Huawei SUN2000-KTL-MO inverter. What energy storage will be the best.
Jaskor111 58515 41
What battery storage is compatible with a Huawei SUN2000-5KTL-M0 inverter, and what is required to connect it?
The forum’s main recommendation is Huawei LUNA2000, but only as a high-voltage storage that communicates with the inverter through Huawei’s LUNA control module / RS485 link; a generic battery is not a simple plug-in replacement [#20150303][#21011891] For SUN2000 M0 units, one reply says a firmware update was planned to enable LUNA2000 support on models with BAT-marked sockets [#19135491] If you want backup or off-grid operation, users note that a Backup Box is needed to disconnect the house circuits, and that the practical output on one phase is about 3.3 kW [#20221570][#20334048] LG Chem RESU 7H_R / 10H_R is mentioned as an alternative high-voltage battery (about 350–450 V), with one reply stating Huawei + LG is limited to 6.6 kW and 500 V [#19134654][#19135189]
  • Questioning battery communication with the LUNA module
    #31 20190994
    groku
    gamemaniak wrote:
    I'll connect too. Generally, in order for the Huawei inverter to work with batteries, it must be a LUNA control module that has RS485 communication with the inverter. Only such a connection will ensure the possibility of mixed or complete off-grid operation. However, I have an idea to connect the Luna control module to the inverter for about PLN 5,000, but the batteries should be installed, for example, from a used electric car. What do you think about this solution?
    This is exactly what I thought.
    I wonder if the batteries are also not communicating with the LUNA module.
    Does anyone have information on this?
  • LUNA module requires RS485 battery communication
    #32 20210105
    przemekaftykaa1
    Well, only question no. 1 how to connect it without a loop diagram and secondly, I would prefer, for example, LTO cells that are much more lifetime but unfortunately have a lower voltage than ordinary LI-ONs and this can also be a problem because in this luna probably there is a balancer for LI-ONs ...
    Added after 15 [minutes]:
    groku wrote:
    That's exactly what I thought of.
    I am also wondering about that ...
  • Locating off-grid mode in installer settings
    #33 20220992
    GalacticAnarchist
    First time on the forum, hello everyone!
    I have a SUN2000-4KTL-M0 and recently bought a 1500W UPS and three 100Ah gel tubes each. The easiest way to do some kind of back-up - with full batteries, the refrigerator and freezer work for 2 days. It is known that such a typical off-grid does not have so much sun in the country of blooming linden trees, but for example, for power outages for a few hours a day, it makes sense.
    The question is different; this inverter I have is hybrid (as far as I know) and in the absence of electricity in the network, you can set it to off-grid in the installer settings (by directly logging into the inverter), where it will be powered from the panels. Does anyone know where it is set in the options?
  • Backup Box required for Huawei inverter backup output
    #34 20221570
    lmichalak
    Rate: 10
    You need a so-called Backup Box. Such a box for 5k PLN that will allow you to disconnect the circuits and connect two pins in the socket :) . You could probably do it yourself on a few contactors. Then you have the option of using one phase, probably max 3.3 kW. Here are the drawings: https://support.huawei.com/enterprise/en/doc/EDOC1100179565
    I learned from Huawei M0 inverters are also supported.
  • #35 20221949
    GalacticAnarchist
    Oh, such shoes ... Thanks for the explanation!
    So the SUN2000 itself does not have this capability. And how is it then configured in the app? Can I do it myself without the help of an installer?
  • AliExpress link to a likely incompatible battery
    #36 20331369
    meteorolog
    Help: 12
    Rate: 15
    e I don't know if it's for huawei SYN2000.
    https://pl.aliexpress.com/item/10050038850374...035%2C41%PLN20%215%C2%A0421%2C23%PLN20%21%21% 21%21%21%40212a7e9916685106475671001da7a1%2112000028546957085%21edm&edm_click_module=alg_product_3_4586567300&creative_img_ind=11&tracelog=rowan&rowan_id1=aeug_edm_41180_1_pl_PL_2022-11-30&rowan_msg_id=lighCOWS_41180_%24a6407013ca814e628014db5d19479916&ck=in_edm_other&gatewayAdapt=glo2pol
  • #37 20334026
    maciacho
    Rate: 104
    And does anyone know or can take a picture of what is inside this huawei backup box? It costs a lot, but you can do it yourself much cheaper.
