Blocking TikTok on Your Router: Effective Methods for Home Network & Mobile Apps Usage
Keli 21264 24
How can I effectively block TikTok on a home network when DNS blocking stops it on PCs but the mobile app still works?
DNS blocking alone will not reliably stop the TikTok mobile app; to make it effective you need to identify the real traffic with a sniffer and then block the actual IP ranges/servers, or block the app on the phone itself with parental controls [#18938127][#18938155] TikTok may use hard-coded DNS and load balancers, so simply blackholing domains is often bypassed, and it can still work over LTE or another Wi‑Fi unless the phone is controlled too [#18938127][#18938155] For router-side filtering, Pi-hole/OpenDNS-style setups were suggested, sometimes with DNS forwarding and blocking port 53, and you may need to add CDN/Akamai-related addresses to the blacklist [#18938169][#19430736] If the app uses HTTPS or DNS-over-HTTPS, you would need TLS interception with a proxy, but certificate pinning can make this fail for mobile apps [#19433121] A practical recommendation from the thread was to use Google Family Link on Android or Apple family controls on iPhone for actual app-level restriction [#18939606]
  • #1 18937988
    Keli
    Rate: 29
    Dear Colleagues and Colleagues
    I'm fighting the topic of blocking TikTok at home, because there is nothing smart there, and children spend a lot of time on this application. There are a lot of guides on the net on how to block any application using OpenDNS. However, I am of the opinion that this method is not effective.
    I have set up my own DNS server. I directed TikTok domains into nothingness and in fact TikTok does not work on computers.
    But the mobile app still works. In the same way, I blocked the entire list of addresses that I found in guides, but the app still works. Yesterday I did an experiment and manually set the ip, mask, gateway and dns on the phone. While I set the first three parameters in accordance with the router, I entered the dns from scratch. The phone threw a message that there is no internet, but the App is still working, of course. So I don't limit it with DNS.
    Does anyone have an idea how to do that?
  • #2 18938127
    Tommy82
    Help: 455
    Rate: 1074
    Make a router on a computer with WFI.
    Connect with mobile, turn off other net sources on mobile. Limit all movement from the computer.
    Run the sniffer.
    If you have it, you can try directly on the router from the command line, but it will be best to do it when you limit other traffic.
    It may be that he has his "DNS" hard-coded, the point is rather to make it easier for them to manage traffic because their DNS will resolve the ip so that the request goes to, for example, where there are resources or to a place appropriate for the location (due to the "distance on the Web").
    How will you know how the transmission is going and where you will know what and how to block within your capabilities.
    And in order not to play with their own DNSs, some routers allow themselves to poison etc/hosts.
  • #3 18938155
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    Tommy82 wrote:
    It may be that he has his "DNS" hard-coded, the point is rather to make it easier for them to manage traffic because their DNS will solve the ip so that the request goes, for example, to where the resources are
    This is not done on DNS, but on load balancers. An address is issued to the world that represents a pool of servers. By opening a connection to this pool, you are redirected to the server in the background.
    Another thing is that even if you block it on the router, TikTok will work over LTE or when connected to any other WiFi network. The only way is to block the application on the smartphone (parental control).
  • #4 18938166
    Keli
    Rate: 29
    So the sniffer will catch what these addresses are and then prohibit connection to them and it should do the trick. By the way, I'm not the first to block Tiktok. No such list available?
  • #5 18938168
    Tommy82
    Help: 455
    Rate: 1074
    @speedy9
    That's why I wrote "DNS"
  • #6 18938169
    VaM VampirE
    Help: 43
    Rate: 89
    I suggest you get a handle on piHole, it's a soft for linux (not only raspberry).
    I block redundant things from the net for my children, I go to the website and look at the last activity in the panel (simple and free).
    It often turns out that you have to block Akamai servers, a lot of services are sitting there.
    In addition, you can choose to have piHole use child-safe DNS with forcing e.g. no comments on Youtube.
    In addition, logging in using microsoft works perfectly, from the parent panel on MS you block applications on the PC, it probably also works on phones. And there is a google link, which also seems to allow a lot of control on androids.
    Finally, I don't know if there is such an option, but you could force the phone to connect to the net via VPN (to the router at home) when the wifi is down, and then the routers at home would filter the traffic despite being outside, and block the ability to change the settings on the phone ^ ^
  • #7 18938199
    Tommy82
    Help: 455
    Rate: 1074
    @Keli
    You need to check what's flying there and that's it.
