[Solved] Updating Skymaster STB HD N-6 Software for DVB-T2 Program Reception - No Video, Only Audio
Gumek54 24027 6
  • #1 19494712
    Gumek54
    Rate: 39
    As in the topic - the receiver does not receive DVB-T2 programs. There is sound but no picture. Is it enough to only update the software? If so, where can you find the current software.
    MODEL :D STB-N6
    Software version 133 [9-09-2016 17:14:02 r 480
    Hardware version: 20
  • #3 19494818
  • #4 19495360
    Gumek54
    Rate: 39
    The designation is DVB-T2 on it
  • #5 19495380
    sosarek
    Help: 9320
    Rate: 15534
    Take a look at the link from # 2 - do you see anything about h.265 and HEVC?
    This is equipment from five years ago - then no one thought about DVB-T2, you can buy it on Allegro for just over PLN 20. so understand that you need to replace your hardware.
    Z
    Pka, Poznań, 60-850
  • #6 19495437
    kaem
    Help: 66
    Rate: 296
    DVB-T2 is just a modulation standard. You still need an appropriate codec, and only the newest devices have one.
  • #7 19495610
    Gumek54
    Rate: 39
    Electro-waste decoder.
The Skymaster STB HD N-6 receiver is unable to receive DVB-T2 programs, resulting in audio without video. Users suggest that updating the software alone will not resolve the issue, as the hardware does not support the necessary codecs for DVB-T2 reception. Recommendations include replacing the equipment with a newer model that supports the required standards, as the current device is outdated and lacks compatibility with modern broadcasting formats like h.265 and HEVC.
