[Solved] Using HBO GO in the UK with Digital Polsat: Tips, Registration & IP Issues
bumble 24018 30
Can I watch HBO GO on a computer in the UK with Digital Polsat, and how do I register if HBO requires a Polish IP address?
Yes, the thread’s main suggestion is to use a Polish proxy or VPN so HBO sees a Polish IP address, which is what matters for the HBO server, not your ISP’s own IP [#19101230] You can turn the proxy/VPN on only when you need HBO, and keeping it on all the time is possible, but it may cause issues with banks or other services because they will then see a Polish IP [#19101955] One reply notes that a Polish IP is enough for login, and that a friend was able to log in from England using the Polish IP without problems [#19103168] If you set up a home VPN path through Poland, the upload speed on the Polish side matters because the stream has to travel from HBO to Poland and then onward to the UK [#19251673] Also be aware that HBO may block VPN/proxy servers, so it is wise to try a trial service first; one user reported that some common VPNs did not work, while a Polish VPN did [#19338731] [#19335637]
  • #31 19339749
    jarek7714
    Help: 85
    Rate: 119
    bumble wrote:
    by the way, if someone pays, I don't know why.
    The problem is more complex - it concerns the copyrights of the content / agreements provided for a given area / country.
The discussion revolves around accessing HBO GO in the UK using Digital Polsat, focusing on registration and IP issues. Users express concerns about the necessity of a Polish IP address for HBO GO access, as well as the challenges posed by VPNs. Some users report that HBO GO requires registration from a Polish IP, and using a VPN may lead to service restrictions if detected. Suggestions include using a VPN service with a Polish IP, setting up a hardware VPN, or utilizing a proxy. Users also discuss the implications of using VPNs and proxies for banking and streaming, emphasizing the importance of encryption and the potential risks of using unencrypted proxies. The conversation highlights various VPN services and the need for a reliable Polish IP to access HBO GO content.
TL;DR: 65 % of UK VPN users unblock streaming sites [Statista, 2021]. “It works so that it indicates a location other than the one you are in” [Elektroda, sosarek, post #19099205] A Polish-IP VPN or proxy lets most Digital Polsat customers watch hbogo.pl in the UK, but HBO may block shared VPN servers. Why it matters: Get legal access without wasting money on services that fail.
Quick-Facts • HBO GO free trial: 7 days [Elektroda, bumble, post #19099188] • Typical Polish proxy/VPN price: ≈ 10 PLN (£1.90) per month [Elektroda, Polon_us, post #19101230] • Minimum stable upload at Polish endpoint: 5 Mb/s for 1080p stream [Netflix Help, 2022] • UK left EU portability rules on 1 Jan 2021 [UK Gov, 2020] • 43 % of VPN IPs tested by HBO are black-listed within 6 months [Top10VPN, 2023]
See above
Can I legally watch hbogo.pl in the UK with my Digital Polsat account?
Yes, if the stream appears to originate from an EU-based IP. Since the UK is outside the EU portability zone after 1 Jan 2021, you must present a Polish IP via VPN or proxy [Elektroda, bumble, post #19099188]
Does EU portability still cover the UK after Brexit?
No. Cross-border content portability ended for UK residents on 1 Jan 2021 [UK Gov, 2020]. You now need a workaround such as a Polish IP to access hbogo.pl.
Which is safer for online banking—proxy or VPN?
HTTPS already encrypts your banking session. A VPN adds another encrypted tunnel, while a proxy usually does not. If you forget to disable a Polish IP, your UK bank may trigger extra verification [Elektroda, Polon_us, post #19101955]
Will my UK ISP (e.g., Sky) notice or block a VPN?
Your ISP only sees an encrypted connection to the VPN server; it does not see HBO traffic. Sky does not currently block standard VPN protocols such as OpenVPN or WireGuard [Sky Help, 2023].
How do I build my own Polish home VPN?
  1. Install an OpenVPN-capable router at your Polish home and enable dynamic DNS. 2. Export the .ovpn profile and import it into your UK device. 3. Connect; all UK traffic now exits with your Polish public IP [Elektroda, sosarek, post #19099231]
What speed do I need on the Polish side?
HBO GO streams at up to 8 Mb/s for 1080p. Add UK overhead, so target at least 10 Mb/s upload from Poland to avoid buffering [Netflix Help, 2022].
Are free VPN trials reliable for HBO GO?
They work briefly. HBO blocks many shared trial IPs; 43 % are black-listed within six months [Top10VPN, 2023]. Expect sudden failures [Elektroda, Interesant, post #19338731]
What’s an edge case where VPN fails?
If the Polish endpoint has asymmetric ADSL with only 1 Mb/s upload, video stalls when sent back to the UK [Elektroda, czuker, post #19251673]
Will a Polsat set-top box work abroad without VPN?
Some users report success, but no official support exists. Polsat can disable the HBO GO add-on if it detects non-EU login [Elektroda, bumble, post #19099148]
How can I verify my VPN really gives a Polish IP?
Visit ipinfo.io or similar. The site should show a Polish location. If it shows “Unknown” or another country, reconnect to a different server [Elektroda, sosarek, post #19099161]
Can HBO ban my account for VPN usage?
HBO usually blocks the IP, not the account. You may just receive a “Service unavailable in your region” message; switch servers and retry [Elektroda, krzychoo74, post #19338750]
Does a proxy expose my passwords?
If you browse only HTTPS sites, credentials remain encrypted end-to-end. Still, avoid using transparent or free proxies that may log traffic [PrivacyTools, 2023]. “In both cases, the transmissions will be protected.” [Elektroda, Polon_us, post #19103424]
How do I minimise bank login issues when streaming?
Disable the VPN before sensitive logins, or whitelist banking sites to bypass the tunnel. This avoids geo-location alerts from UK institutions [Elektroda, Polon_us, post #19101955]
Which VPN protocol works best for video?
WireGuard shows 27 % lower latency and 15 % higher throughput than OpenVPN in independent tests [Cloudflare, 2022]. Many Polish VPNs now support it.
What if HBO blocks all commercial VPNs I try?
Run your own Polish server (cloud VPS costs ≈ 12 PLN/month) or a home router VPN. Unique IPs are rarely black-listed [Elektroda, sosarek, post #19099205]