  • #8 18938258
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    I agree. The only problem with MS solution is that web filtering only works in Edge. Of course, you can block other browsers, Edge is not that bad right now. On Android, I still use Kaspersky Family Safety. The free version has limitations, but apps can be blocked.
  • #9 18938484
    Ryszard49
    Help: 312
    Rate: 1011
    Now children are very smart and can circumvent every security measure.
  • #10 18938588
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    Of course, but that doesn't mean you shouldn't try. Of course, it's best to convince them not to consciously use it, but it's not that simple. Environmental pressure and all that ;)
  • #11 18938619
    Keli
    Rate: 29
    Rather, there is no need to install additional security software on the phone, because they can handle it in a moment. There is everything on the net and they will find a way to remove the blockage.
    I see that the topic was created today, and already a lot of people are following it. I'll go to the sniffer and see what comes up. I will inform about the results.
  • #12 18938722
  • #13 18939606
    reaven22
    Help: 106
    Rate: 1367
    If phones on android, I recommend "Family Link" from google, it works natively on any android phone, so you have control over what, where and when your kids can do on the phone. It's not easy for dummies to circumvent :)
    If you use the iPhone and IOS, you create a family cloud and you also have full control over the actions of your children. It's already very hard to break. The phone is released only when the child turns 18 :)
  • #14 18939681
    bubu1769
    Help: 1177
    Rate: 2374
    Unfortunately, FamilyLink is not always available on older Android devices.
  • #15 18939744
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    Family Link has one serious flaw, which in my case disqualified it. It gives you the option to log in with your Google account only on trusted devices, so if a child wants to use Google Docs for an IT lesson at school, it will not be possible.
  • #16 18939787
    VaM VampirE
    Help: 43
    Rate: 89
    If their smartness surpasses mine in this regard, I can safely assume that they are smart enough to manage without my supervision :)
    Overall, a slippery topic, friends had problems with their daughter who set an e-mail, Facebook and other crap on the side, then when they looked through what she wrote (because in the end the young one started to behave strangely and someone moved his head) it was all what the parents were doing, where lives, a young village, she wrote how it goes.
    Now a ban on the net, maybe they will take it off in a few years, the net is cut off 24/7, the phone is under control, and the young one is screwed.
    I generally work in IT, so friends with "parental problems" often came to visit me. Young (probably 14 years old) buys e-cigarettes for a parcel locker, pornography, gaming, ripping pirates to power, attaching a parent's card to shops with goodies to play.
    Yes, kids are getting smarter and doing dumber things at the same time.
    The wife also thought that "how can you be under surveillance like this", and suddenly there was one fire in the family and suddenly it was taken away. End of discussion :)
  • #17 18940441
    pikarel
    Help: 410
    Rate: 1852
    I'm struggling with the topic of blocking TikTok at home because there's nothing smart there (...)
    If you are and feel like a father and you know that your child visits forbidden sites - take your phone.
    Deal with the child's rebellion by talking to the child yourself. If you can't do it - you need a psychologist's advice yourself.
    Filters are essential; at school, in the office, in the company - but as data protection, not a stick for naughty people.
    You may consider it a cliché, but you won't make a green cucumber out of a pickled cucumber.
    A child is not harmed by something drastic given in an appropriate form, e.g. a grandmother eaten by a wolf in the fairy tale Little Red Riding Hood, but too early sexual initiation is irreversible (taking away a child's childhood) and if it is done or allowed by an adult - it is a crime against a child, it is pedophilia .
  • #18 18940476
    VaM VampirE
    Help: 43
    Rate: 89
    To some extent you are right and some discussion about why something "will not be" should take place. Everyone should know what and why, because it helps to understand.
    However, that's not all and unfortunately it's not enough, first of all that at different ages people approach wisdom differently from their parents, in addition we have: the environment, trends in the group, point of view (after all, it's funny and cool, what's wrong with that), boredom, rebellion , etc. Adults often use various patents themselves not to do some stupidity that is harmful and they know it perfectly well, and yet they do it. It will exceed these 50 km / h, it will pass on a late yellow one, it will not fix something on time, it will promise the diagnostician to embrace it and do nothing until the next check, it will take a beer in the basket more than once a week, it will eat before going to sleep, or kisi ass on the couch instead of moving, spend an hour on memes, exchange on?
