No WiFi Connection on Technicolor CGA2121: Can't Access Router or Network, Incorrect Password
grzeslaw87 23373 5
  • Default Wi‑Fi SSID and router login mismatch
    #1 19133701
    grzeslaw87
    I have the following problem:
    today I was connected to the technicolor CGA2121 router in the Play network. The fitter said that they only connect the power cable and you only need to connect via wifi. I say ok, nothing simpler and here the stairs began ... there is no network with the name on the sticker of the router ... there are two others:
    1. "2.4-Vectra-WiFi-******"
    2. "5G-Vectra-WiFi-******"
    Where asterisks are the last 6 characters of "CM MAC"
    I tried to connect to both using the key from the router but the password is incorrect.
    After connecting the laptop with a cable, the internet works fine.
    I entered the address 192.168.0.1. and it seems to be connected to the router. You need to log in, but none of the usernames and passwords match. I also checked the login/password: "admin" and "homeu" "homep" and lipa..
    Anyone can help???
    Thanks in advance, best regards :)
  • #2 19133948
    -Zuzia
    Help: 15
    Rate: 89
    grzeslaw87 wrote:
    Anyone can help???
    Hotline or Play chat.
    gruszka
    There is a "WPS" button on the router, and there is also a wi-fi connection option on the smartphone.
  • #4 19134103
    grzeslaw87
    The hotline and chat rooms couldn't help me. But using WPS I was able to connect my laptop TV and phone to the router. But it doesn't change the fact that I still can't connect using a password (I need a cleaning robot to connect because I don't have the WPS option there). And I still don't know how to log in to 192.168.0.1
  • #5 19134140
    -Zuzia
    Help: 15
    Rate: 89
    WPS is convenient but not very secure, you can use it temporarily, but you have to bother Play support until it works, to use the WiFi password and log in to the modem.
    The only thing you can do yourself is to reset to factory settings with the button on the back of the modem, use a toothpick and try the password on the sticker again.
  • #6 19703604
    jglemp
    click on the "Confirm" button, leaving both windows blank.
    ps got me thinking about how much time it took...
