Marshall s80 ValveState 8240: Boost Channel Not Working, Low Output on Normal Channel
570 8
  • Check the tube and input jack contacts
    #1 21661762
    Alex Brackett
  • #2 21661763
    Boi Okken
  • #3 21661764
    David Figueroa
  • Recommend recapping, resoldering, and valve substitution
    #4 21661765
    Peter Owens
  • Poor connection may have opened a component or tube
    #5 21661766
    Jonny Death
  • #6 21661767
    Mark Harrington
  • #7 21661768
    Rich Diemer
  • Start with tube swap before circuit testing
    #8 21661769
    Jonny Death
  • Need proper bias checks before replacing valves
    #9 21661770
    Mark Harrington
A Marshall S80 ValveState 8240 amplifier with 2x12" Celestion speakers exhibits a non-functional Boost channel and significantly reduced output (~20%) on the Normal and Master channels. Initial symptoms included sporadic popping and crackling noises linked to a poorly seated three-prong power cord connection. Internally, the chassis appears clean with no visible damage to capacitors, resistors, or solder joints. Common diagnostic suggestions include inspecting and replacing electrolytic capacitors due to age-related failure, checking for dry or cracked solder joints, and verifying resistor values. Replacing the 12AX7 valve, which is used exclusively in the Boost channel, is recommended as a low-cost initial step. Further troubleshooting involves voltage measurements, signal injection, and oscilloscope analysis to identify faults such as open circuits or output transformer issues. Proper grid bias settings for output valves (EL34) should be confirmed to avoid damage and fuse blowing. If these steps fail, professional servicing is advised. A schematic is available to assist in detailed diagnostics.
