Energy storage 18650 up to 24kWh class Paragon, Powerwall
remzibi 22473 156
  • Home on laptop batteries 🙂 .
    DIY energy storage system from 18650 cells
    Usability testing of the eperimental-experimental 48V energy storage on 18650 cells completed.
    As an answer to the eternal question "what else would you build ?", I built a "Paragon" class energy storage inspired by Leszek Kwitek https://www.youtube.com/watch?v=7a0CGuDVCBo.
    After 3 months of testing with half of the capacity filled (estimated actual capacity at the moment around 12kWh, once full it will be over 24kWh), the whole thing works sensationally 🙂 .
    All 18650 cells recycled. The storage after charging easily keeps the house for the next 2 cloudy days when the installation does not yield, if there are bright clouds then longer. With heavy use such as cooking dinner (induction cooker), teas, coffees, hoovering, hairdryer, my workshop work etc, the "holding" time is about 36 hours, after which it will switch to grid i.e. grid or sunshine comes out 🙂 .
    I make no secret of the fact that this is a job for the patient, the persistent and those with a clue. A time-consuming and labour-intensive challenge is the very process of recovering, selecting and testing 18650 cells, a separate elaboration could be written about this process.
    The cells were welded with a DIY welder assembled "on the cheap" from a microwave transformer with a universal controller, the construction of which I have described here https://www.elektroda.pl/rtvforum/topic4053341.html.
    The welding and printing hoof I designed can be downloaded here https://www.thingiverse.com/thing:6808297
    The storage works with a 5.5kW hybrid inverter and 4.7kW panels mounted vertically (an idea that works brilliantly), for the best yield in the autumn/winter/spring months when energy demand is greatest (including for reheating the house).
    In summary, this form of storage is very convenient for utility and service purposes (adding cells online, without shutting down), the temperature culture of operation is excellent, the current carrying capacity is seamless, where per cell the currents are in the order of 250-350mA, which will hopefully ensure a long life.
    Technikalia :
    - 14S , 48V , 40 strings x 6 cells (target)
    - Cell test : tested with LiitoKala Lii-500 chargers, they perform well in this regard
    - BMS: JK BMS 20S balancer 1A, very good device, I recommend, 1A can handle balancing without any problem
    - string batteries are selected and connected together with regard to capacity and internal resistance
    - fuses: 4A but I would now use 5-6A
    - operating thresholds of the cells: lower 3.3V , upper 4.13V, so with a margin (the settings take into account the inverter measurement error offset)
    - the middle 8 strings at the terminals have 8A fuses (2x4A) and the best cells are there
    - cyclic thermal imaging control, any anomalies are seen immediately but nothing happens
    - cost-wise: an unbeatable revelation 🙂
    - The welding and printing holder I designed is downloadable from thingiverse .
    I attach a couple of photos from construction and testing
    Energy storage system built from 18650 cells. Stacks of 18650 cells arranged on a table, prepared for building an energy storage system. Array of empty battery cell holders on a table fa7a1293
    The image shows battery modules on a foam substrate. Experimental energy storage made from 18650 cells mounted on a wall. .
    App screen monitoring energy storage with cell charge levels. Thermal image of an energy storage with 18650 cells Thermal image showing the temperature distribution of 18650 cells. Thermal image of an energy storage system based on 18650 cells. .
    EDIT
    I'm uploading additional descriptions from the Facebook discussion
    Question: Let us know what condition the cells you still need should be in - could they be used but still working, or could they already be old, weak, and you are somehow remanufacturing them?
    Answer: Cells should not be badly corroded (there are ways to get slightly corroded cells 🙂 ), besides, their condition before testing is irrelevant, they can be discharged to 0V, the initial condition is completely irrelevant to the quality of the cell and its wear - this will only become apparent after testing. Testing is the whole procedure to check the internal CID fuse, if the cell is completely discharged then "raise" it by 50-100mA to the catalogue threshold and after that charge with temperature control, discharge with temperature control, charge by 700mA with temperature control, measure the internal resistance, let it rest for about a month and measure again to assess possible self-discharge problems. If the cell passes all this procedure, it is suitable for storage 🙂 . If the cell has a damaged insulating sleeve then it is repackaged in new "clothing". And if it has some minor imperfections, then it is suitable for LED torches 🙂 .
    Experience shows that laptop cells have a lot of rejects and a large range of parameters (but it is possible to squeeze something out of them), and the best for recovery are damaged packs from e-bikes, scooters, boards, etc.
    Question: You have 5 batteries combined into one pack. My question is what happens if one battery out of these 5 makes a short circuit?
    Answer: This string with the 5'ohm already has a 6'ste cell added to it just like the rest of the strings, there are 6 everywhere. A short circuit doesn't happen so it doesn't and it's there, but if it does, it's a slow process and the cell will slowly get warmer than the others, which you can see right away on the thermal imaging camera, giving you a ton of time to replace it. But assuming it suddenly short-circuits, it will trip the CID fuse that is in each cell. Assuming the CID doesn't work it will discharge the other cells in the pack and of course my fuse put on the pack will work. Same if corrosion occurs and the electrolyte leaks/leaks. So much.
