[Solved] Minecraft 1.8.9 Labymod Exit Code 0: Solutions & Causes for Multiplayer Errors & Core Dump Failures
fkroske 18567 5
  • Multiplayer-only exit code 0 with Labymod 1.8.9
    #1 19134909
    fkroske
    Hello. I have had a problem with Minecraft for several days. Well, when I play version 1.8.9 of Labymod on different servers, I get kicked after a short time after starting the game and entering the server because of the exit code 0 or Failed to write core dump. Minidumbs are not enabled by default on client version of Windows.
    Actions taken by me:
    - Reinstall Java and Minecraft (remove and redownload all of their files)
    - Upgrade your graphics card drivers to the latest
    - Uninstalling all launchers or clients leaving only the normal (mojang) one.
    - Removal of all texture pack shaders and mods
    I am asking for help in solving this problem, because no guide posted on the Internet has helped me.
    Edit: If someone can tell me what are the causes of the above errors, I would ask.
    Edit 2: I don't know if this is important but the above-mentioned bugs only occur in multiplayer mode.
    Edit 3: Everything works fine while playing regular minecraft without any modifications etc.
  • #3 19135044
    fkroske
    Unfortunately it does not work :/
  • #4 19138857
    fkroske
    I found a solution to this problem (I don't know if it will work for everyone, but it works for me). Well, I changed the regular minecraft launcher to the lunar client, although I think that on other clients or launchers it should also work.
    Edit: Although I found the solution, I would like to go back to the game on the regular launcher, so again please help me fix the bug.
  • #5 19171300
    fkroske
    Hello, I am submitting the error log
    • hs_err_pid22168.txt (38.05 KB) You must be logged in to download this attachment.