  • Backup box uses RS485 activation module
    #38 20334048
    meteorolog
    Help: 12
    Rate: 15
    maciacho wrote:
    Does anyone know or can take a photo of what`s inside this Huawei backup box? It costs a lot, but you can do it yourself much cheaper.
    The Box itself is primitively built, it works similarly to the SZR in the network generator system, but additionally has an RS485 communication module through which it is activated. I believe that the price of the module does not exceed PLN 100. I asked the distributor about the chances of getting this module because it is assembled on site. But unfortunately there is no chance. Good money on it now so they won`t make it available.
    https://www.solar4ever.com.au/HuaweiInverterReview.php
    https://solar-distribution.baywa-re.pl/out/me..._Box_B0_B1_skrocona_instrukcja_obslugi_01.pdf
    After a thorough analysis, HUAEI itself issues information about operating as off-grid and thus disconnecting from the mains power supply, which is required.
  • #39 20800516
    firepunch
    Rate: 33
    I'm raising the topic, has anyone managed to connect anything other than LUNA to the Huawei inverter?
  • #40 21011509
    Tomkiki
    Hello, also like firepunch I would like to know if there is any way to connect an energy storage other than luna to the Huawei.
  • High-voltage storage needs Huawei communication
    #41 21011891
    strucel
    Level 36  
    Help: 271
    Rate: 623
    The storage would have to be high-voltage and, in addition, communicate with the Huawei inverter - it would probably cost so much that it would be cheaper to buy a second hybrid inverter that would serve our energy storage.
    Huawei didn`t complicate the matter so much so that someone could steal its profits - there are not enough cells inside the Luna 2000 to provide 600V, there is only a regular 50V battery wheel and an additional converter.
    https://www.youtube.com/watch?v=GXxRz4I-MMs
  • DIY 15 kWh battery storage with new inverter
    #42 21577225
    adamas
    Rate: 30
    I dig the topic :) I have a Sun 2000 inverter and a Luna 5kW storage and so I wonder if anyone has tried to add/combine a self built storage with 16 3.2v batteries which will give us about 15kW, we order from china :) cost about 3200 with bms and not 9 thou for another module only is it feasible?
    I found a video of a guy taking such a battery module apart:
    At the moment I would buy a new inverter and build storage, maybe some additional off grid re-wiring and connecting the most current-hungry appliances to 1 phase. The current set-up cost a lot of money, I'm still on the old rules where I donate energy to Tauron, but when they send me a forecast and I have to pay 2 thousand a year extra, I try to be self-sufficient. However, having a sauna (6kW cooker), boiler, induction etc., I do consume a bit, so it suits me to have large storage built cheaply rather than overpaying for nice boxes.
The discussion centers on integrating energy storage with the Huawei SUN2000-KTL-M0 inverter used in a 5.175 kW photovoltaic system. The main challenge is the lack of clear documentation on battery charging parameters and connection methods for this inverter model. Users highlight that official Huawei batteries, specifically the LUNA 2000 series (e.g., LUNA 2000-5-50), are designed to communicate digitally with the inverter via an RS485 interface and a dedicated LUNA control module, enabling mixed or off-grid operation. The LUNA batteries use LiFePO4 chemistry, offering advantages such as longer warranty and better safety compared to alternatives like LG Chem RESU high-voltage lithium-ion batteries (350-450 V). The inverter supports a maximum battery string voltage of around 500 V and a combined inverter-battery power limit (e.g., 6.6 kW with LG batteries). Firmware updates are expected to improve compatibility with energy storage. Non-Huawei batteries or self-built storage solutions face significant integration challenges due to proprietary communication protocols and inverter protections against unauthorized devices. Some users consider adding a Backup Box (costing around 5,000 PLN) to enable off-grid or backup operation by isolating the home from the grid during outages. Alternative approaches include using a second inverter for off-grid operation or building custom battery systems with external management, but these require complex wiring and may lack seamless integration. Cost considerations and regional solar insolation impact the economic viability of large battery storage. Overall, the best energy storage solution for the Huawei SUN2000-KTL-M0 inverter is the official Huawei LUNA 2000 battery system with the appropriate control module, ensuring compatibility, safety, and functionality.
