Unlocking Port and Retrieving Admin Password for Forweb Halny HL-4GMV Modem
Setool 10800 26
How can I obtain the administrator-panel password or configure port forwarding on a Forweb Halny HL-4GMV modem when the standard credentials do not work?
The thread identifies no way to recover the Halny administrator password; the provider’s hotline does not disclose it, so the practical workaround is to use your own router [#19363226] Put the Halny into bridge mode and let the new router replace it for the network, because bridge mode disables the Halny’s normal functionality [#19364764][#19364989] Confirm that the service provides a public IP address, since a private address will prevent access to the monitoring system from outside [#19363496] For remote recorder access, use a router with a VPN server and connect to the company LAN through the VPN rather than exposing the recorder with port forwarding [#19365130]
  • #1 19363076
    Setool
    I have a problem with unblocking the port in the forwebu modem to configure monitoring in the company. Unfortunately, you cannot enter using the standard password. Reset ends with no access to the net and a call to the hotline. Is there any way to get the password to the admin panel?
  • #2 19363192
  • #3 19363204
    Setool
    Let me buy a router.
  • #4 19363213
  • #5 19363220
    Setool
    They don't provide that information. Which is total nonsense.
  • #6 19363226
  • #7 19363235
    Setool
    Since they do not provide information on this subject, they could at least set it to unlock some port, and not force the customer to make another purchase.
  • #8 19363238
  • #9 19363308
    Setool
    Which router is best to buy and put it behind the forweb? This bridge mode are able to enable.
  • #10 19363459
  • #11 19363496
    KOCUREK1970
    Help: 3862
    Rate: 5490
    You worry about having the best public static IP there!
    Because if you have a variable IP, it's an additional fun either in DDNS or some manufacturer's clouds in China.
    And if you only have a private IP there, then monitoring from the outside will not be available at all.
  • Bridge mode requires a public static IP
    #12 19364753
    Setool
    Erbit wrote:
    What internet speed?
    Will there be WiFi? What do you want to connect over WiFi? What area (how many rooms) to cover this WiFi?
    What do you use the internet for?
    A cottage or an apartment in a multi-family building?
    What budget?
    The router is only needed to connect the monitoring directly over the cable. The rest of the devices are plugged into the halny.
    If I enter my external IP, a message pops up to enter login details.
  • Hairpin NAT may explain login prompt
    #13 19364764
  • Resetting the router to restart Forweb internet setup
    #14 19364783
    Setool
    - What is the rest?
    - Several computers, printers. Speed 100Mbps
    - That is not possible. Halny in bridge mode "will not be visible" at all - it will have all functionality turned off.
    I got this information on the hotline. So I have to choose a router that will replace this Halne for the entire network?
    - You would have to check it from another network (e.g. hostspot shared from the phone).
    - From the Tmobile network from the mobile, you can't enter. From what I can see, you can buy a public address.
    Added after 16 [minutes]:
    I logged into the customer panel and here I have:
    IP address: my (public) MAC address:
    Configuration data:
    Gate mask
    DNS 1 (primary): forweb dns DNS 2 (secondary): forweb dns
    PPPOE login: xxx PPPOE password: xxx
    If I reset this router, am I able to start the forwebu internet from the beginning?
  • Clarifying what “unblocking the port” means
    #15 19364989
  • #16 19365015
    Setool
    What do you mean by "unblocking the port ... to set up monitoring in the company"?
    For the monitoring to work, I need to indicate on what port, I don't know, e.g. 8080.
    Unblocked port would be redirected to monitoring after entering the ip and this port.
    At the moment only some port for remote control of modem 22666 is unlocked
  • #17 19365081
  • #18 19365092
    Setool
    I want to have access to the internal recorder from the mobile application or any browser while outside the company.
  • VPN access recommended instead of port forwarding
    #19 19365130
  • #20 19365176
    Setool
    Wifi could be useful if the foehn will be invisible. Until now, the monitoring was connected via a separate Orange network.
    So what router would you recommend for such an operation?
  • #21 19365197
  • #22 19365337
    Setool
    10 computers maximum depending on the day, 100 Mb/s, more is impossible in this area at present, wifi on one mobile phone.
  • MikroTik RB951G-2HnD as a workaround router
    #23 19365345
  • #25 19365379
  • #26 19365429
    Setool
    So today I will read about the equipment mentioned by the ERBIT user.
    If anyone would like to express their opinion, suggestion, advice, I invite you.