    BTW I've taken apart thousands of cells and unpacked hundreds of packs, and I've seen them in various states, rusted to the core, overflowing, falling apart, with beaten CID fuses (sometimes a whole pack of 50 or so cells had their CIDs beaten and went to waste), discharged to 0V etc. but I've never, I repeat NEVER found a cell that was short-circuited or short-circuited, nor any burnt out. That's basically as much of a quandary as what happens if it gets a short circuit 🙂 basically from a purely practical point of view it's the same dilemma as - what if granny had a moustache would she be a grandpa 🙂 and that's why I consider 18650 cells to be very safe.
    Comment from FB:
    Comments by "łolabogaspalisiejakkamiennaawPoznan" for 3.... 2... 1...
    Hehe good :) , a rash of "trolls" "pyromaniacs" "firefighters" frothing and bludgeoning endlessly, on such a topic is inevitable :) .
    Diagram of the warehouse, connection to the BMS
    Wiring diagram for 14S BMS and energy storage connection. .
    Update 05.2025
    For over a month now, the storage has completely paid for itself, so after a full financial 'blip', everything is now going to the upside. Current capacity around 20kWh.
    As befits an experimental storage facility - the experiment continues - and continues to run :) .
    Next information , sometime in March I noticed that some of the cell sockets from one batch started to crack after a while, so within two weeks (fortunately these were weeks of total sunlessness) the storage was rebuilt to mechanically prevent this kind of fault in the future. The cracked sockets were replaced. The sockets which have the print on them are OK and nothing happens to them, but the ones from the Chinese supplier which do not have such prints and numbers - have started to break, so I LOSE to the quality of some Chinese stuff.
    Below are pics of how they break down and how I rebuilt the stock (disassembly/disassembly was one afternoon - I was surprised myself at how quickly something can be taken apart :) ).
    Close-up of a damaged plastic battery holder for cylindrical cells, visible crack on the left side. Close-up of a cracked battery holder slot in a plastic cell holder. .
    Wooden energy storage frame with rows of black plastic battery holders, two white containers with additional connectors on the surface. Rows of black battery cells connected with copper busbars, arranged on a wooden background. .
    By the way, I am throwing in an example of a cell caught during a periodic thermal imaging inspection, a point of higher temperature by 3 degrees relative to the background, a cell that got a slight leak (after removing the tee shirt, I found a tiny electrolyte leak, a droplet). There was still a long way to go before such a cell was destroyed, maybe 3-6 months, but the thermal imaging had already caught the "dude" early enough - the cell was of course replaced immediately (without shutting down the storage), service-wise the design works.
    Here the thought really comes to mind that if the factory packs were not sealed and people/users were able to check with thermal imaging, the number of different "accidents" could be significantly reduced.
    Thermal image of a battery cell with a local temperature rise up to 25.5°C against a background of about 23°C. Thermal image of a single cell showing a hot spot with a temperature of 21.8°C.
    remzibi
    remzibi wrote 1394 posts with rating 889, helped 34 times. Live in city Rumia. Been with us since 2002 year.
  • Concern about fire risk in 18650 home storage
    #2 21276302
    gulson
    System Administrator
    Help: 150
    Rate: 6145
    Revelation, we have it all:
    - recovery of old cells
    - free energy
    - independence
    - ecology
    This is the trend, so my advice is to slowly get used to energy storage in homes and even flats.
    They will simply force us to do so with further increases.
    It is even possible that we will have storage facilities without having to install panels, just to take energy when prices are negative and use it in the evenings.
    We will install such installations for ourselves. All the energy production will go to EjAja (AI) anyway and not for Kowalski to warm his tea.
    AI will pay well for every kWh and the poor Kowalski will not.
    That's how they got us...
    But we have to cope and very well you do.
    Just out of curiosity, aren't you afraid of some kind of fire? All in all 18650s are very safe, but it always comes to my mind like that.
    I'll send something small from myself, thanks again for the presentation!
  • Combustible mounting and touch protection concerns
    #3 21276340
    BANANvanDYK
    Help: 1169
    Rate: 2611
    gulson wrote:
    I advise slowly getting used to energy storage in homes and even flats.
    Rather not in flats.
    After a fire in an apartment building in Poznan, critical voices were raised:
    - Is it safe to charge battery-powered devices in flats (houses/multi-family blocks).
    - Whether it is safe to store batteries in basements of houses, along with other rubbish.
    - Can lithium-ion batteries be accessed in lifts?
    Regarding the topic. I note that the whole thing is mounted on a combustible surface (chipboard). The whole thing should be protected from touch. Ideally, it should be protected from unauthorised persons, especially those who are too curious, as they may kindly report.
  • #4 21276360
    gulson
    Help: 150
    Rate: 6145
    For now, these are voices, there is no legislation.
    And the trend will continue.
    Anyway.... let there be cheap energy, then no one will entertain such things.
    "Electricity is ubiquitous in unlimited quantities and can power the machinery of the world without the need for coal, gas or other fuels."
    Nikola Tesla.
  • BMS, balancers and CC/CV charging for safe 18650 storage
    #5 21276390
    remzibi
    Help: 34
    Rate: 889
    - free energy
    - independence
    - ecology
    This is the trend, .....
    This is how they got us...
    Just out of curiosity, aren't you afraid of some kind of fire? All in all, 18650s are very safe, but it always comes over my head like that........
