Alternatives to the ESP8266 for use as a WiFi gateway with WPS and SPI
leonow32 1119 1
  • #1 17284465
    leonow32
    Level 30  
    Help: 37
    Rate: 1232
    Hey!
    Due to numerous problems with the ESP8266, I found that I needed to look for an alternative, but I have no experience with WiFi modules other than ESP. My requirements are not high:
    - sending and receiving simple text data in any way, once every 15 minutes
    - WPS function for easy connection to a WiFi router
    - built-in antenna, but the possibility to connect an external one would be nice
    - communication with uC via SPI (preferably)
    - ready-made libraries for the above-mentioned functions
    What is your advice? I would prefer it not to be some cheap Chinese thing, but something you can rely on.
  • #2 17285099
    PowracajacyBumerang
    ESP32
    Or a tried and tested solution, Ethernet and AP from any manufacturer.
    Another option OrangePi ZERO.
