elizabeth hi fi - problem z prawym kanałem eleizabeth hi fi
Michael_123 1740 6
  • #1 19020074
    Michael_123
    Mam problem z Elizą. Mianowicie prawy kanał przestał grać. Miałem przy sobie sprawną płytkę z końcówką mocy na GLM 026 wymieniłem i dalej to samo. Również sprawdziłem wtyczkę od słuchawek, ale jest sprawna. Czy może to być od zasilacza? Co może być powodem ??
  • #2 19022970
    aksakal
    Tube devices specialist
    Help: 1672
    Rate: 3011
    Check the supply voltage on legs 3 and 2 of both GML. Swap the wires at points 41 and 42 on the power amplifier board. This will help diagnose tips and PW.
  • #3 19032325
    Michael_123
    Why should I change wires at points 41 and 42?
  • #4 19032791
    tomaszcz
    Rate: 14
    I had a dirty input selection switch. My left channel was completely cut off.
  • #5 19037048
    aksakal
    Help: 1672
    Rate: 3011
    Replacing the wires in places will help to locate the location of the problem - PW or the terminal.
  • #6 19037369
    SlawekKedra
    Help: 1579
    Rate: 1970
    Michael_123 wrote:
    change
    Don't change, just swap places.
  • #7 19038466
    Michael_123
    potentiometer?
The user reports an issue with their Elizabeth Hi-Fi system, specifically that the right channel has stopped functioning. They have already replaced the power amplifier board with a known working GLM 026 and checked the headphone plug for faults. Suggestions from other users include checking the supply voltage on specific legs of the GML, swapping wires at points 41 and 42 on the power amplifier board to help diagnose the issue, and considering a dirty input selection switch as a potential cause. The discussion also touches on the importance of swapping rather than changing wires to locate the problem effectively.
