Onkyo TX-NR616: How to Test Regulators & Verify Voltages for VSP & VMPU chips (90 chars)
onkyoyoho 1458 2
  • #1 19344425
    onkyoyoho
    Level 4  
    Hi
    I can't see any question mark when I check firmware for V and K. this is vsp and vmpu
    I want to check voltages coming into this chip as they maybe not getting voltage
    Please can someone tell me the regulators to test and how to test as they are on the other side of the board
    can I do any tests from the top or can I flip the board over with something underneath and test and
    in order to do this do all the cables need to be attached
    Thanks so much
    please can someone help who has worked on these boards
    can someone tell me which regulators please
    thanks so much
    I have tested voltages on the following coils
    L8932 - 1.3V
    L8942 - 1.8V
    L8952 - 3.3V
    L8962 - 5.2V
    i have been checking everything seems to be checking out fine
    L8002 - 1.0V
    L8004 - 1.4V
    L8006 - 1.0V
    L8932 - 1.3V
    L8942 - 1.8V
    L8952 - 3.3V
    L8962 - 5.2V
  • #2 20370570
    azaghorth
    Rate: 11
    *Please can someone tell me the regulators to test and how to test as they are on the other side of the board*
    All of them, use a DMM (digital multimeter), check on the web for the datasheet of the component, or a service manual.
    *can I do any tests from the top or can i flip the board over with something underneath and test and*
    Do as is convenient, while trying not to damage the boards. You can use/make extending cables...
  • #3 20370723
    dobrykamil
    Level 19  
    Help: 35
    Rate: 75
    And how does the DSP fw verison looks like? Do you get question marks?