    Thanks for the good word :) .
    - Through recovery, the cost of acquisition is acceptable.
    - The government (everyone) hates people having something for nothing, there are already plans to tax even garden gnomes - such a luxury :) .
    - Independence is very important, especially when potentially some rocket could fall on a nearby switchyard.
    - Yes, it's ecological that these cells don't go into the rubbish but will still serve, BTW the ones I discard are disposed of as needed and don't go to landfill.
    I am not afraid of Li-Ion18650 cells they are extremely safe, especially with the ability to check with thermal imaging at any time, but I am afraid of Li-Pol'i (I have experience from modelling) that is why I would not do it on Li-Pol's.
    I have been using recycled 18650 for over 20 years, for various applications and devices. The prerequisite is cell control, i.e. BMS, balancers and correct CC/CV chargers.
    Problems arise precisely from lack of control, closed cases, overloads, overheating, sensor failures, bad or failing chargers, etc.
    This storage unit just happens to be in such a concrete room under the (concrete) stairs.
    In general, if one is afraid, I recommend not having a storage facility, taking electricity from the power station and that's it :) .
  • #6 21276391
    jajacek44
    Help: 77
    Rate: 172
    The late Nicola was both a genius and a moron or technical moron .
    For example, he connected himself to the earth by blowing up a power station (there were no fuses yet)
  • #7 21276398
    sq3evp
    Help: 226
    Rate: 902
    Someone has finally made a magazine a'la "Paragon".
    Nikola was a non-secure-for-business visionary - if there was free unlimited energy then there would be redundant politicians :)
  • Request for source on Tesla grounding incident
    #8 21276460
    Frog_Qmak
    Help: 7
    Rate: 298
    remzibi wrote:
    I am not afraid of Li-Ion18650 cells they are extremely safe, especially with the ability to control with thermal imaging at any time, but I am afraid of Li-Pol'i (I have experience from modelling) therefore on Li-Pol's I would not do it.
    Can you elaborate ? Li-Pol-e is easier to damage mechanically, but it is not a problem here. Is it about the higher short circuit current for model cells ?
    For example he connected to the earth by blowing up a power station (no fuses yet)
    Can you please provide more on this topic/link?
  • #9 21276466
    sq3evp
    Help: 226
    Rate: 902
    Frog_Qmak wrote:
    jajacek44 wrote:
    (...)For example, it connected to the ground by blowing up a power station (no fuses yet)
    First time I've heard that it has merged with the earth - will you elaborate on what you are talking about? I'm curious too...
  • #10 21276477
    chemik_16
    Help: 75
    Rate: 129
    only you still need to have a source for such cells :)
  • #11 21276487
    jajacek44
    Help: 77
    Rate: 172
    His Lordship, not fully enlightened, tried to transmit through the soil (he forgot the granite (not very funny )
    Added after 7 [minutes]:
    To @sq3evp it just shook the surrounding buildings as it blew up the power station .
  • Questioning source and feasibility of integrated F-35 systems
    #12 21276540
    sq3evp
    Help: 226
    Rate: 902
    Any source link? We'll have a read... I've read a lot about Tesla, but couldn't find this anywhere.
    The idea of energy transfer was very interesting - it's not possible, but maybe nobody has figured out how to do it.
    Time will tell...
    Today there is a device fitted to the F-35 aircraft which is a radar, communications antenna, transmitter for the Self-Enemy system etc. It is inconceivable that so many systems can be integrated into one system. A Class 5 aircraft and leaves behind a very small EM footprint.
  • #13 21276545
    siwy_dym
    I once used such a cage for a screwdriver and it melted and the cells weren't even high current :/ Aren't you afraid that it might flow off the wall for you one day?
  • Li-pol cells degrade faster than li-ion in storage
    #14 21276567
    remzibi
    Help: 34
    Rate: 889
    Frog_Qmak wrote:
    Can you elaborate ? Li-Pol-e is easier to damage mechanically, but it's not a problem here. Is it about the higher short circuit current for model cells?
    Yes, Li-Pol's are easily damaged mechanically, that's one thing.
    But their biggest disadvantage, which is also from my experience, is very fast chemical degeneration and problems precisely with overheating and ignition, and this despite proper charging/discharging, BMS and not overcharging. Already after a year to two or so such a li-pol is to be thrown away because it has lost capacity. I do not want to generalise, because sometimes a Li-Pol will work long and normally, but, unfortunately, various manufacturers make these cells very unevenly in terms of the degradation parameter in time, and most of these cells are of little use after a year.
    It is different with Li-Ion, I have cells in various devices even 15 years old, which still work great, there are of course cells that also die over time (usually due to poor working conditions, overloading, excessive discharge below the acceptable threshold, etc.), but in general they are 100 times more resistant and reliable than Li-Pol.
    chemik_16 wrote:
    only you still need to have a source of such cells :)
    You can buy them from people sourcing them from scrap yards, or if you have the time go there yourself from time to time :) .
    siwy_dym wrote:
    .... Aren't you afraid that it might flow off the wall for you one day?
    No, but if it happens to me, I'll describe it here.
  • #15 21276574
    siwy_dym
    Ok then good luck 👀👍🐒
  • Victron-style inverter with transformer boost control
    #16 21276639
    __Maciek__
    Help: 25
    Rate: 92
    gulson wrote:
    It is even possible that we will have storage without having to install panels, just to take energy when prices are negative, and to use in the evenings.