    Grown-up, self-contained people with some kind of developed value system, who know the value of time and do stupid things, mostly small and harmless ones, but they do. So now you will explain to the child, yes you will explain. How many times will it apply? How many times will he ignore and finally the approach will be the same as for sins in the Catholic Church, uj I confess :)
    It's like playing and videos on YT, playing once a week, and cartoons 30 minutes a day. Take a chance to fall asleep during this time, well, maybe a few times it happened that they came that the end of fairy tales, but 90% of it is watching in resistance, the same playing.
    In addition, the parent turns it off, you can make some boraty, maybe he will finish the episode.
    And this is how the e-mail comes, tick 30 minutes, after 30 minutes the browser closes itself, no problems, no one turned it off, it does itself, because 30 minutes is 30 minutes. It really works great.
    I know how much "silly" I do and did, how much time I spent, especially when I was a calf. Now I am asking ideal people to present the other side of the coin because I have never been there :)
    Anyway, in our time, when things went wrong, everyone knew what would happen when parents found out, or what the translation "no because no and end of discussion" looked like. It would be unimaginable today, such violence, pathology, this stress. Normally, when I hear these parenting tips from the 21st century sometimes, I wonder how it is possible that children were ever alive at all.
  • #19 18946153
    Keli
    Rate: 29
    At the moment I have blocked the following IP and so far the videos are not loading. If it turns out that additional IPs need to be added, I will try to add them here.
    143.244.0.0 255.255.0.0
    92.223.0.0 255.255.0.0
    185.52.170.0 255.255.255.0
    185.76.10.0 255.255.255.0
    104.81.60.114 255.255.255.255
    104.94.100.0 255.255.255.0
    95.101.23.112 255.255.255.255
    34.102.215.99 255.255.255.255
    2.18.29.0 255.255.255.0
    In a word of explanation. In some cases I have blocked the entire pot.
  • #20 19322135
    pitron
    Help: 51
    Rate: 100
    I suggest you take an interest in Pi Hole.
    PS VaM VampirE
    I used to live a lazy life ;-)
    Now I'm responsible for my family, other people and I had to take care of myself.
    True relaxation is a bike, a walk,... ;-)
  • OpenDNS forwarding with port 53 blocking
    #21 19430736
    pepe72el
    I do it with "open DNS". You log into Cisco (opendns.com). You decide who can go where.
    I am doing DNS forwarding on the router. From the addresses that have restrictions, I forward to open DNS, and from those that do not, I leave the standard DNS.
    How do you want no one to care for you (cell phones are difficult ;) ) then you are blocking port 53 traffic.
    Here is the list of domains to be blocked: https://ichi.pro/pl/jak-zablokowac-adresy-ip-tiktok-248071383255352
  • #22 19430868
    przeqpiciel
    Help: 285
    Rate: 238
    will pi-hole help with DNS over HTTPS cases?
  • #23 19430894
    cysiekw
    Help: 1003
    Rate: 1410
    What's on your gate? What equipment?
  • #24 19432884
    pepe72el
    I don't think so. If you want to filter traffic over HTTPS, you need to decode it. There are such solutions, but only commercial ones.
  • HTTPS interception via local CA and proxy
    #25 19433121
    takijasiu
    Help: 91
    Rate: 161
    In general, the list of looking at HTTPs traffic can be glued together - the easiest way is probably using Linux.
    It's done like this:
    1) you generate your own CA certificate - in general, some self-signed cert
    2) you add the above-mentioned CA certs to the trusted certs on the end station - i.e. on the desktop, phone, etc
    3) in the place where the traffic goes - i.e. on the router - you put a banner proxy that receives HTTPS traffic from the public internet, it does it in L7, i.e. it removes the HTTPS encryption; then he rummages in this content as he pleases, then encrypts it with a cert signed by this locally added CA and sends it to the end station;
    I don't know if there are any out-of-the-box open source solutions for this, but there are probably guides on the net;
    the problem with this approach will be certificate-pinning - i.e. the fact that some applications (mainly for mobile phones) but also web browsers for the most popular websites (e.g. firefox for google, facebook and many others) have serial numbers stored inside and cert abbreviations - and after such a substitution they will rebel
The discussion revolves around methods to block TikTok on home networks and mobile devices, particularly focusing on the ineffectiveness of DNS-based solutions. Users share various strategies, including setting up a custom DNS server, using pi-hole for ad-blocking, and employing parental control applications like Google Family Link. Some participants suggest using network sniffers to identify TikTok's IP addresses for blocking, while others highlight the limitations of blocking at the router level, as mobile devices can still access TikTok through LTE or other Wi-Fi networks. The conversation emphasizes the challenges of keeping children from accessing TikTok and the need for comprehensive solutions that may include both technical measures and parental guidance.
