Whirlpool WFC3C23PFX - Error F15 the dishwasher does not take water
Elokwent 72702 9
Why does a Whirlpool WFC3C23PFX dishwasher stop filling with water and show F15, and what part should be checked or replaced?
F15 on this Whirlpool usually points to a worn or failed wash pump, so the practical fix is to replace the wash pump or repair it with a kit if you want to regenerate it [#19182123] [#19622872] [#19622938] One reply also notes that F15 is described as a virtual sensor / inconsistent readings fault, again pointing to the wash pump [#19622938] A later user reported that replacing the plain bearings in the pump made the dishwasher run again [#19651721] [#19651731] F2 was mentioned separately as a fill solenoid valve failure or main board triac issue, but the thread’s main diagnosis for F15 is the wash pump [#19622938]
Treść zostaÅ‚a przetÅ‚umaczona polish » english Zobacz oryginalnÄ… wersjÄ™ tematu
  • Low water pressure likely causing intermittent F15 fault
    #1 19181801
    Elokwent
    I have a problem with the Whirlpool WFC 3C23 PF X / WFC3C23PFX / 769991017174 / 869991017170 dishwasher. The dishwasher does not take water. After some time from launching any program, it displays the F15 error. I replaced the Aquastop cable, but it did not help to remove the fault. I have quite low water pressure. The dishwasher sometimes works, more often it doesn't. Out of 10 attempts, 1 will pass the entire program.
    The F15 error is so general that it basically says nothing.
    skryn
    Home appliances specialist
    Help: 268
    Rate: 1011
    It must have been a million times that F15 is a finished wash pump... :(
  • #3 19622796
    Tmkawa86
    Rate: 35
    Hello. And what was the cause? I have the same dishwasher and the same problem for a few days.
  • #4 19622872
    Piotr2608
    Help: 851
    Rate: 4487
    The usual with this error code - Wash Pump to be replaced.
    ZimTech Piotr Zimny
  • #5 19622923
    Tmkawa86
    Rate: 35
    @Piotr2608
    Seriously? The warranty expired in the dishwasher 3 months ago, which is a little over 2 years old and it was not overly exploited.
    Ps. In addition to F15, F2 also pops up from time to time.
  • #6 19622938
    Piotr2608
    Help: 851
    Rate: 4487
    F2 - WATER FILL SOLENOID VALVE FAILURE
    - Fill solenoid valve failure;
    - Main board fill solenoid valve triac short-circuiting;
    - Make certain drain hose is not on the door.
    F15 - VIRTUAL SENSOR - Inconsistent readings
    - Replace wash pump.
    Tmkawa86 wrote:
    Seriously? The dishwasher warranty expired 3 months ago
    You will replace the washing pump and the dishwasher will return to the world of the living.
    ZimTech Piotr Zimny
  • #7 19623947
    Tmkawa86
    Rate: 35
    @Piotr2608
    Is there any way to regenerate her? Maybe it's enough to replace the plain bearings, the pump is working so far, only this error does not allow you to complete the program.
  • #8 19651721
    PralkowcyPL
    Rate: 18
    Tmkawa86 wrote:
    @Piotr2608
    It can regenerate. I manufacture and sell repair kits for these pumps.
  • #9 19651731
    Tmkawa86
    Rate: 35
    @PralkowcyPL I just recently bought from you on Allegro. The bearings are already installed and the dishwasher continues to run. Now I use gel and not tablets.😅
  • #10 19651732
    PralkowcyPL
    Rate: 18
    Tmkawa86 wrote:
    @PralkowcyPL I just recently bought from you on allegro. The bearings are already installed and the dishwasher continues to run. Now I use gel and not tablets.😅
    Gites :) Regards! :)
The Whirlpool WFC3C23PFX dishwasher is experiencing an F15 error, indicating a failure related to the wash pump, which prevents the machine from taking in water. Users have noted that low water pressure may exacerbate the issue, and the error can be intermittent, with the machine occasionally completing a cycle. Suggestions for resolution include replacing the wash pump, as well as potential regeneration of the pump by replacing bearings. Additional error codes, such as F2, indicate possible issues with the water fill solenoid valve. Some users have successfully repaired their pumps using kits available for purchase.