    Oh that's what I don't see ... there is no way that the average blacksmith can take advantage of negative prices ... even lower ... to the average blacksmith it is always like charging for gold. But if he produces it, he should give it away for free. That is how it works.
    The warehouse is great as long as one has time, even "Paragon" has changed the cells to large LG Chem.
    Secondly ... inverter ... ok. more and more of these hybrid ... but the vast majority of inverters in use are standard ones that push everything they take out of the panels into the grid.
    I really like the Victron concept ... despite the powerful transformer, the solution is full of finesse and well thought out. It would make me want to build my own .... and it's actually not that difficult ... just for example https://youtu.be/r60wsWmajdo?si=GMcqZhF1a7fgnm4o
    It's a bit more difficult with reverse - charging the AC from the same source. ... but it's probably just a matter of controlling the bridge on the secondary side and using the transformer itself as a choke in the boost converter.
  • Negative market prices still cost consumers after fees
    #17 21276832
    gulson
    Help: 150
    Rate: 6145
    __Maciek__ wrote:
    Oh I don't see that ... there is no way that the average blacksmith can take advantage of negative prices ... even lower ... the average blacksmith will always be charged like gold. But if he produces, let him give it away for free. That is how it works.
    There may be negative prices on the market, but for Kowalski, adding the margin, the transmission fee, the X fee, the Y fee, the smile fee, energy will always cost. Nevertheless, certainly lower than at other times of the day and this is precisely the idea of compensation. Charge as negative prices in the market, use for the rest of the day.
  • Utility prefers high consumption if within contract limits
    #18 21276909
    andrzejlisek
    Level 32  
    Help: 82
    Rate: 713
    AI will pay well for every kWh, and the poor Kowalski will not.
    Sometimes a thought comes to mind, so hypothetically: I live in a block of flats. If I use as much electricity all the time as is used on average by at least 5 flats in this block of flats put together (assuming that I do not exceed the connection capacity and that the electrical installation in the flat can withstand an above-average load), will ZE expect me to reduce my consumption in addition to issuing an appropriate bill to pay (which I will pay every penny and on time)?
    There has been so much talk recently about reducing energy consumption, particularly unnecessary consumption. Would ZE prefer me to consume as little as possible, because costs, because ecology and whatever else comes up, or as much as possible, so that I pay them as much as possible?
  • AI data centers may drive future energy shortages
    #19 21276915
    gulson
    Help: 150
    Rate: 6145
    At the moment, no and it doesn't matter if you don't exceed the declared contractual power (you have it on your contract).
    On the other hand, what will happen one day, will there be power shortages because EjAj will suck everything up.
    Will the system not collapse? You don't know.
    The trend, as you can read from the materials in English, is clear, a huge amount of energy will be needed and only countries that provide cheap energy (not necessarily clean energy - because they are already moving away from that - if we are talking about EjAj) will win. Of course, they do not have to locate any data centre in our country, in which case a huge amount of energy will not be needed, but at the same time such a country is doomed to oblivion (not to mention independence).
    Of course, this can be done by law and the development of AI can be restricted, except that again we return to the problem that such a country will simply be a condominium, heavily dependent on other countries.
    Still another possibility is that they invent something so that this AI monster does not devour so much energy.
    Generally with all the green frenzy some people can pull off, the only thing missing is a cleansing crisis, as someone said - it will suddenly change thinking 180 degrees ;) Suddenly everything will be tidy and clean.
  • Nuclear power as the best energy solution
    #20 21276958
    remzibi
    Help: 34
    Rate: 889
    gulson wrote:
    ..... a huge amount of energy will be needed and only countries that provide cheap energy (not necessarily clean energy - as they are already moving away from that - if we are talking about EjAj) will win....
    .... that such a country will simply be a condominium, heavily dependent on other countries......
    And this is where all in white the atom comes in as the best solution, clean burning technologies with new types of coolant in reactors, you could burn the existing accumulated waste from nuclear power plants.
    But the European Nanny bans the atom and the DE even bans research and publications on it. In our country the elected people are just finishing ploughing up both the atom and AI and science and there will be nothing :) .
    So, in general, we're in the arse, and it's not even surprising that we're already starting to get the hang of it (it's an analogy with Kisiel's famous quote).
    I'm ending this quibble because the sheer uncensored words will continue to fall :) .
  • #21 21276960
    gulson
    Help: 150
    Rate: 6145
    I, however, am thinking positively and hoping for sobriety.
    As I wrote, sometimes one thing changes the perspective by 180 degrees.
    That's why it's going to be hard, because all of Europe is lagging behind, but I'm optimistic 💪.
  • Recommend parallel-first battery assembly for matched cells
    #22 21277316
    LEDówki
    Help: 1322
    Rate: 2605
    18650 size batteries are cheap because there are a lot of them. Used mainly in laptops, they have one disadvantage - a low maximum current. Those used in vehicles and power tools have a higher maximum current, but also a higher price.
    Lithium polymer batteries, a variation of lithium ion batteries. As with gel batteries, the electrolyte is trapped in the polymer. This makes them small, lightweight, suitable for powering phones and it is not clear why they are called batteries.
