Siemens EQ.7 brew unit piston gets stuck after just a couples of brews
bonne 6348 3
  • Worn brew unit seals may be causing piston sticking
    #1 19400377
    bonne
    Got a Siemens TE712291RW/02
    It started complaining about clean brew unit, sometimes change brew unit. I cleaned it and it could run again. But now it is down to every second brew I need to clean the brew unit.
    The "piston" gets stuck, så I need to rinse and force it loose again, and the machine works again - a couple of brews.
    Coffee was ejected everywhere inside the compartment. So I also had to clean this.
    My question is... how to solve this so I don't need to clean the unit so often. Is the brew unit faulty or is the problem another place in the machine?
    Could I perhaps disassemble the brew unit to clean it better - or do I need to change parts in it? I can see that it has some o-rings?
    Regards, Lars
  • #2 19425515
    JamesGBC
    You need to use food safe silikonfett to lubricate the piston and other moving parts in the brew group. You can buy an o ring kit but try the silikon first.
    There are quite a few good YouTube videos showing this its very similar to the Bosch units.
    ssss
    Help: 471
    Rate: 1824
    To replace
    0613
    0614
    • 1774958.pdf (1.16 MB) You must be logged in to download this attachment.
  • Need the 0612 o-rings or full 0614 inlet fitting
    #4 19490045
    bonne
    Thanks both of you.
    I bought a repair set on Amazon, but I only got the larger 0613 (four of them actually)
    0614 was not in, but maybe they need to be ordered separately? I only need the o-rings (0612) or the full "thing" 0614?
    Regards, Lars.
    I mean all this
    https://dein-ersatzteil.de/p/einlaufstutzen-a...sch-siemens-00636487-kaffeeautomat-3160021953
    or just the two small o-rings?
