Transition from ESP8266 to ESP32 without redesigning the board - adapter can be created
Kuba_Cooper 1278 5
  • ESP32 adapter board to replace ESP8266
    #1 19163970
    Kuba_Cooper
    Hi!
    I have a board designed with several devices on I2C, output/input. All of this is supported by the ESP8266. However, I'm struggling with performance issues with this chip, so I'd like to make the switch to its big brother, the ESP32, as painless as possible. I'm wondering if it would be possible, instead of redesigning the whole board, to design an "adapter" which would match the ESP8266 with pins on one side and with paths leading to the same places in ESP32. Has anyone tried this solution yet and is it even doable according to you? I don't need additional I/O just more RAM/processor power.
  • ESP32 adapter would need non-1:1 pin mapping
    #2 19164027
  • #3 19164082
    Zdzicho
    Help: 77
    Rate: 71
    There is also LoLin in esp32 and 8266 versions.
  • #4 19164779
    Slawek K.
    Help: 259
    Rate: 1303
    It is easy to make a hardware adapter, but of course you have to modify the software.
    Greetings
  • #5 19165248
    Nagus
    Help: 99
    Rate: 97
    And what is the ESP8266 doing that is so demanding that it can't cope? Are you generating/receiving signals with microsecond timing?
    I'm afraid the problem might be faulty software design, in which case even switching to an RPi with a quad-core CPU won't help.
    In other words: write something about this project, because you might not have to mess around with adapters.
  • #6 19174252
    krzbor
    Help: 42
    Rate: 1072
    The problem may be the lack of hardware I2C on the ESP8266. The ESP32 has several hardware I2Cs.
