields. I replaced a blown triac and now the board is working again.
The discussion revolves around identifying a component on the Electrolux EWM 2100 washing machine's circuit board, specifically a blackened transformer. Users suggest that the component is an inverter transformer or a flyback converter transformer, which typically does not fail. One user mentions that the markings on their transformer are E47 x 1116, indicating it is a type of ferrite core. Another user notes that the black soot may not indicate a faulty transformer, as they successfully replaced a blown triac, restoring functionality to the board. The conversation highlights the challenges in sourcing replacement parts and the importance of checking other components, such as fuse resistors.
