Procedure to Determine Phone Number of Active, Unlocked PLUS Network Data SIM Card
Mareksdz 25185 6
  • #1 18943322
    Mareksdz
    Level 4  
    I have a sim card only with a data package, the card is in the PLUS network is active and unlocked.
    How can I check the phone number of this card?
  • #2 18943335
    badboy84
    Help: 1197
    Rate: 1484
    If you have a modem that provides this option, you can send yourself SMS, but they are paid. That's probably the easiest and fastest way.
  • #3 18943344
    gumisie
    Help: 1667
    Rate: 2480
    You can also insert the card into the phone and then:
    To check the phone number in Plus, enter the code *132#. Then press the green receiver or another button that is responsible for starting a call on our phone.
  • #4 18943586
    Mareksdz
    Level 4  
    I don't have a modem, I tried with *132# before and it says "Connection problem or invalid MMI code".
    I also have a normal Plus card and the message is the same. I tried on two phones.
  • #5 18943705
    gumisie
    Help: 1667
    Rate: 2480
    Therefore, your so-called "problem" I put into the phone, not used for a long time, but active Plus_a card, after entering the code: *132#, I received information about the number.
  • #6 18943914
    Mareksdz
    Level 4  
    If you want to be smart, you first need to know what you're talking about. For my cards this code does not work and will not work. Because I have my cards are on a subscription basis. After a long verification, I was given a number for the Plus hotline.
  • #7 18943938
    gumisie
    Help: 1667
    Rate: 2480
    And who's smart here?
    You create a topic, ask for help without informing that:
    Regards.
    EDIT:
    So what is the problem?
    Call and after the "problem".
✨ To determine the phone number of an active, unlocked PLUS network data SIM card, users can try inserting the SIM into a compatible phone and dialing *132#. However, some users have reported issues with this method, receiving messages indicating a "Connection problem or invalid MMI code." An alternative method involves using a modem that allows sending SMS, although this may incur charges. If these methods fail, contacting PLUS customer service for assistance is recommended.
