[Solved] Using Huawei B525s-23a for Enhanced Wi-Fi: Configuring as Repeater for Funbox 3.0 Router
tomek2k6 19947 4
  • Huawei B525s-23a flashed with BridgeMode firmware
    #1 19395137
    tomek2k6
    Level 4  
    I have an orange optical fiber at home on the ground floor, which is connected to the Funbox 3.0 router from the modem.
    Funbox 3.0 is fine on the ground floor, but it's hard on the first floor. I have a Huawei b525s-23a router, would it work as a repeater?
    I have this router from T-mobile and for my part I have already managed to upload the firmware with the modem that gives the BridgeMode function.
    Please help :)
    IC_Current
    Help: 1499
    Rate: 2522
    Repeater is a mode of operation for people who like "attractions" in the form of instability, low connection speeds and other unforeseen problems. The B525 does not support this mode. However, you can do the installation correctly and lead the cable from the main router to the first floor and connect the B525 there as an access point. This will now work perfectly fine.
  • #3 19395176
    tomek2k6
    Level 4  
    I've done so much with this router, and here it turns out that there is no such possibility.
    Getting the cable will be a big challenge, but oh well.
    IC_Current
    Help: 1499
    Rate: 2522
    A big challenge but it will pay off in trouble-free operation of the network.
  • #5 19395800
    tomek2k6
    Level 4  
    Thanks for your help, closing :)
