Tafel GV8700 Shows Empty Water Tank After Start, Even with New Pump - Need Help
Manzoor 2349 1
  • #1 19538877
    Manzoor
    Hi
    Tafel GV8700 shows water tank empty after start and works when making it stand the water tank at the top.
    I have changed the water pump still problem persists.
    I would appreciate any help .
  • #2 19540088
    skała
    Help: 29
    Rate: 117
    Check the water level sensor if present on this model.
    Often, such a fault occurred in Philips irons, just a small float with a magnet hung in the sensor tube horizontally in the water and did not turn on the reed switch.
    Best regards.