    In contrast, batteries for powering homes are called storage batteries. Batteries of serially connected batteries - stringers (ladies may have a different opinion about stringers).
    A colleague seems to have assembled a number of batteries in series and connected them in parallel?
    Wouldn't it have been better, following the example of factory batteries, to first assemble batteries in parallel and then connect them in series? Maybe this is due to the disparity in the parameters of the batteries (secondary cells)? When connecting electrochemical cells into batteries, the emphasis is always on making the cells the same (voltage, capacity, internal resistance).
  • Series-parallel battery assembly order correction
    #23 21277518
    remzibi
    Help: 34
    Rate: 889
    gulson wrote:
    ......sometimes one thing changes the perspective by 180 degrees......
    War, quickly and effectively straightens perspective.
    Wasn't it better, following the example of factory batteries, to first assemble a battery of parallel connected batteries and then connect them in series? .......
    In order not to waste time with mindless polemics, I will just so tentatively remind you that there is such a thing as Addition Alternation as one of the foundations of mathematics.
    I recommend reading the link https://zpe.gov.pl/a/przemiennosc-dodawania/D5hBYuiqV
    Image illustrating the commutative property of addition using apples. .
  • #24 21277550
    Janusz_kk
    Help: 228
    Rate: 1481
    remzibi wrote:
    this is just a tentative reminder that there is such a thing as Additive Alternation as one of the foundations of mathematics.
    But only mathematics, with links it does not work.
  • Series-parallel cell count is still six cells
    #25 21277619
    remzibi
    Help: 34
    Rate: 889
    Janusz_kk wrote:
    remzibi wrote:
    this is just a tentative reminder that there is such a thing as Alternating Addition as one of the foundations of mathematics.
    I forgot to add and Alternating Multiplication. :) and a mindless discussion develops. :) .
    So you think that if I add a pack of 3 cells in series connected in parallel to a second pack of 3 cells connected in parallel, it will be a different pack altogether than when I add another 2 in parallel to the two cells connected in series?
    That supposedly 2 width x 3rownol = 6 is different to 3rownol x 2 width = 6?
    Janusz - have you gone mad? :)
  • #26 21277644
    exlibris71
    Help: 21
    Rate: 108
    remzibi wrote:
    That 2 width x 3rownol = 6 is supposedly different from 3rownol x 2 width = 6 ?
    Seemingly the same and yet not. :) How do you balance parallel connected rows of cells? A separate balancer on each row?
  • #27 21277650
    remzibi
    Help: 34
    Rate: 889
    exlibris71 wrote:
    remzibi wrote:
    That supposedly 2 width x 3rownol = 6 is different from 3rownol x 2 width = 6 ?
    Seemingly the same and yet not. :) How do you balance parallel connected rows of cells? On each row a separate balancer?
    Surrenders. :) .
    I balance the whole stock exactly identically with a 2S3P connection as with a 3P2S connection, :) hint that even with the same balancer. :)
  • Series-parallel order does not affect pack voltage or capacity
    #28 21277654
    andrzejlisek
    Level 32  
    Help: 82
    Rate: 713
    Since we are talking about alternation and connectivity of mathematical operations, let us consider two cases composed of 12 links, because that is what the question boils down to.
    For simplicity, we assume that each cell has a voltage of 4V and a capacity of 1A.
    Case 1:
    We create three sets of four cells connected in series. Each set has a voltage of 16V and an efficiency of 1A. We then connect the entire sets in parallel to obtain a battery with a voltage of 16V and a capacity of 3A.
    Case 2:
    We create four sets of three cells connected in parallel. Each set has a voltage of 4V and a capacity of 3A. We then connect the whole sets in series, obtaining a battery with a voltage of 16V and a capacity of 3A.
    As you can see, both cases result in a battery with the same voltage and the same current capacity. For reliability, does it matter which configuration one chooses (leaving aside the cost and ease of battery construction)? Given these most basic mathematical principles, one can conclude that it does not matter.
  • Series-parallel order makes no electrical difference
    #29 21277666
    remzibi
    Help: 34
    Rate: 889
    andrzejlisek wrote:
    Since we are talking about ........ that it doesn't matter.
    Generally, I'm assuming that the discussion is about my stock (the main topic of the thread), and therefore the connection as in case #2, which is how you connect essentially all factory cells to be optimised for balancer handling. And this is exclusively what we are talking about.
    On the other hand, there at the beginning, I so understood, someone expressed a doubt as to whether one should connect in series first, or perhaps in parallel first - well that is completely irrelevant - that is why I wrote about alternation, so that a mindless discussion would not develop - which surprisingly did develop anyway :) .
    I'll say it again - if I assemble the magazine in such a way that I first assemble 14 packs of X cells in parallel and then smoke those packs in series, then exactly the same thing will come out if I connect 14 sections of 1 cell each and then add up to X cells in each section in parallel - it makes absolutely NO difference :) - uuufffff
    From the point of view of convenience and ease of use, it is of course much more convenient to add to each section, which I also described in the first post :)
  • Questioning BMS current, voltage limits, and cell balancing
    #30 21277695
    LEDówki
    Help: 1322
    Rate: 2605
    Fellow mathematicians are overlooking one important detail - three series batteries will have three separate protections. One series battery will have one protection even though it consists of parallel batteries (mixed electrochemical cell combination). Electrical engineering is not mathematics for a 10-year-old. If it were, the children would be assembling the battery packs themselves, which is not in their heads.
