Xiaomi Mi Air 13 Component ID- Marble 17805-1 448.0CE07.0011: QA702, AD XA 14, AP2204K-ADJTRG1
fixitprohr 3822 3
  • #1 18963412
    fixitprohr
    Hi everyone,
    I have Xiaomi Mi Air 13
    Board number is: Marble 17805-1 448.0CE07.0011
    Problem is burned and missing component that I need to identify.. mark on the board is QA702
    QA701 looks same but I am not sure if it is (values), marking are AD XA 14
    Also 5pin component (maybe LDO) with GAF marked on top gets hot.. for this GAF I manage to find that it should be AP2204K-ADJTRG1 (maybe not, looks like GAF is general/factory marking)
    Can you guys help me out?
    Thnx
    Xiaomi Mi Air 13 Component ID- Marble 17805-1 448.0CE07.0011: QA702, AD XA 14, AP2204K-ADJTRG1 Xiaomi Mi Air 13 Component ID- Marble 17805-1 448.0CE07.0011: QA702, AD XA 14, AP2204K-ADJTRG1
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    Look for the datasheet and what you have on the board (pins)
    - LDO (Low Dropout) Linear Voltage Regulators, Adjustable Output,
    SOT23-5, code: GAF LDO stabilizer Adj (adjustable) 300mA RP170N381B Link
    SOT25-3, GAF, AP2204K-ADJTRG1 / * weaker current 150mA
    * Link
    * Link
    There you have kbc npce285pa0dx
    - i.e. after similar developments on this kbc, e.g. new Quanta TMMA / DATMAAMBAC0 rev.?
  • #3 19002737
    fixitprohr
    Thnx a lot for your help..
    will try to find schematic and find missing component..
    thnx again
  • #4 19869423
    alexxtechnik
    thnx again
    hi could you solve your problem? My Air 13" doesn't start too. No lights. And the parts you showed are getting hot
