[Solved] Automatic retrieval of SHA-1 key by ESP8266 in Solaredge API
bryko 723 6
  • #1 19455826
    bryko
    Help: 49
    Rate: 103
    Hi
    Based on an ESP8266 and a 5110 display, I have made myself such a small preview of the Solaredge inverter parameters. The ESP connects using the standard API over https to the Solaredge platform and downloads the data. For communication over https, the SHA-1 key is specified
    const char fingerprint[] PROGMEM = "69 01 51 C2 49 16 4A 38 93 FA 7C A8 E4 BC 61 9A 25 4B 98 BF";
    Unfortunately every so often the key changes and the reading stops working. Is there any way for ESP to fetch the key automatically as the browser does? I am not a programmer, so I apologise in advance if the question is lame.
  • #3 19455884
    bryko
    Help: 49
    Rate: 103
    thank you for the quick hint, I will fight
  • #5 19456583
    bryko
    Help: 49
    Rate: 103
    Thank you @khoam
    I was able to get the communication working using Root CA. From what I've checked in my case it's valid until XI.2031, so I'll manage without the automatic update.
    I am closing
  • #6 19458164
  • #7 19458808
    bryko
    Help: 49
    Rate: 103
    Authorisation using Root CA was used
✨ The discussion revolves around the challenge of automatically retrieving the SHA-1 key for HTTPS communication with the Solaredge API using an ESP8266 microcontroller and a 5110 display. The user initially faced issues when the SHA-1 key changed, disrupting data retrieval. A solution was proposed to use the Root CA certificate for site verification, which is typically valid for several years, thus eliminating the need for frequent key updates. The user successfully implemented this solution, confirming that the Root CA certificate is valid until XI.2031. Additional suggestions were made regarding the automatic updating of certificates for connections to multiple servers.
