SodaStream Black - Water Dispensing from Right Side Valve Post-Warranty Service
Spakey 24789 5
  • Water leaks from the right-side valve after warranty rejection
    #1 19441026
    Spakey
    Rate: 13
    Hello, I'm not sure if I chose the right section.
    I have a sodastream, unfortunately the service rejected the warranty because there were traces of children carbonating the juices.
    he sent the device back to me, it dispenses water from the visible valve on the right side, which I hold with my finger.
    I'm posting a link to the video https://drive.google.com/file/d/1qTXIxIGBco9ha6MlXvd0pGu22eErPc2v/view?usp=sharing
  • #2 19450490
    gelob
    Rate: 81
    This is probably a safety valve that should release when the pressure is too high, but from what you can see, it doesn't hold at all.
    check out this repair video:
  • #3 19451559
    Spakey
    Rate: 13
    I took it apart and it fell apart in my fingers. It was polluted inside.
  • #4 19482071
    Spakey
    Rate: 13
    Finally, my father-in-law threaded a new nut for me, I screwed it in and it works. Alternatively, the spring can be replaced in the future.
  • #5 20489370
    111lisu
    Rate: 52
    My valve is stuck, but it's super lubricated. I lightly hit it with a knife and it runs away.
  • #6 20710292
    sybeer
    Rate: 9
    >>19450490
    I'm starting to dismantle my SodaStream
