Trouble Turning on Minecraft: Launcher Crashes, Unexpected Error, Windows 8.1, Latest Java
Inteligent155 4131 2
  • #1 16817120
    Inteligent155
    For some time I have a problem with turning on the minecraft, the launcher starts, click "play" and after loading the game does not start and crashes and there is a launcher and says:
    ,, CRASH GAMES An unexpected error has occurred and the game has been closed. Sorry for the inconvenience"
    recently everything worked, now not, I formatted the system and installed the latest java and still the same. I tried on other launchers and versions and it doesn't work either. Windows 8.1.
    Please help. In case of asking.
    best regards
  • #2 16818056
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Hi. Post the configuration of your computer and some details about this error.
  • #3 16818139
    Inteligent155
    specyfikacja komputera:
    procesor: Intel(R) Celeron(R) CPU G530 @ 2.40GHz
    płyta główna: Gigabyte GA-H61M-DS2
    pamięć RAM 8,00 GB HyperX
    karta graficzna: GIGABYTE RADEON R7 360 2GB
    zasilacz: chieftec
    system: Windows 8.1 x64
    jeszcze crash w shiginima launcher:
    ---- Minecraft Crash Report ----
    // My bad.
    Time: 12.11.17 15:14
    Description: Initializing game
    org.lwjgl.LWJGLException: Pixel format not accelerated
    at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
    at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
    at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
    at org.lwjgl.opengl.Display.createWindow(Display.java:306)
    at org.lwjgl.opengl.Display.create(Display.java:848)
    at org.lwjgl.opengl.Display.create(Display.java:757)
    at org.lwjgl.opengl.Display.create(Display.java:739)
    at ave.ap(SourceFile:534)
    at ave.am(SourceFile:363)
    at ave.a(SourceFile:310)
    at net.minecraft.client.main.Main.main(SourceFile:124)
    A detailed walkthrough of the error, its code path and all known details is as follows:
    -- Head --
    Stacktrace:
    -- Initialization --
    Details:
    Stacktrace:
    -- System Details --
    Details:
    Minecraft Version: 1.8.8
    Operating System: Windows 8.1 (amd64) version 6.3
    Java Version: 1.8.0_151, Oracle Corporation
    Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
    Memory: 65498488 bytes (62 MB) / 160112640 bytes (152 MB) up to 1060372480 bytes (1011 MB)
    JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
    IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
    Launched Version: 1.8.8
    LWJGL: 2.9.4
    OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
    GL Caps:
    Using VBOs: No
    Is Modded: Probably not. Jar signature remains and client brand is untouched.
    Type: Client (map_client.txt)
    Resource Packs:
    Current Language: ~~ERROR~~ NullPointerException: null
    Profiler Position: N/A (disabled)
    CPU:
    #@!@# Game crashed! Crash report saved to: #@!@# C:\Users\Radosław\AppData\Roaming\.minecraft\crash-reports\crash-2017-11-12_15.14.28-client.txt
    [15] [Client Shutdown Thread/INFO]: Stopping server
    Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
    I'm closing the topic
    helped install the latest graphics card drivers
    best regards
