[Solved] Minecraft Startup Error: Integrated Card Issue, Error Screenshots - Kid's Gaming Troubles
winmap 12282 5
  • Suspected integrated graphics failure causing Minecraft startup error
    #1 17041814
    winmap
    Help: 361
    Rate: 753
    Hello. Maybe I chose the wrong department or wgl. this problem does not apply.
    Namely, I mean Minecraft.
    I suspect that this integrated card simply does not work, although it works on a different system at home.
    After loading, this error pops up:
    I wanted to run it for one kid, but it's hardly possible.
    What do you think?
  • #2 17042002
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Post the screen of dxdiag.
    Do you have the latest drivers?
  • Catalyst drivers uninstalled after removing Radeon card
    #3 17042470
    winmap
    Help: 361
    Rate: 753
    I am writing the driver like the newest in the menu. I tried driverdoc. There were some updates there, but not for the graphics system. Unfortunately, I did not install because the paid program. The computer will add that, as I put it, even on the CS it is muli, which should work normally on the integrated one despite this. There was a radeon but got out. I took it out, reset the bios and connected it to the board. Catalyst drivers uninstalled.
    • DxDiag.txt (25.65 KB) You must be logged in to download this attachment.
  • Installed DirectX, but Minecraft still stutters
    #5 17042887
    winmap
    Help: 361
    Rate: 753
    Ok. I will check.
    As for the minecraft version, there is this patch for something. I don't know. Probably all versions are there.
    Added after 18 [hours] 56 [minutes]:
    I have installed everything plus DirectX latest.
    It works, but it cuts a lot.
    This computer seems to be terribly stuffed in terms of software and on the inside.
    For this, maybe the disk also crashes, but that's what I'll do myself.
    Thanks for the help. :)
  • #6 17044253
    winmap
    Help: 361
    Rate: 753
    Ok. I will check.
    Thanks to the help on the topic.