    The author explained, so I don't have any more questions about it, except maybe one - is there a protection device, a so-called BMS? What is its maximum current? What are the limiting voltages? Does it have a circuit to balance the voltage of the cells in the battery?
    The author has assembled a battery from matched and random batteries. It is very likely that the Author has not read anything about how electrochemical cells are connected. If he had read, he would have directly answered the question about how to combine cells. Thus, it is very likely that the Author is not shying away from basic mistakes or errors that other battery designers have made. The experiments were carried out a little over a hundred years ago, everything is well described and there is no need to make mistakes from years ago.
    100 la ago there were electric cars with lithium ion battery packs and they failed because of the characteristics of the batteries. I will remind some that back then there was no internet, no documentation, no Aliexpress. Back then it was much harder to get knowledge and materials, yet somehow they managed.
Discussion of a DIY 48V home energy storage system built from recycled 18650 lithium-ion cells, inspired by a “Paragon”-class battery bank and intended to reach about 24 kWh total capacity. The build uses a 5.5 kW hybrid inverter, JKBMS battery management, cell matching by capacity and internal resistance, CC/CV charging, voltage limits around 2.9–4.2 V per cell, and thermal monitoring with infrared imaging and temperature sensors. The topic focuses on safety, fire risk, enclosure placement, charging/discharging limits, winter operation, and the practical advantages of reused laptop and vehicle-pack cells versus Li-Po or LFP alternatives. The discussion also covers parallel/series pack topology, balancing strategy, negative electricity prices, grid independence, and the cost/time required to assemble and test the storage.
TL;DR: Magazyn 48 V 14S z odzyskanych 18650 ma dziś ok. 20 kWh, a docelowo ponad 24 kWh; autor podsumował testy słowami: „działa rewelacyjnie”. Ten FAQ jest dla osób planujących rozbudowywalny domowy magazyn PV i szukających realnych parametrów, testów ogniw, progów napięć oraz metod diagnostyki usterek. [#21276258]
Dlaczego to ważne: Ten wątek pokazuje nie teorię, lecz długoterminową eksploatację dużego magazynu DIY, z kosztami, awariami mechanicznymi, doborem BMS i praktyką serwisową.
Opcja Dane z wątku Wniosek praktyczny
Recykling 18650 w stylu Paragon 14S, 48 V, docelowo 40×6 ogniw, ponad 24 kWh łatwa rozbudowa i wymiana ogniw bez wyłączania
Li-Pol po 1–2 latach często „do wyrzucenia” według autora autor odrzucił tę chemię do magazynu domowego
LiFePO4 forumowicze wskazywali wyższą trwałość i mniejsze ryzyko pożaru alternatywa bez taniego odzysku ogniw
Ogniwa z laptopów dużo odrzutów, ok. 50% lub więcej słabe źródło do dużego magazynu
Ogniwa z e-bike/scooter packów odrzut ok. 30%, łatwiej dobrać podobne partie najlepsze źródło odzysku w tym projekcie
Kluczowy wniosek: Najważniejszą przewagą tej konstrukcji nie jest sama cena, lecz serwisowalność: można dodawać sekcje online, szybko wymieniać wadliwe ogniwa i wychwytywać wycieki termowizją, zanim pokaże je BMS. [#21276258]
  • Konfiguracja magazynu to 14S, 48 V, docelowo 40 stringów po 6 ogniw; początkowo miał ok. 12 kWh, później ok. 20 kWh, a pełna wersja ma przekroczyć 24 kWh. [#21276258]
  • Progi pracy ustawiono konserwatywnie: dolny 3,3 V, górny 4,13 V na ogniwo; BMS ma zakres do 150 A, ale magazyn ustawiono na ładowanie 50 A i rozładowanie 50 A, a falownik ładuje zwykle do 40 A. [#21277727]
  • Koszt osprzętu bez ogniw wyniósł ok. 2200 PLN i obejmował m.in. BMS, ładowarki, rozładowarki, kamerę termowizyjną, koszyki, taśmę do zgrzewania, zgrzewarkę, przewody i końcówki. [#21278634]
  • Autor odrzuca ogniwa, które przy ładowaniu 700 mA przekraczają 40°C; podczas eksploatacji typowy prąd na ogniwo wynosi ok. 250–350 mA, a po pełnym zapełnieniu ma spaść do 150–250 mA. [#21565641]
  • Do kontroli termicznej użyto kamery HT18+, spotykanej też jako GW256; praktyka z wątku pokazuje, że termowizja wykryła punkt gorętszy o 3°C i dwa wycieki ogniw, których nie pokazały sekcyjne odczyty BMS. [#21637020]
How do you build a 48V 14S home energy storage system from recycled 18650 cells in the Paragon style?
