Failed IPTV connection after returning from holiday - how to fix it?
Fala1989 18279 16
Why does my IPTV app on a Samsung TV show “connecting failed” after a few weeks away, and how can I fix it?
First check whether the TV still has internet access; if it does, the IPTV service itself is probably the problem rather than the TV [#18941028] The most likely causes mentioned are that the m3u playlist links were blocked or that your MAC address was banned by the provider [#18941084][#18941092] Another possible issue is a device limit, since IPTV services can restrict how many devices may use the same source [#18941454] To diagnose it, open the m3u list on a computer, extract one stream URL, and test that URL in a browser to see whether it plays or returns an error [#18941454]
  • #1 18940925
    Fala1989
    Hi. Until 3 weeks ago the iptv phone was working without any problems. I went on holiday and when I came back I switched everything on to contacts and it turned out that iptv is not working. When entering channels it says connecting failed. Does anyone know how to work around this?
  • #2 18940952
    sosarek
    Help: 9320
    Rate: 15541
    Fala1989 wrote:
    tel. Iptv
    You've made an effort...
    What is the service, from what operator, on what device etc.?
    Z
    Pka, Poznań, 60-850
  • #3 18941024
    Fala1989
    So yes.
    Iptv is an application for Smart TV. I have a samsung TV. Thanks to this application, I buy from someone a list with TV programmes like tvn tvp etc. The list is loaded somehow on the m3m... I do not know who sells the list, he loads it for me with the help of a page and a possible mac address.
  • #4 18941028
    sosarek
    Help: 9320
    Rate: 15541
    Since you have a connection error then check if the internet on the TV is working, if it is then the seller probably got fed up and terminated access.
    Z
    Pka, Poznań, 60-850
  • #5 18941033
    Fala1989
    Of course I have a connection. And no one has been dissuaded from doing anything. I am in contact with the seller and even two of them, but they cannot fix it...
  • #6 18941038
    sosarek
    Help: 9320
    Rate: 15541
    Fala1989 wrote:
    I am in contact with the seller and even two of them, but they do not know how to fix it...
    You should have written about it beforehand and these "business janitors", whom you call "traders", are profiting from people's ignorance and selling lists available on the net which are on some servers.
    Z
    Pka, Poznań, 60-850
  • #7 18941046
    Fala1989
    Kurde sosarek you are not helping. Really. Thank you for your interest, but you're just getting in trouble and looking for hooks. I know what I'm buying and who I'm buying it from. Don't worry, I'm not a bit of a jerk. If you're relieved, consider it a boost to the economy. NaRka
  • #8 18941074
    sosarek
    Help: 9320
    Rate: 15541
    Fala1989 wrote:
    Kurde sosarek you are not helping. Really. Thanks for your interest, but you're just getting on and looking for hooks.
    What do you mean by
    sosarek wrote:
    they are preying on people's ignorance and selling lists available on the net being on some servers.
    After all, you only need to install for example Delta Media Player and export the list from it, similarly with KODI etc. so really
    Fala1989 wrote:
    Don't be afraid in the dark I'm not.
    Z
    Pka, Poznań, 60-850
  • #9 18941079
    Fala1989
    If you're smart, why aren't you helping?
  • #10 18941084
    sosarek
    Help: 9320
    Rate: 15541
    Help you with WHAT?
    Most likely the links contained in the m3u have been blocked and therefore don't work - that's it.
    Z
    Pka, Poznań, 60-850
  • #11 18941087
    Fala1989
    Not possible. Checked 3 letters from 2 different people. Brother has the same ones and dxialaja....
  • #13 18941096
    Fala1989
    By whom? And how to unban him?
  • #14 18941102
    sosarek
    Help: 9320
    Rate: 15541
    The model of this Samsung of yours is...? You can still check whether the manufacturer has ended support because then also some services become unavailable.
    Z
    Pka, Poznań, 60-850
  • #15 18941106
    Fala1989
    Why a shajsung right away? You like being mean huh?
    UE48H...
    Moderated By Mirek Z.:
    Colleague really can't behave culturally? https://www.elektroda.pl/rtvforum/faq.php - p.3.1.9, p.3.1.13, p.3.1.17. Warning.
  • #16 18941127
    sosarek
    Help: 9320
    Rate: 15541
    Fala1989 wrote:
    UE48H...
    So what's next? You can't even name the model of the TV?
    Z
    Pka, Poznań, 60-850
  • #17 18941454
    przeqpiciel
    Help: 285
    Rate: 238
    When I was playing around with IPTV, it:
    1. there is a limit on the number of devices, I don't know what you mean that your brother has the same ones, yours or from the same source ?
