Technicolor CGA2121 Router Login Issue: Continuous Page Refresh After Entering Data
Jasiek24312412 53979 17
How can I log into a Technicolor CGA2121 router when the login page keeps refreshing after I enter the credentials?
Try logging in with an empty username and an empty password; that fixed the same CGA2121 login loop for another user [#20217415] After changing the credentials, the router is then accessed with the new password and an empty username [#20217415] Another user confirmed that the empty/empty login works on this modem-router as well [#20254493]
  • #1 19428709
    Jasiek24312412
    I go to the router's website and try to log in, but after entering the correct data, the page refreshes and so on.
  • #2 19428723
    sosarek
    Help: 9320
    Rate: 15532
    192.168.0.1 and enter
    Username: homeu Password: homep?
    Checked in another browser?
    Z
    Pka, Poznań, 60-850
  • #3 19428727
    Jasiek24312412
    This was checked not only on different browsers but also on devices
  • #4 19428729
    artbi881
    Level 30  
    Help: 130
    Rate: 264
    You are probably entering incorrect data and Adam2 does not allow you :) admin/admin not working? sometimes Customer number and PESEL as password ... :|
  • #5 19428732
    Jasiek24312412
    I will check and let you know with this pesel
  • #6 19428905
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Jasiek24312412 wrote:
    I cannot log into the Technicolor CGA2121 router website
    Which OP did you subscribe to?
    If it's Vectra/MM, they don't give the retailer access to the GUI of the modem router, the only option is through the subscriber portal (but options there are like medicine).
    Switch your modemorouter to modem mode in this portal, connect your own router and you have full control.
  • Vectra portal lacks modem settings and bridge mode
    #7 19428976
    Jasiek24312412
    With the client number and pesel, it does not work, and when it comes to access, it's strange because I had it with vectra all the time, but on the previous router I could normally log in to the router's website. I will mess with this modem, thanks for the info that it is possible
    Added after 25 [minutes]:
    I logged into the Vectra website, there are practically no settings. There is no modem option, only router and bridge to choose from
  • #8 19429116
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Bridge is just a modem.
  • #9 19429199
    Jasiek24312412
    Ah, stupid me. Well, it turns out that nothing can really be done, the only option is to give it to the bridge and another router. It's a bit strange that Vectra giving a new router does not give you the ability to change its more advanced functions. The only question is why on the previous router from Arris it was possible to log in normally
  • #10 19429223
    artbi881
    Level 30  
    Help: 130
    Rate: 264
    The answer is simple: to prevent the end user from fiddling with the settings with a later password, I CHANGED NOTHING AND DID NOTHING, this is the case 99% of the time.
  • #11 19483946
    -Zuzia
    Help: 15
    Rate: 89
    Few other cables give access to this model, so we are rather dealing with excessive "care" of Vectra/MM. I also thought that it is impossible to log in to this modem from Vectra/MM, but it is not true, the old recipe given on this forum, Wykop and in several other places still works.
  • #12 19556113
    blazejwiecha
    Can you post an old recipe? I'm trying to get into this modem router myself :(
  • #13 19556267
  • Router ownership and liability warning
    #14 19556866
    -Zuzia
    Help: 15
    Rate: 89
    Erbit wrote:
    I have a different opinion. I will only ask rhetorically - whose property is the router in question?
    Without waiting for an answer, I will add that by "hacking" your device, you can be held liable depending on the damage caused. Yes, I know, no hair has fallen off anyone's head yet (probably).
    Vectra doesn't care at all, checked on the hotline, they see changes in the modem configuration and they are completely hanging and fluttering, colloquially speaking :) They didn't even lift a finger to overwrite it.
    blazejwiecha wrote:
    Can you post an old recipe? I'm trying to get into this modemrouter myself :(
    I will not write so that no one will accuse me of encouraging something bad. Use the search engine, this recipe is here on the forum, the thread is quite a few years old.
  • #15 19556872
  • #16 19556880
    -Zuzia
    Help: 15
    Rate: 89
    Erbit wrote:
    I understand it all. I call this state of affairs "all is well as long as it is well". Worse, when it stops being good, then some people stop blowing.
    In theory, you're even right. But in practice this has been done for years, Vectra does not pursue customers for resetting the modem and setting, for example, Wi-Fi configuration. And in an old thread, even their employee spoke :)
  • #17 20217415
    lozelik
    I ran into this problem as well and was a bit confused :) The answer in my case was an empty username and an empty password (sic!). After changing the username and password, login is performed using the changed password and an empty username.
  • #18 20254493
    daredave
    I confirm! In my case also empty login and password! Way to go. I've been looking for this for 3 months :) Thank you again!
The discussion revolves around a login issue with the Technicolor CGA2121 router, where users experience continuous page refreshes after entering their credentials. Various suggestions are made, including checking the IP address (192.168.0.1) and using default credentials (homeu/homep). Some users report that logging in with a customer number and PESEL as a password does not work. It is noted that certain ISPs, like Vectra, restrict access to the router's GUI, requiring users to switch to modem mode and use their own routers for full control. A workaround mentioned involves using an empty username and password for successful login. The conversation highlights frustrations with limited access to router settings and the implications of ISP restrictions on user control.
