Galaxy S8+: Issues with External Loudspeaker Crackling During Calls in Warm Weather
Mik99 10191 6
  • Loose housing near speaker causing crackling in heat
    #1 16540294
    Mik99
    Rate: 34
    Welcome
    I did not enjoy my phone for a long time. I have a problem with the external loudspeaker and this for conversations. When the heat is loud, the loudspeaker cracks and the same happens when talking on the loudspeaker. The problem does not always occur but only when it is warm outside. I noticed that I have empty space in the housing on the side of the external speaker (near the USB port).
    When I close this place, the casing clicks and resonates so that the voice in the speakers is very quiet and "chrubotanie" appears. Later I will post a video of what it looks like. I wonder one thing if the housing seems to be not fully glued to what effect it has on the sound, since all the elements are screwed to the cover.
    Have any of you already had a problem with the loudspeaker and replaced the phone with a new one? I do not want to play service and warranty repair.
    I have S8 at home and everything is fine. Both phones bought at the Brand Store Warsaw.
  • #2 16540439
    nutergsm
    Help: 1034
    Rate: 1665
    In that case, what do you expect? Do you want to repair yourself and lose your guarantee yourself?
    Take advantage of the guarantee better.
  • Housing tightness and resonance as possible cause
    #3 16540528
    Mik99
    Rate: 34
    I would like to get a new phone and here I will probably fight the shop. Assuming this topic, I hope that maybe something can be done using home methods, since, for example, the housing is not well glued, maybe it can be done. The second thing I'm interested in is the relationship of tightening the housing with improving the sound and falling into resonance.
  • #4 16540642
    E8600
    Help: 529
    Rate: 2520
    You can only lose the guarantee in a homemade way. You do not do much because of what you know, first the phone must undergo two attempts to repair and only three times they exchange the phone.
  • #5 16540761
    nutergsm
    Help: 1034
    Rate: 1665
    And not always.
  • #6 16540770
    Mik99
    Rate: 34
    I can use the SWAP program because I have a GUARD or a shop warranty, but how do I come across a red LCD lenghth? My S8 + and brother S8 has perfectly white screens, but mine is suffering from another case.
    I was thinking of a home-made way to warm the back of the dryer and press it. Yes, I did, but after this procedure the loudspeaker did not work at all. When the phone cooled down, the old problem returned so something obviously does not connect only the question, what? Do you, dear servicers, have already dismantled S8 because what is the problem with my problem if there is a gap in fitting the housing? This is a mystery to me now.
  • #7 16540787
    E8600
    Help: 529
    Rate: 2520
The discussion revolves around issues with the external loudspeaker of the Samsung Galaxy S8+ during calls in warm weather, where users experience crackling sounds. The original poster notes a gap in the housing near the USB port, which may contribute to the sound issues. They express a desire to avoid warranty repairs and explore DIY solutions, such as tightening the housing. Other participants advise against self-repair due to potential warranty loss and suggest utilizing the warranty service instead. The poster also mentions a failed attempt to fix the issue using heat, which temporarily worsened the loudspeaker's functionality.
