Minecraft LAN Connection Error: Fix for Overnight Issue & Potential Harmful Factors
starzaczek1 28953 9
  • #1 16296935
    starzaczek1
    Rate: 9
    When you try to connect, the error from the photo pops up. How to fix it? I will add that it happened overnight. I did nothing on any of the computers. What could have harmed the game?
    Minecraft LAN Connection Error: Fix for Overnight Issue & Potential Harmful Factors Minecraft LAN Connection Error: Fix for Overnight Issue & Potential Harmful Factors
  • #2 16298097
  • #3 16298831
    starzaczek1
    Rate: 9
    The version as I added in the photo was updated yesterday. Banned I can not because this is my world :) shared by LAN for a brother who plays on the laptop next door.
    I checked the versions and on the newest one, this error pops up. only on version 1.8. 9 Herobrine I can turn on or 1.7.4 standard,
  • #4 16300642
  • #5 16301479
    starzaczek1
    Rate: 9
    I'm playing a minecraft for Zycz. I do not have other minecraft programs. I do not create anything complicated when it comes to the server. I turn on the normal game and share it via LAN, i.e. I made available while it worked.
    I can share only as I wrote above. In the older version. in the latest I can not play
  • #7 16304611
    starzaczek1
    Rate: 9
    if another company did not take over, I would buy it for PLN 30 as it used to be :D but 100 is a pity for me :D
    and what should I do with this site? :about
  • #8 16306147
    matikowy123
    Rate: 22
    Mc costs 100 for as long as I can remember. From this page, you have to download the exe and you can probably go on. I have never used it but it is supposed to help
  • #9 16460533
    starzaczek1
    Rate: 9
    I do not know what was but it works :) to close
  • #10 16460592
    swiercm
    Moderator on vacation ...
    Help: 1216
    Rate: 550
    We do not support piracy.
    First of all - it is the theft of intellectual property, over which someone spent some time and spent the hard-earned money on it.
    Secondly - cracked versions are usually endowed with an incomplete code and usually there will be problems in the long run - usually not enough is cut out, then you are never sure that an unexpected error will occur in the middle of the game.
    I close the topic and suggest you, however, if you like playing this game, you have invested a few zlotys.
    There are often promotions for legitimate software.
✨ The discussion revolves around a Minecraft LAN connection error that occurred unexpectedly overnight. Users suggest checking for required add-ons, verifying Java versions, and ensuring the correct Minecraft server version is being used. The author notes that the issue arises specifically with the latest version of Minecraft, while older versions function correctly. A recommendation is made to use a tool called "Minecraft Region Fixer" to potentially resolve the issue. The conversation also touches on the importance of using legitimate software to avoid complications associated with pirated versions, which can lead to incomplete code and unexpected errors.
