Onkyo TX NR906: No HDMI Video Output - Troubleshooting and Firmware Update Tips
satbeginner 3786 4
  • #1 18908466
    satbeginner
    I am a retired Dutch electronic technician, now living in Spain.
    After using Google I found this site.
    I have a problem with an Onkyo TX NR906, it does not give any picture out on the HDMI ports.
    When I check the firmware versions I see information on Main, DSP1, DSP2, DSP3, HDMI, NET, NET usr, NET rfs, NET krn , NET ipl, but only a blank line on VIDEO:.
    It was a gift to me, so I started to replace all capacitors on the HDMI board, this did not change anything.
    When it came to me, it had Main FW 1.00, and I was able to upgrade using the serial port to 1.05 and a Windows-98 PC, but this did not change anything with respect to the HDMI output.
    I do not see any setup screen, nor any video input.
    Is there any information about what could cause this available?
    Thank you for any help available,
    Leo
  • #2 18969854
    promo7uk
    Rate: 15
    I have the one for Pioneer 1051 it's the same, full fix,,
  • #3 19252539
    petrykcom
    Rate: 19
    If this helps, I had a similar topic in the TX-NR515. It is completely unknown how the contents of the memory of the video controller itself were cleared. All other software was ok. For me it was Q8040 W25Q128BVFIG. When I desoldered it and checked it was very clean. I found a batch for it and uploaded it. After this operation, I have already done the traditional upgrade and everything worked.
  • Q8040 flash memory reprogramming restored HDMI output
    #4 19343737
    onkyoyoho
    Level 4  
    Hi can you upload the firmware as I am in the same boat
    Thanks all
  • #5 19352385
    petrykcom
    Rate: 19
    Please dump attached ...
    • TX-NR515 Q8040 W25Q128BVFIG ONKAVR000D_00EAEA00EAEAEA_128 - Mój.BIN (16 MB) You must be logged in to download this attachment.