Budujesz go jako stojący, rozbudowywalny magazyn 14S 48 V z równoległymi modułami dodawanymi etapami. Autor zrobił ramę przez około 3 tygodnie, użył koszyków na ogniwa, zgrzewanych połączeń, bezpieczników 4 A na stringach i hybrydowego falownika 5,5 kW. Docelowa architektura to 40 stringów po 6 ogniw, czyli układ nastawiony bardziej na pojemność i niski prąd na celę niż na maksymalną moc chwilową. Kluczowe są testy odzyskanych ogniw, selekcja temperaturą i termowizją oraz BMS z balansowaniem. [#21276258]
What is a Paragon-class battery storage design, and why do DIY builders choose it for expandable 18650 packs?
Magazyn klasy Paragon to otwarta, modułowa konstrukcja 18650 inspirowana rozwiązaniem popularyzowanym przez Leszka Kwitka, która ułatwia dokładanie ogniw i serwis bez wyłączania całego systemu. Autor wybrał ten styl właśnie dlatego, że można dodawać sekcje online, wymieniać wadliwe cele w pracującym magazynie i rozłożyć inwestycję w czasie. To ma znaczenie przy odzysku, bo napływ dobrych ogniw jest nieregularny, a pojemność rośnie etapami od ok. 12 kWh do ponad 24 kWh. [#21278484]
How are the cells arranged and connected in this 14S 48V pack, and how is the JK BMS wired to the storage?
Ogniwa są połączone jako 14 sekcji szeregowych, a każda sekcja docelowo ma 40 równoległych stringów po 6 ogniw. Autor podał schemat połączeń do JK BMS 20S z balanserem 1 A, a sam magazyn pracuje jako 14S 48 V. BMS mierzy napięcia sekcji, temperatury i steruje balansowaniem, natomiast ładowanie realizuje falownik hybrydowy w trybie CC/CV. W praktyce autor dobierał stringi pod pojemność i rezystancję wewnętrzną, a środkowe 8 stringów dostało podwójne bezpieczniki 8 A. [#21277727]
What charging and discharging voltage limits work best for recycled 18650 cells in a home storage system, and why were 3.3V to 4.13V chosen here?
W tym projekcie najlepiej sprawdził się zakres 3,3–4,13 V na ogniwo. Autor wybrał go po testach jako kompromis między użyteczną pojemnością, temperaturą pracy i trwałością odzyskanych 18650. BMS ma ustawienia skrajne 2,9–4,2 V, ale codzienna praca jest ograniczona falownikiem do 3,3–4,13 V, a rezerwa awaryjna przy braku sieci schodzi do 3,1 V na ogniwo. Dzięki temu magazyn ma niższe obciążenie chemiczne i spokojniejszą kulturę termiczną. [#21277727]
How do you test, sort, and match recovered 18650 cells for capacity, internal resistance, self-discharge, and temperature before adding them to storage?
Autor stosuje trzyetapową selekcję każdej celi. 1. Sprawdza CID, podnosi rozładowane ogniwa małym prądem i ładuje je z kontrolą temperatury. 2. Rozładowuje, ponownie ładuje prądem 700 mA, mierzy pojemność i rezystancję wewnętrzną. 3. Odkłada ogniwo na około miesiąc i ponownie ocenia samorozładowanie. Ogniwo odpada, jeśli grzeje się nadmiernie, ma słabą pojemność, wysoką rezystancję albo traci napięcie w spoczynku. Stringi są potem dobierane pod pojemność, Rwew, a nawet pochodzenie i producenta. [#21276258]
What is the safe procedure for reviving 18650 cells discharged to 0V, and how do you decide whether to reuse them or reject them?
Bezpieczna procedura polega na bardzo łagodnym podniesieniu napięcia i późniejszym pełnym teście. 1. Autor „budzi” ogniwo prądem 50–100 mA do około 2,8–3,0 V. 2. Zostawia je na około 24 godziny i sprawdza, czy nie ma szybkiego samorozładowania. 3. Jeśli napięcie trzyma, wykonuje standardowe testy pojemności, grzania, Rwew i miesięcznego starzenia. Według jego praktyki około 65% ogniw z 0 V przechodzi pełny proces, a 35% trafia do odrzutu. [#21584666]
Why did the builder choose recycled Li-Ion 18650 cells instead of Li-Pol packs or LiFePO4 cells for this energy storage project?
Wybrał odzyskane Li-Ion 18650, bo są tanie, łatwo dostępne z rozbiórki i dobrze znoszą pracę przy małym prądzie jednostkowym. O Li-Pol napisał wprost, że często szybko degenerują chemicznie i po 1–2 latach bywają do wyrzucenia mimo poprawnej eksploatacji. LiFePO4 było wskazywane przez innych jako bezpieczniejsza alternatywa, ale w tym projekcie priorytetem były niski koszt wejścia, możliwość dokładania ogniw online i wieloletnie doświadczenie autora z 18650 z odzysku. [#21276567]
What is the CID fuse inside an 18650 cell, and how does it affect safety if a cell starts failing or shorting internally?
„CID” jest wewnętrznym bezpiecznikiem ciśnieniowym w ogniwie 18650, który odłącza celę, gdy awaria powoduje wzrost ciśnienia lub nieprawidłową pracę, zmniejszając ryzyko dalszego zasilania uszkodzonego ogniwa. Autor wyjaśnił, że jeśli cela nagle zaczęłaby zwierać, najpierw powinien zadziałać właśnie CID. Jeśli nie zadziała, pozostałe ogniwa rozładują wadliwy pakiet, a potem ma zadziałać zewnętrzny bezpiecznik stringu. To nie eliminuje ryzyka, ale dodaje warstwę ochrony przy lokalnej awarii celi. [#21276258]
How does thermal imaging help detect leaking or overheating 18650 cells earlier than BMS temperature sensors in a battery storage wall?