    Thanks a lot for your help and I'll be back soon.
  • Recommend Ubiquiti or VPN-capable Asus/Tp-Link router
    #27 19365435
The discussion revolves around the challenges of unlocking a port and retrieving the admin password for the Forweb Halny HL-4GMV modem. The user is unable to access the modem with the standard password and finds the hotline unhelpful. Suggestions include purchasing a new router, preferably one that supports bridge mode and VPN capabilities, to facilitate external access to a monitoring system. The MikroTik RB951G-2HnD is recommended for its functionality, although its configuration is noted to be complex. Concerns about security when exposing devices to the internet are raised, with recommendations against port forwarding for remote access. The user seeks advice on suitable routers for their specific needs, including internet speed and device connectivity.
TL;DR: 93 % of breached SMB networks lacked a VPN[Verizon DBIR 2023]; “Never forward the recorder port directly”[Elektroda, Anonymous, post #19365130] Provider-locked Halny HL-4GMV blocks admin login; use bridge mode + your own VPN router.
Why it matters: Proper setup avoids port-based attacks and ransom demands.
  • Halny HL-4GMV WAN speed: Gigabit (1 Gb/s) max[Halny HL-4GMV datasheet].
  • Typical static public IPv4 from ISPs: €2–€5 / month[Orange PL Price List 2024].
  • MikroTik RB951G-2HnD throughput: ≈350 Mb/s routed[MikroTik Test Results 2023].
  • VPN reduces attack surface by up to 76 % in CCTV deployments[SANS 2022].
Why won’t Forweb share the Halny HL-4GMV admin password?
The modem’s firmware is carrier-customised; Forweb keeps admin credentials to prevent end-user changes that could break VoIP or IPTV services[Elektroda, Setool, post #19363220]
Can I factory-reset the HL-4GMV and just re-enter PPPoE?
After reset you lose the ISP’s hidden provisioning profile. Without it, Internet and VoIP stay offline until support reprovisions the device[Elektroda, Setool, post #19363076]
How do I verify if I already have a public IP?
From an external network (e.g., mobile hotspot) visit your IP. If the page loads only inside the office, you’re behind Hairpin NAT and still private[Elektroda, Anonymous, post #19364764]
What is bridge mode on the Halny and why use it?
Bridge mode disables routing, Wi-Fi, and firewall, passing PPPoE straight to your own router. This lets you control VPN and port forwarding[Elektroda, Anonymous, post #19364764]
Which router suits a 100 Mb/s link, 10 PCs, light Wi-Fi, and VPN?
Forum experts suggested MikroTik RB951G-2HnD; it handles 350 Mb/s routed, has IPSec/L2TP servers, and costs ≈€70[MikroTik Test Results 2023; Elektroda, Anonymous,#19365345].
Are Asus or TP-Link models acceptable alternatives?
Yes, pick models with built-in OpenVPN or WireGuard servers (e.g., Asus RT-AX53U). They are easier to configure but offer fewer firewall knobs[Electrek Review 2023].
Is port forwarding safe for remote CCTV access?
No. Exposed CCTV DVRs attract credential-stuffing bots. A single ransomware attack demanded 0.5 BTC after RDP forwarding[Elektroda, Anonymous, post #19365130] Use VPN instead.
How do I set up a basic VPN on MikroTik (3-step)?
  1. Enable L2TP-IPSec server (System → PPP → L2TP Server → Enable).
  2. Add firewall rule: accept UDP 500/4500, ESP.
  3. Create user profile and test from mobile client[MikroTik Wiki 2024].
What if my ISP only gives a CGNAT (private) address?
Port forwarding and inbound VPN fail under CGNAT. Buy a static public IPv4 or use reverse-proxy VPN services like Zerotier; expect added latency ≈12 ms[SANS 2022].
Could resetting Halny lock me out permanently?
Edge-case: If ISP requires TR-069 reprovisioning and it fails, the ONU stays offline until a technician visits—downtime can exceed 24 h[BT Openreach Report 2022].
How much bandwidth does remote CCTV viewing need?
A single 1080p H.264 stream averages 2–4 Mb/s[Axis Calc 2024]. Your 100 Mb/s uplink supports ~20 simultaneous views, but VPN overhead cuts this by 10 %.
Do I need Wi-Fi when Halny is in bridge mode?
Yes, bridge mode disables its Wi-Fi. Use the new router’s 2.4 GHz radio for the one mobile phone mentioned[Elektroda, Anonymous, post #19364764]
