Siemens EQ 6 TE603201RW / 09 - Problem with removing the brew unit
Nikkaz 29535 9
Why does the brew unit on a Siemens EQ.6 only slide out halfway and then get stuck, with the lock tab no longer movable, and how can it be released?
The brew unit drive is probably stopped in the wrong position, which is why the unit only comes out halfway and the lock tab cannot be reset; the machine should be switched off when you try to remove it [#16410696] [#16410615] Check the PCB X9 connector and use pins 3 and 4, which supply the 12 V brewing motor [#16410696] You can test the motor with a 9 V battery; if it runs, adjust for polarity and running time, but if it does not run then the motor-circuit fuse has tripped [#16410696] A dirty brew unit or mechanical resistance may be the cause of the drive stopping in the wrong position [#16410696]
  • #1 16410480
    Nikkaz
    Hello, I bought a Siemens E.Q. 6 Series 300 coffee machine today. I’ve filled it with water and added coffee. I opened the side flap of the brew unit, where there was a small instruction leaflet on cleaning and so on. When I tried to pull out the brew unit, I noticed that I couldn’t ‘unlock’ it. The wheel with the hole for the red switch seems to be in the wrong position and the switch cannot be pushed back – something I only noticed after I had unlocked the brew unit (a manufacturing fault? In all the videos, the hole for the switch was in the correct position). However, following the instructions, I managed to open the mechanism by pressing the right button down (which was theoretically blocked by the faulty padlock button, but it went down without any trouble and without me having to use any force, so I thought everything was fine). However, everything wasn’t fine, because despite pressing the right button down, the mechanism only slides out halfway, as if something were blocking it. On top of that, I can’t push it back in, as I can’t push the padlock button back – which is strange, as it opened without any trouble. Does the machine need replacing, or have I done something wrong? That wheel with the hole for the switch won’t turn at all.
    Photo:
  • #2 16410615
    tkaczu1
    Help: 22
    Rate: 92
    From what I remember in my simens you have to do it on the switched-off machine but I have a different model.
  • #3 16410623
    Nikkaz
    the machine is switched off
  • #4 16410696
    mrhari
    Help: 835
    Rate: 3239
    In your photo you can see such a wajcha in red and above it the symbol of an open and closed padlock, if it does not work, it means that the brewing unit drive has stopped in the wrong position.
    On the PCB, find the x9 connector and counting from the right side pins 3 and 4 is the power supply to the 12V brewing motor.
    Powered by 9V battery, if the engine starts then combine with polarization and spinning time.
    If it does not start, i.e. a fuse in the motor circuit has reacted. The reason may be a dirty brewing unit or resistance to its operation.
  • #5 16410707
    Nikkaz
    So this wheel with a crack on this red is movable and just stopped in the wrong place? The coffee maker didn't make even one coffee because it was just unpacked from the box so I would prefer not to play with this engine. I'll see what they'll tell me tomorrow in the store.
  • #6 16410813
    mrhari
    Help: 835
    Rate: 3239
    And did you see the inscription "Push Here" ??
    https://translate.google.com/#en/pl/push%20here
  • #7 16410823
    Nikkaz
    Specialist, this inscription concerns the insertion of the brewing unit
  • #8 16410899
    mrhari
    Help: 835
    Rate: 3239
    Nikkaz wrote:
    Mr. specialist
    [sarcasm = "mrhari"] And I'm sorry. [/sarcasm]
    Added after 53 [seconds]:
    Nikkaz wrote:
    Wanting to pull out the brewer, I noticed that it could not be "unlocked".
    I can't help it, Yogi Baboo, poor bear.
  • #9 21161369
    Dasmeister
    How did you fix your issue?
  • #10 21413592
    ragavsathisc
    >>16410823 : I am facing the same issue.
    Did you fix it? Can you share the details?
The discussion concerns a Siemens EQ 6 TE603201RW / 09 coffee machine with a problem removing the brew unit. The user reports that the red locking switch on the brewing unit appears misaligned and cannot be unlocked properly, despite following cleaning and removal instructions. The brewing unit mechanism only slides halfway, suggesting it may be stuck or blocked. Responses indicate the brewing unit drive might have stopped in an incorrect position, potentially due to a motor circuit fuse triggered by resistance or dirt in the unit. It is advised to check the 12V brewing motor power supply on the PCB (pins 3 and 4 of the x9 connector) and test motor operation with a 9V battery to diagnose motor or fuse issues. The machine should be switched off during removal attempts. The user prefers not to attempt motor repairs as the machine is new and plans to consult the store. Later posts inquire if the issue was resolved, but no solution is provided.