TL;DR: One user reports the CGA2121 login loop fixes by using "empty username and an empty password," then setting a new password. This FAQ helps Vectra/MM owners who ask how to log in or manage a CGA2121 when the page keeps refreshing. [Elektroda, lozelik, post #20217415]
Why it matters: It speeds up troubleshooting and shows when to switch to Bridge mode and use your own router.
How do I fix the CGA2121 login page that keeps refreshing?
Submit the form with both fields blank first. One user solved the loop using an "empty username and an empty password." After you log in, set a new password. Then continue logging in with an empty username and your new password. How-To:
  1. Open the router’s web interface.
  2. Leave username and password empty and submit.
  3. Set a new password; log in using empty username + new password. [Elektroda, lozelik, post #20217415]
Why can’t I access the CGA2121 admin panel on Vectra/MM?
Vectra/MM often locks the local GUI on issued units. As one expert noted, "they don't give the retailer access to the GUI of the modem router." Manage the device via the subscriber portal instead. If you want full control, switch to Bridge mode and connect your own router. This is the common path when the GUI is disabled locally. [Elektroda, KOCUREK1970, post #19428905]
What does Bridge mode actually do on the CGA2121?
Bridge mode disables routing on the gateway and leaves you with modem-only operation. In the thread’s words, "Bridge is just a modem." Use this when you prefer running your own router for configuration, security, or advanced features. It’s the practical workaround when the ISP locks the GUI. [Elektroda, KOCUREK1970, post #19429116]
How do I switch the CGA2121 to Bridge mode using Vectra’s portal?
Use the subscriber portal to change the device mode. Steps:
  1. Log into your Vectra subscriber portal.
  2. Change operating mode to Bridge.
  3. Connect your own router’s WAN port to the modem and configure your router. This approach restores full control on your own hardware and avoids the locked GUI. [Elektroda, KOCUREK1970, post #19428905]
What IP and defaults should I try if blank credentials don’t work?
Browse to 192.168.0.1. Some firmware loads suggest Username: homeu and Password: homep. If the page still loops, try another browser to rule out a client issue. If none of these work, your ISP may have disabled local access. In that case, manage via the portal or use Bridge mode with your own router. [Elektroda, sosarek, post #19428723]
Do admin/admin or customer number + PESEL ever work on CGA2121?
Some users suggest trying admin/admin. Others mention the customer number as the login and PESEL as the password. Results vary by ISP provisioning and firmware. These combinations won’t help if your ISP has disabled local GUI access. Try them only if blank credentials and known defaults fail. [Elektroda, artbi881, post #19428729]
I tried different browsers and devices and the login loop persists. What does that indicate?
A user reported testing multiple browsers and devices with no change. That points to the device or ISP configuration, not your browser. If your unit is ISP-locked, switching browsers will not resolve access. Consider the ISP portal or Bridge mode with your own router for management. [Elektroda, Jasiek24312412, post #19428727]
My older Arris allowed login. Why doesn’t this Technicolor from Vectra?
A user found the Technicolor CGA2121 had no accessible settings while the earlier Arris did. They concluded the only practical path was to enable Bridge and attach another router. Different vendor firmwares and ISP policies explain the change in accessibility. [Elektroda, Jasiek24312412, post #19429199]
Why does Vectra lock advanced settings on the CGA2121?
One participant put it plainly: to stop end users from changing settings and later claiming, "I CHANGED NOTHING AND DID NOTHING." ISPs reduce support costs by limiting changes that can break service. This policy leads to fewer misconfiguration tickets and faster support resolution. [Elektroda, artbi881, post #19429223]
Is it legal or safe to bypass restrictions to access the UI?
A community moderator warned that the device belongs to the ISP. By "hacking" it, "you can be held liable" if damage occurs. Even if enforcement seems rare, you assume risk. Use the official portal or Bridge mode for compliant management. [Elektroda, Anonymous, post #19556267]
Will Vectra overwrite my changes if I alter the modem’s configuration?
One user called Vectra and reported that changes were visible to support but not reverted. In their words, support "didn’t even lift a finger to overwrite it." Policies can change, but this suggests limited enforcement in that case. Proceed understanding this can be an edge case, not a guarantee. [Elektroda, -Zuzia, post #19556866]
What mode options will I see in Vectra’s portal?
Users report only two choices: Router and Bridge. There is no separate “modem” label in the menu. If you want modem-only behavior, choose Bridge. Then manage networking with your own router hardware. [Elektroda, Jasiek24312412, post #19428976]
After changing the password, what username should I use to log in?
Continue using a blank username. Enter only the password you set during the first successful login. A user confirmed that after setting credentials, the username remains empty while the password is required. This behavior resolves the refresh loop for that unit. [Elektroda, lozelik, post #20217415]
How long did it take users to find the blank-credentials fix?
One user searched for 3 months before discovering that an empty username and password worked. This underscores how nonstandard credential handling can waste time. Try the blank-credential method early when facing refresh loops. It may save hours of troubleshooting. [Elektroda, daredave, post #20254493]
Is there a known "old recipe" to access the CGA2121 UI on Vectra/MM?
A community member said the old method still works and appears across multiple forums. They declined to post it, suggesting users search existing threads. This indicates historical workarounds exist but may involve unsupported steps. Consider Bridge mode for a supported path. [Elektroda, -Zuzia, post #19483946]