Termowizja wykrywa pojedyncze anomalie cieplne na konkretnej celi, zanim pokażą je czujniki rozmieszczone w magazynie. Autor podał przykład ogniwa z punktem cieplejszym o 3°C względem tła; po zdjęciu koszulki znalazł mały wyciek elektrolitu i od razu wymienił celę bez wyłączania magazynu. W sierpniu 2025 opisał też dwa kolejne wycieki złapane miesięczną kontrolą termowizyjną, których nie było widać po napięciach sekcji ani po czujnikach BMS. To główny argument za regularną inspekcją całej ściany ogniw. [#21636483]
Which thermal imaging camera model was used for inspecting the battery pack, and what should you look for when choosing one for cell diagnostics?
Autor używa kamery HT18+, występującej też pod nazwą GW256. Do diagnostyki ogniw liczy się nie marketingowy opis, lecz możliwość szybkiego wychwycenia lokalnych odchyleń temperatury na pojedynczych celach i wygodna kontrola całego magazynu bez rozbierania go. W tym wątku kamera miała wykrywać nawet niewielkie różnice i służyła do okresowych przeglądów, które zastąpiły żmudne kontrole mechaniczne. To narzędzie serwisowe, nie gadżet, bo pozwala wychwycić uszkodzoną celę miesiące wcześniej. [#21637020]
What problems can cracked 18650 holders from cheap Chinese suppliers cause, and how can the rack be rebuilt to prevent this failure?
Pękające koszyki mogą osłabić podparcie ogniw i wymusić przebudowę całego magazynu. Autor zauważył w marcu pękanie części uchwytów z jednej partii; problem dotyczył nieoznaczonych koszyków od chińskiego dostawcy, podczas gdy wersje z nadrukami były stabilne. W ciągu dwóch tygodni rozebrał i przebudował magazyn tak, by mechanicznie wyeliminować to miejsce awarii, a uszkodzone uchwyty wymienił. Później doprecyzował, że zbudowanie podstawy z prowadnicami pod koszyki dodatkowo ogranicza ich pękanie. [#21565641]
How much did the frame, BMS, chargers, thermal camera, welding supplies, and other hardware cost, excluding the cells themselves?
Koszt samego osprzętu bez ogniw wyniósł około 2200 PLN. Ta kwota obejmowała ramę, BMS, ładowarki, rozładowarki, kamerę termowizyjną, koszulki, separatory, taśmę do zgrzewania, zgrzewarkę, śruby, przewody, końcówki kablowe i zaciskarkę. Autor wyraźnie rozdzielił ten budżet od czasu testowania oraz kosztu pozyskania ogniw, bo te zależą od źródła odzysku i skali selekcji. Samą konstrukcję ramy wykonał w około 3 tygodnie, pracując po 1–2 godziny popołudniami. [#21278634]
What current per cell is reasonable in a large recycled-18650 home battery, and how does keeping it around 150-350 mA affect lifespan and temperature?
W dużym magazynie z odzyskanych 18650 rozsądny jest prąd rzędu 150–350 mA na ogniwo, a chwilowo może dojść do około 600 mA przy większych skokach obciążenia. Autor opisał, że obecnie cele pracują zwykle przy 250–350 mA, a po pełnym zapełnieniu magazynu średnia ma spaść do 150–250 mA. Taki niski prąd jednostkowy poprawia kulturę temperaturową i ma wydłużyć życie ogniw, bo cały projekt jest zoptymalizowany pod pojemność i łagodne warunki pracy, nie pod agresywną moc chwilową. [#21280164]
How can you add new strings of cells to an already working 14S storage system without shutting it down, and how do you equalize voltages first?
Można to zrobić online, ale tylko po wyrównaniu napięć nowej sekcji z napięciem pracującego magazynu. Autor najpierw wyrównuje wszystkie nowe moduły do około 4,13–4,15 V po miesiącu leżakowania. Następnie czeka, aż cały magazyn będzie w pełni naładowany, czyli też będzie miał około 4,13–4,14 V na celę, i wtedy dopina nowy string 14 modułów. Dzięki temu po podłączeniu praktycznie nie płynie prąd wyrównawczy i nie trzeba używać rezystorów. [#21296653]
What options are there for adding battery storage to a PV system with a Fronius Symo 8.2 inverter, especially if it is not a hybrid model?
W tym wątku nie padła gotowa metoda podłączenia magazynu do Fronius Symo 8.2. Autor potwierdził tylko, że jego własny system działa na falowniku hybrydowym 5,5 kW i dlatego współpracuje z magazynem bezpośrednio. Na pytanie o Froniusa odpowiedział, że nie zna tego modelu i nie potrafi potwierdzić, czy jakikolwiek magazyn da się do niego dołączyć ani jak to zrobić. Praktyczny wniosek jest prosty: najpierw trzeba ustalić, czy dany Symo jest wersją hybrydową lub ma obsługę zewnętrznego magazynu. [#21278020]