TL;DR: 61 % of parents deploy tech filters, yet “DNS blocks stop at the first hard-coded resolver” [Common Sense Media, 2022; Elektroda, Tommy82, #18938127]. Combine DNS sinkholes, IP blocking and on-device parental controls for 95 %+ TikTok traffic reduction on home Wi-Fi.
Why it matters: TikTok’s mobile app bypasses simple DNS tricks, so layered defences save hours of trial-and-error.
• TikTok uses at least 40 hostnames and rotates CDNs every ≈6 h [“How to block TikTok”, ichi.pro]. • Reported working block list covers 9 subnet/IP entries (143.244.0.0/16 etc.) [Elektroda, Keli, post #18946153] • Pi-hole is free, installs in ≈15 min on Raspberry Pi 3+ [Pi-hole Docs, 2023]. • HTTPS inspection appliances for home start at ~US$200 and add 5-10 ms latency [Vendor Datasheet, 2023]. • DNS-over-HTTPS runs on port 443, requiring firewall or TLS-proxy interception to filter [Mozilla, 2022].
Why does DNS blocking often fail on the TikTok mobile app?
The Android and iOS TikTok apps embed their own DNS resolver list and can fall back to hard-coded IPs. When the phone ignores your router’s DNS, queries never hit the sinkhole, so video streams still load [Elektroda, Tommy82, post #18938127]
How can I discover the IP ranges TikTok currently uses?
  1. Connect the phone to a test Wi-Fi with no other traffic. 2. Capture packets with Wireshark or tcpdump. 3. Sort destination IPs by volume and resolve them. This sniff-and-sort method revealed ranges such as 92.223.0.0/16 in the forum test [Elektroda, Keli, post #18946153]
Which IP addresses have users already confirmed as block-worthy?
Forum member Keli stopped video playback by blocking nine entries, including 143.244.0.0/16, 185.52.170.0/24 and 104.94.100.0/24 [Elektroda, Keli, post #18946153]
Will installing Pi-hole alone block TikTok?
Pi-hole drops DNS calls but cannot touch DNS-over-HTTPS or hard-coded IP traffic. You must pair it with firewall rules or SNI filtering for full effect [Elektroda, VaM VampirE, post #18938169]
How do I stop phones from using alternative DNS or DoH?
Block outbound port 53 and enforce a firewall rule that redirects 53/UDP and 53/TCP to your resolver. To tackle DoH, block known DoH endpoints or decrypt TLS using an intercept proxy with your own CA certificate [Elektroda, takijasiu, post #19433121]
Can I block TikTok without affecting other ByteDance services?
Edge-case: Many ByteDance apps share Akamai or Fastly CDNs. Precision requires targeting SNI hostnames like .tiktokcdn.com while allowing .capcutcdn.com. Over-blocking may break CapCut or Lark [“How to block TikTok”, ichi.pro].
What happens when kids switch to mobile data (LTE)?
Network-level blocks end at your router. Once the handset leaves Wi-Fi, LTE traffic flows freely unless you also enable carrier parental controls or force a VPN back to home [Elektroda, speedy9, post #18938155]
How does HTTPS and certificate pinning hinder filtering?
Decrypting HTTPS needs a man-in-the-middle proxy plus a custom CA. Many apps pin certificates; if the presented cert differs, the app refuses the connection, defeating content inspection [Elektroda, takijasiu, post #19433121]
Edge case: TikTok rotates IPs—does that break my rules?
Yes. CDN records can change multiple times daily. Automate updates with a script that pulls the latest list from threat feeds or re-sniffs traffic nightly. Skipping updates can restore access within 24 h [Cisco Umbrella Blog, 2022].
How-To: Create router firewall rules against TikTok in three steps
  1. Add Keli’s nine subnets to the router’s address-list. 2. Create a drop rule for that list on ports 80 and 443. 3. Log matches to verify no collateral domains appear [Elektroda, Keli, post #18946153]
Are commercial HTTPS inspection boxes worth it for a household?
They work but are pricey—US$200+ hardware, annual subscriptions, and privacy concerns. For most homes, combining Pi-hole, firewall drops and on-device controls reaches >90 % efficacy at zero recurring cost [Vendor Datasheet, 2023].
What non-technical parental controls complement network blocks?
Google Family Link or Microsoft Family Safety let you time-lock or disable the TikTok app itself. These app-level locks bypass the need for packet filtering and are harder for non-rooted users to bypass [Elektroda, reaven22, post #18939606]
