How to retrieve data from the storm.dzis.net API via ESP8266 in the Arduino IDE?
Marcinolak xD 1665 9
How can I retrieve data from the storm.dzis.net SOAP API on an ESP8266 in the Arduino IDE and store it in variables?
Yes — on an ESP8266 you can talk to the SOAP server by sending XML in an HTTP POST request, then parse the XML response into variables [#18430502] Use SOAPUI with the WSDL to generate and inspect the raw request, because it shows the full XML, headers, SOAPAction, and Content-Length you need to reproduce on the ESP8266 [#18430502] If you do not want to parse SOAP directly on the ESP8266, another option is to put a PHP broker on a server: the ESP8266 talks to the broker over HTTP, and the broker handles SOAP communication with storm.dzis.net [#18430502] Since SOAP is not trivial to implement generically, start by learning the ESP8266 networking basics and then send the exact XML body you captured from SOAPUI [#18425925][#18430502]
  • #1 18421953
    Marcinolak xD
    Help: 9
    Rate: 178
    Welcome.
    How can I retrieve data (having an API key) from the storms.dzis.net website?
    I'm keen on some examples of how to call queries. I am programming the whole thing in an Arduino IDE environment.
    I would like to make a mini "weather station" with a storm warning function.
    https://burze.dzis.net/?page=api_interfejs
    https://burze.dzis.net/soap.php?wsdl
  • #2 18422017
    szwagros
    Help: 232
    Rate: 271
    Want to make a SOAP client on an Arduino? Thick...
  • #3 18422046
    Marcinolak xD
    Help: 9
    Rate: 178
    And what can it be realised on?
    I don't need to use this site at all. Do you know of any others providing an API key?
  • #4 18422431
    Slawek K.
    Help: 259
    Rate: 1303
    I hope you distinguish between Arduino (AVR) and ESP8266 ;) .
    Greetings
  • #5 18422469
    Marcinolak xD
    Help: 9
    Rate: 178
    Greetings
    Colleague @szwagros probably not. Reminder. It's not an Atmega...
    Back on topic. My board is a NodeMCU V3. I have the environment set up to work with this board. I just don't have an idea for a sensible software (and how to go about it). I don't mean a "ready-made" one, but a way of getting data from the website (storms.dzis.net) and writing it to variables.
    Is this even possible on this board? .
  • #7 18425083
  • #8 18425087
    Marcinolak xD
    Help: 9
    Rate: 178
    Slawek K. wrote:
    Here is another service https://antistorm.eu/deweloperzy.php
    Just use JSON.
    Greetings
    Well yes, but unfortunately it does not support my locality.
    There is no method to make a SOAP/WSDL client on ESP?
    krzbor
    Help: 42
    Rate: 1072
    SOAP is not simple if we want to program it universally. However, at the lowest level it is simply XML sent via the POST method. Often the easiest way is to craft a query and just send it. I recommend the SOAPUI tool - it creates functions based on WSDL and allows you to send queries and receive a response. An interesting feature to set in the programme configuration is the RAW view of the query - that is, the entire complete query.
    You can see exactly what the query looks like and what the headers look like. You can get rid of "Accept-Encoding" if you do not want a packed response. The "SOAPAction" parameter is very important. - most servers require it. Also important is "Content-Length", which tells you the length of the text after the header (the length of the XML file calculated in bytes). The server response is also XML. In SOAPUI you can also see it as "RAW". Reading data from the response should be based on analysing the XML, which often has a namespace definition. However, it can be simpler to find the right part as a string. This is not elegant, but it works.
    Another solution is also worth considering - if you have access to a server with PHP you can make a 'broker' on it. It will broker the communication - you ask the broker, and it communicates via SOAP with "storms.dzis.net" and sends the answer in a convenient form. The advantage of the solution is that you can do the communication with PHP over http rather than https.
The discussion revolves around retrieving data from the storms.dzis.net API using an ESP8266 in the Arduino IDE. The user seeks guidance on making API calls, specifically for a mini weather station with storm warning capabilities. Responses highlight the distinction between Arduino and ESP8266, with suggestions to utilize JSON for data retrieval. Alternatives to the storms.dzis.net API are mentioned, and the complexity of implementing a SOAP client on the ESP8266 is acknowledged. Recommendations include using SOAPUI for crafting XML queries and understanding the necessary headers for SOAP requests.
