Whirlpool ADP6920 Dishwasher: Resolving Error Codes F4 & E3 - Troubleshooting & Repair Guidance
CórkaSwojejMamy 52764 12
Why do alternating F4 and E3 errors appear on a Whirlpool dishwasher, and what can be checked or repaired to fix them?
The F4/E3 combination usually points to a wash-motor problem, often a sticking pump, though some cases were fixed by replacing the OVI sensor or the control module [#16243609] [#16243034] [#17999924] One user reported that the pump would only start after tapping or moving it, which strongly suggests the pump/motor is intermittently hanging up and may need replacement if it will not run reliably [#17230364] [#17435645] [#17435799] A separate explanation for F4 mentions drain failure, so it is also worth checking the drain hose, pump, filters, and whether they are blocked or broken [#16242405] E3 can also be triggered by dirty or clogged filters and excessive foam [#16242405]
  • #1 16242325
    CórkaSwojejMamy
    Rate: 9
    As above, the two errors pop up alternately. Maybe someone has an idea about what is going on and how to fix it?
  • #2 16242405
    Dra98
    Help: 1321
    Rate: 1076
    Error code of Whirlpool F4 dishwashers - water pump failure - Draining failure, can mean a problem with the pump - pumping out or just working? - drain hose - it is worth checking if it is broken, blocked. E3 can mean eg dirty or clogged filters, large foaming inside the device.
    User's manual - http://docs.whirlpool.eu/_doc/501939601853EN.pdf
  • #3 16242491
    CórkaSwojejMamy
    Rate: 9
    Thank you very much, with the tide already checked, but maybe it is worth getting to the pump itself and clean :)
  • #4 16243034
    domis33
    Help: 13
    Rate: 220
    Replace the OVI sensor
  • #5 16243609
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    F4E3 - Wash motor not functioning
  • #6 17230364
    Robaczek20
    Hello everyone,
    I also get an error like in the subject. By accident, I came to what is causing the individual subassemblies :) . My problem is the periodic occurrence of these errors. I have the impression that the pump seems to hang. Just tap the pump and start working immediately. Is it time to replace the element or maybe the pump is all right, and there is another element that causes it to work once without dumping it in the error?
  • #7 17435240
    Mateuszamator
    Rate: 22
    I have a dishwasher Whirpool ADP620IX and I get errors F4 E3 alternately exchanged sensor owi made calibration and did not show any error, one wash was ok. And the same what happens? Maybe someone coped with this help error.
  • #8 17435363
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Mateuszamator wrote:
    F4 e3 errors pop up
    This is one mistake.
    You have enough tips on this topic.
  • #9 17435645
    Mateuszamator
    Rate: 22
    Mrice, thank you for the answer I just noticed that when I move a little, the pump starts to work only that it annoys me how it can be repaired or is it necessary to replace the pump?
  • #10 17435799
    mrice
    Help: 2213
    Rate: 6951
    If nothing pumps, it blocks the exchange.
  • #11 17999924
    romanoix
    And in my case, the module replacement helped.
  • #12 18000605
    Piotr2608
    Help: 851
    Rate: 4487
    How many times I would not paste this error code is still not enough and I do not want to look.
    ZimTech Piotr Zimny
  • Request for service manual and motor part number
    #13 20077416
    horiamorariu
    I have the same error F4 E3 to my dishwasher Whirlpool ADG7643A+
    And is doing a very strange noise, like vibration.
    As I read in this post, the most probable fault component is the motor.
    Please, anyone have the service manual of this dish-washer: how to disassemble, electric and mechanic schematic, part number for the motor to be changed?
    Many thanks in advance!
    Best regards, Horia.
The Whirlpool ADP6920 dishwasher is experiencing alternating error codes F4 and E3, indicating potential issues with the water pump and motor. Error F4 typically signifies a water pump failure or drainage issue, possibly due to a blocked or broken drain hose. Error E3 may result from clogged filters or excessive foaming. Users suggest checking and cleaning the pump, as some have found that tapping the pump can temporarily resolve the issue. Others have reported that replacing the OVI sensor or the motor module has resolved similar problems. Additionally, one user noted unusual vibrations, indicating a possible motor fault. Service manuals and part numbers for repairs are sought by users.