    2. if you have a m3u list, fire up the list on your computer and try to extract the link to the stream via notepad, then you can try to see what happens via the browser. whether you get a stream or some error code
    3. for me IPTV is crap, like a bigger event the TV worked unstable
The user reports a failed IPTV connection on their Samsung Smart TV after returning from holiday. Despite having a working internet connection, the IPTV application displays a "connecting failed" message. Other users suggest checking if the IPTV service provider has terminated access, as well as verifying the MAC address for potential bans. They also recommend testing the m3u list on a computer to extract stream links and check for errors. The discussion highlights the limitations of IPTV services, including device connection limits and potential service discontinuation by the manufacturer.
TL;DR: 3 quick checks often restore IPTV: "there is a limit on the number of devices." Validate your m3u on a PC, then test a stream in a browser; if it still fails, ask for MAC whitelisting. [Elektroda, przeqpiciel, post #18941454] Why it matters: This FAQ helps Smart TV users whose IPTV/m3u-MAC services suddenly show connection errors get working again fast.
How do I fix IPTV "Connecting failed" after coming back from holiday?
Start with account rules. Confirm your subscription’s device limit. Validate your m3u on a PC and open a stream in a browser. If the stream plays, the TV app is at fault. If it fails, ask the provider to refresh or whitelist your MAC. Test alternate apps to isolate the fault. [Elektroda, przeqpiciel, post #18941454]
How can I test if my m3u playlist is valid?
Do a quick playlist check from a computer.
  1. Open the m3u in a text editor and copy one full stream URL.
  2. Paste the URL into a web browser and try to play it.
  3. Capture any error code or playback success for support. Expert tip: "extract the link to the stream via notepad." [Elektroda, przeqpiciel, post #18941454]
What is a device limit and could it block me?
A device limit restricts how many devices can connect on one subscription. If you share credentials between TVs, one may be refused. Ask your provider to confirm your limit and reset active sessions. "there is a limit on the number of devices." [Elektroda, przeqpiciel, post #18941454]
Could my MAC address be banned, and how do I fix it?
A MAC block prevents your device from authenticating to the IPTV portal. It looks like valid playlists that never connect. Ask the seller or portal operator to check and remove any MAC ban. Provide your TV or app MAC exactly as shown. After unblocking, reboot the TV and retry. [Elektroda, sosarek, post #18941092]
IPTV works on my brother’s TV but not mine—why?
Your subscription may be tied to device identity. A MAC ban can block one device while others keep working. Ask the provider to verify the MAC status for your TV. If clear, test the same playlist on your TV with another app. This narrows the issue to the app or account. [Elektroda, sosarek, post #18941092]
How many playlists should I try before blaming my TV?
Rule out a bad list first. One poster tested 3 playlists from 2 sellers, yet the TV still failed. That points to account restrictions, MAC blocks, or app issues. After two or three working sources fail, investigate your device or account. Keep one known‑good list as a control. [Elektroda, Fala1989, post #18941087]
Could a Samsung app support change break IPTV on my model?
Yes. When a manufacturer ends app support, some services stop working on that model. Check your model’s support status on the vendor site and Smart Hub. "check whether the manufacturer has ended support." If support ended, use an external device or a different app. [Elektroda, sosarek, post #18941102]
My TV has internet, but IPTV still shows "Connecting failed". What next?
If general internet works, the IPTV playlist links may be blocked upstream. "Most likely the links contained in the m3u have been blocked." Ask the seller to refresh your access or provide a new portal. Confirm by opening one stream URL from the playlist on a PC. If it errors, the source is down or restricted. [Elektroda, sosarek, post #18941084]
What details should I provide when asking for help?
Share the service name, operator, and device model. Include TV brand and full model number. Provide the app name and whether you use m3u or a MAC portal. Add how you connect and any error messages. These details speed diagnosis. [Elektroda, sosarek, post #18940952]
Can I use VLC, Kodi, or Delta Media Player to check my playlist?
Yes. Testing with another app can isolate whether the list or TV app fails. As one expert noted, "install for example Delta Media Player" and test similarly in Kodi. If it works elsewhere, troubleshoot the TV app or firmware. If it fails everywhere, escalate to your provider. [Elektroda, sosarek, post #18941074]
Is IPTV reliable during big live events?
Not always. Congestion and source overload can cause instability during major events. As one user wrote, "like a bigger event the TV worked unstable." Use a backup for critical viewing. Keep an antenna or official app as fallback. [Elektroda, przeqpiciel, post #18941454]
What model info should I share for Samsung TVs?
Share the full model code, not just the series. Provide UE48H plus the full suffix from the label. That helps pinpoint platform year and app support. An incomplete model delays help. Capture it from the label or TV menus. [Elektroda, sosarek, post #18941127]
