Seeking Firmware for Onkyo TX-NR616 Receiver: Issues with HDMI, Sound Output, VSP & VMPU
onkyoyoho 4476 4
  • VSP and VMPU firmware update error 5-82
    #1 19343735
    onkyoyoho
    Level 4  
    Seeking Firmware for Onkyo TX-NR616 Receiver: Issues with HDMI, Sound Output, VSP & VMPU Seeking Firmware for Onkyo TX-NR616 Receiver: Issues with HDMI, Sound Output, VSP & VMPU Hi
    All
    I have no HDMI out or sound out on this receiver
    Randomly it has stopped working
    In the debug model when I look at the firmware for vsp and vmpu, I get no question marks, just V and K
    I have tried to update by USB and Ethernet and get the same error
    5-82 on vsp and vmpu
    Please can someone send me the firmware so that I can program this myself or upload it
    alternatively can I use the UART cable
    Please can someone reply and assist me, I will be really grateful and appreciate it so much
    Many Thanks
    Kind Regards
    Hi please can anyone help
  • Requesting regulator test points on the board top
    #2 19344419
    onkyoyoho
    Level 4  
    I have been thinking it might be a voltage problem but I can't get to the regulators as they are on the bottom of the board.
    Can I do any tests from the top or can I flip the board over with something underneath and test and
    in order to do this do all the cables need to be attached
    Thanks so much
    please can someone help who has worked on these boards
    can someone tell me which regulators please
    thanks so much
  • VMPU firmware failure blocks VSP update
    #3 19892728
    Lizak86
    Rate: 21
    I have the same but in Onkyo TX-NR818.
    https://www.elektroda.pl/rtvforum/topic3873122.html
    The update on VMPU did not go ... and if VMPU fails, then VSP also, On VMPU there is a compiled program and without its source code nothing can be done .. I have Ulink2 and as much as I was able to communicate with the TMPM361F10FG microprocessor and delete it ....
  • Internal short on RX HDMI chip collapsed 1.8V rail
    #4 19893735
    dobrykamil
    Level 19  
    Help: 35
    Rate: 76
    onkyoyoho wrote:
    I thought this might be a voltage problem but I can't get to the regulators as they are on the bottom of the board.
    can i do some top tests, can i flip the board with something underneath and test and
    for this, all cables must be connected
    Thank you very much
    please can anyone help who worked on these boards
    can anyone tell me which regulators please
    Thank you very much
    I love the same problem once. Cause the voltage on the pins of the RX hdmi chip. In my case, this circuit had an internal short circuit. He got quite hot and the 1.8V line was only a few mV.
  • #5 19895223
    onkyoyoho
    Level 4  
    How did you get it to communicate with the CPU chip? J-link keeps showing error. Can you show wiring and make video of setup please
    Thanks
    Jak udało ci się zmusić go do komunikacji z chipem procesora? J-link ciągle pokazuje błąd. Czy możesz pokazać okablowanie i nagrać wideo z konfiguracji?
    Dzięki
