Internet: Site Blocking on Vectra Network - Access Denied to Adult Content (xxx) & Solutions
onomatopeja91 5964 11
Why is adult-content access blocked only on Vectra Wi‑Fi on my laptop, while the same sites work on my phone or another network, and how can I bypass or change that block?
This is most likely a DNS block set on the router by the network admin, not state censorship, and it may be redirecting all DNS queries to OpenDNS [#16222888][#16222908] If the block is done that way, changing DNS only on your laptop will not help; the usual workaround is a proxy or VPN, with DNS queries routed through the VPN [#16222888] To verify whether the laptop itself is the problem, test it with a cable to the router and in Safe Mode with Networking, and check the network card settings [#16222998][#16223451] If it really is OpenDNS, switch to another DNS provider such as your operator’s DNS or Google’s [#16224100]
  • #1 16222835
    onomatopeja91
    Today I wanted to visit a known page (xxx ;) ) and suddenly it pops up that I'm blocked from accessing porn sites. Via another network (e.g. by sharing the net from a cellular network via wifi), websites with such topics are already running on my computer. Where did it come from? Vectra could block access to sites on such topics? Some censorship in the state or what? :D
  • #2 16222844
    przeqpiciel
    Help: 285
    Rate: 238
    maybe your parents played a trick on you?
  • #3 16222872
    onomatopeja91
    You are following the wrong lead, it is not about any parents because I do not live with them (I am a student). There is a connection on the same device via another network, only via vectra. This is what amazes me the most ;)
    I will suggest that it is blocking me via OpenDNS
  • #4 16222888
    bogiebog
    Help: 2569
    Rate: 1530
    Then you have a DNS blocker.
    the only way around is by proxy or your VPN server and redirecting DNS queries through your VPN.
    If the DNS block is well done, setting your DNS in the computer will not do anything, because the block is on the router and all DNS queries are redirected to openDNS. I set up such a block myself (at the client's request).
  • #5 16222901
    onomatopeja91
    But who is blocking it then? ISP?
    It makes me wonder if Vectra has offered me some censorship :D
  • #6 16222908
    bogiebog
    Help: 2569
    Rate: 1530
    Your network manager, admin from whom you got the net.
    onomatopeja91 wrote:
    Vectra did not offer me any censorship
    Maybe they have some options on the link.
  • #7 16222914
    onomatopeja91
    And by what right can he do something like that? Did they forbid it in our country or what? ;)
  • #8 16222931
    bogiebog
    Help: 2569
    Rate: 1530
    Who pays this requires.
    You personally pay for the net? who? look for options on this subject in the regulations.
  • #9 16222944
    onomatopeja91
    To be honest, I got a bit lost, because ... by entering this website on the phone (being connected to the same network on which it is blocking my computer) it already works: o
    Summarizing:
    On my laptop, it does not work via wifi (I do not have the option to check on the cable) and it works via the cellular network provided from the phone.
    It works on the phone both via wifi and via the mobile network.
    How is this possible? :D
    Added after 6 [minutes]:
    Yes, I pay. It is very strange, since the phone works via the same wifi network :P
  • #10 16222998
    bogiebog
    Help: 2569
    Rate: 1530
    Without testing the laptop with a cable to the router, we will further theorize.
    In addition, a test with a laptop in safe mode + network support.
  • #11 16223451
    przeqpiciel
    Help: 285
    Rate: 238
    Alternatively, show the network card settings from the laptop, maybe someone made a change for you.
  • #12 16224100
    KOCUREK1970
    Help: 3861
    Rate: 5489
    Well, change to another - operator or google.
The discussion revolves around a user experiencing site blocking for adult content while connected to the Vectra network. The user notes that access is possible through a cellular network but not via Wi-Fi on their laptop. Responses suggest that the blocking may be due to a DNS filter, possibly implemented by the Internet Service Provider (ISP) or network administrator. Solutions proposed include using a VPN or proxy to bypass the block. The user is confused about the inconsistency in access across devices on the same network and questions the legality of such censorship by the ISP.