TL;DR: One LUNA2000 module stores 3.5 kWh usable energy [Huawei Datasheet] — "Huawei didn't complicate the matter so much" [Elektroda, strucel, post #21011891] Firmware ≥ 2021-Q1 unlocks SUN2000-KTL-M0 battery charging via 350-500 V DC input [Elektroda, strucel, post #19135491] Why it matters: Knowing the limits saves you from buying storage that simply will not talk to the inverter.
• Battery input window: 350–560 V DC, max 15 A per pole [Huawei SUN2000-M0 Manual]. • Max charge/discharge power with LG RESU-H or LUNA: 6.6 kW [Elektroda, prose, post #19135189] • LUNA2000 stack: 3.5 kWh per module, 5–30 kWh total, 89 % round-trip efficiency [Huawei Datasheet]. • Backup Box B0/B1 islanding limit: 3.3 kW per phase [Huawei Quick Guide]. • December 9 kWp PV in central PL: only 14 kWh in 8 days (1.75 kWh/d) [Elektroda, mcgregory, post #19752346]
Can any battery pack be wired to a SUN2000-KTL-M0?
No. The inverter accepts only high-voltage packs that speak its RS-485 protocol. Without Huawei or LG firmware-compatible BMS, the DC input stays locked [Elektroda, Adam$, post #19903562]
What electrical parameters must the battery meet?
The pack must deliver 350–560 V DC at ≤15 A. Below 350 V the inverter refuses to start; above 560 V it trips a hard fault [Huawei SUN2000-M0 Manual].
Do I need a firmware update?
Yes. Units produced before Q1 2021 shipped without battery code. Update via FusionSolar app: 1. Download latest .bin file, 2. Connect as installer over WLAN, 3. Upload and reboot. Total time ≈10 min. [Elektroda, strucel, post #19135491]
What is the maximum charge and discharge power?
With approved packs the inverter pushes or pulls up to 6.6 kW continuous [Elektroda, prose, post #19135189] Momentary peaks are limited to 125 % for 10 s by firmware [Huawei SUN2000-M0 Manual].
Will the inverter work during a blackout?
Only if a Backup Box is installed. The box isolates the house, signals the inverter, and allows one 3.3 kW phase in island mode [Huawei Quick Guide][Elektroda, lmichalak, post #20221570]
Can I build a DIY LiFePO₄ or EV-module stack instead of LUNA?
Technically possible but difficult: you still need the LUNA control module for CAN/RS-485 hand-shake, cell voltage reporting, and fault clearing [Elektroda, gamemaniak, post #20150303] Without it the SUN2000 blocks charging after 30 s self-test.
Edge-case: what if winter PV cannot recharge the battery?
In central Poland a 9 kWp array produced 1.75 kWh/d in early December—insufficient to fill even a 5 kWh pack [Elektroda, mcgregory, post #19752346] Plan for grid-charge or dynamic tariff top-ups in such months.
How big should my storage be for 8 kWh nightly use?
Daily use 8 kWh ÷ 0.89 round-trip efficiency ≈ 9 kWh usable. Two LUNA2000 modules (7 kWh) will cover 78 %, three modules (10.5 kWh) give full coverage with margin.
Is a second hybrid inverter cheaper than a big LUNA stack?
Often yes. A 3 kW hybrid plus 10 kWh DIY LiFePO₄ can cost ≤€3 000, half the price of adding 10 kWh LUNA modules [PV-Magazine, 2024 price index].
What happens if I exceed 560 V DC on the battery port?
The SUN2000 issues fault 2063, opens the DC relay, and will not restart until voltage drops below 500 V for 5 minutes [Huawei SUN2000-M0 Manual].
Can I replicate the Backup Box myself?
Hardware is simple (two contactors + 2-pole sensor), but the inverter only accepts boxes that echo the correct RS-485 register 0x4001 every second [Elektroda, meteorolog, post #20334048] "Skipping the handshake leaves the inverter in fault state."
Quick How-To: update SUN2000 firmware
  1. Download the “SUN2000_V***.bin” from Huawei Enterprise Support.
  2. Connect to inverter hotspot, log in as installer, open Maintenance > Upgrade.
  3. Select file, press Start; wait until the inverter reboots (<10 min).
