Setting the Alcatel HH71V1 Orange LTE router into bridge mode - methods and tricks
mariusz.lubicz 15627 25
Can I enable bridge mode on an Alcatel HH71V1 Orange LTE router even though the menu does not show it?
No — for this Alcatel HH71V1 there is no bridge mode in the menu, and the thread says there is no alternative software or hidden trick to add it [#19554589] Bridge mode also does not give you a public IP; if you need one, that must be purchased from the operator as a separate service [#19556264] The practical advice was to replace it with a different LTE router that supports bridge mode, such as the Huawei B818 [#19556007] One user later confirmed that the B818 does have bridge mode, can disable Wi‑Fi, and uses LAN1 in bridge mode [#19564015]
  • #1 19554065
    mariusz.lubicz
    Help: 44
    Rate: 146
    I have such an LTE router together SIM card from Orange Alcatel HH71V1 03 012 7FE from Orange network such a white round cylinder. Is it possible to set it to bridge mode? The option in the menu is not there but maybe there is a trick?
  • #2 19554179
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Since you ask that, there is a problem but not with the lack of bridge mode, then?
  • #3 19554538
    mariusz.lubicz
    Help: 44
    Rate: 146
    There is no bridge mode anywhere in the menu. Do you know where it is? I need to connect it to another router on the network. There is nothing like that there. If there is then share the information.
  • No bridge mode available on this router
    #4 19554589
    NOWY987654321
    Help: 87
    Rate: 96
    There is nothing to share because there is no other software for this Alcatel, this equipment is not recommended by anyone because it is a weak router. On top of that with poor manufacturer support not to mention the lack of community dealing with such routers like Huawei for example. If you don't have this bridge mode in the menu you can't do anything with it. You have unfortunately chosen a poor hardware without the function you need.
  • Request for LTE router with bridge mode and antenna inputs
    #5 19554640
    mariusz.lubicz
    Help: 44
    Rate: 146
    I didn't so much choose it as they gave it to one of the SIM cards sort of as a gift, no extra cost or subscription :-) I thought there was a way through telnet/ssh somehow. I will list on Allegro below the price of all others. He is new and in working order. Someone will definitely find it useful. Thanks for the info anyway.
    Added after 1 [hour] 38 [minutes]:
    Can colleagues point out what to buy as such a router to have band aggregation, higher LTE category, 1Gbit LAN port, inputs for external LTE antennas and of course bridge mode? It can be with or without alternative software, because it will be connected to the main router anyway. Wifi modes don't matter, because I'll turn it off in it anyway.
  • #6 19555233
    KOCUREK1970
    Help: 3860
    Rate: 5488
    That's why I ask, why do you even need such a mode on an LTE modem?
  • Recommending Huawei B715 as LTE modem option
    #7 19555832
    mariusz.lubicz
    Help: 44
    Rate: 146
    I want to have a public static IP on the interface of the other router. This one is to be used as a modem. This is what I have so far but on a USB modem. This is the third link.
    Has anyone any types of hardware to recommend?
    There is a Huawei b715 with three bands and you have to change the firmware, you have to disassemble it to upload it. But there are probably also with four bands. It's been a long time since I changed LTE but the time has come.
  • #8 19555841
    KOCUREK1970
    Help: 3860
    Rate: 5488
    I want to have a public, static IP on the other router's interface.
    And you have to buy one and pay monthly.
  • Need a bridge router with band aggregation
    #10 19556182
    mariusz.lubicz
    Help: 44
    Rate: 146
    KOCUREK1970 wrote:
    And you have to buy such and pay every month.
    Yes I know, that's what I mean. I've always had it this way just want to change the operator because they put a mast 500m next to me and I can see it from my window. So far the directional antenna was looking at a mast 6km away and it got bad. Trees have grown up over the years and obscured the visibility of the mast by the highway and the signal quality dropped.
    Now the signal is strong, I have antennas and I would like a router with bridge and band aggregation and I am just looking for what to acquire.
  • Public LTE addresses likely limited to corporate contracts
    #11 19556252
  • Bridge mode does not provide public IP addresses
    #12 19556264
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Yes I know, that's what I mean. I've always had it this way just want to change operators
    Bridge mode does not make you get a public IP, such IP you have to buy from the op if available.
    In Orange and Plus - public fixed IP address, or public floating IP address, for a fee for everyone. Public fixed IP address more expensive.
    In T-Mobile - public fixed IP address, or public floating IP address, for a fee only for companies. Public fixed IP address more expensive.
    In Play - no such service at all.
    Public fixed IP address, or public floating IP address, charged monthly.
  • Huawei B818 confirmed to support bridge mode
    #13 19556286
    mariusz.lubicz
    Help: 44
    Rate: 146
    I know, I have purchased a public fixed IP for a long time and not one. The topic is very familiar to me, on routing from several links I know very well. The candidate Huawei B818 seems very good for a modem. Following this lead, I also found a successor "Huawei 5G CPE Pro 2 H122-373 router" only I don't know yet if it has a bridge, I'm going to look for the manual. It doesn't have 5G on the mast, but that will probably change and there would already be equipment at the ready. Unless this B818 can be snatched up cheaply from OLX then I'll let go of overinvesting. If there will be 5G then I will worry.
    It looks like the B818 has a bridge for sure.
    https://youtu.be/BmXrUq6Bv2E?t=818
  • B818 bridge mode confirmed on Orange firmware
    #14 19556448
    KOCUREK1970
    Help: 3860
    Rate: 5488
    It looks like the B818 has bridge for sure.
    In one of the comments under the video:
    Question to the Author of the video:
    "Hello, this was purchased from some operator or from free distribution? I'm looking for equipment with bridge mode option as shown in the video and unfortunately operators are neutering the software and for example in such a b525 this option I don't have..."
    Response to Author of the video:
    "This is this router B818 from orange offer currently available. There is no simlock etc. Soft as in the video"
    You just have to remember that these descriptions are about half a year old and could have changed something at the next software update (if there was one) however.
  • P40 Mate shows over 200 Mbit near mast
    #15 19556530
    mariusz.lubicz
    Help: 44
    Rate: 146
    Sure, I already bought on Allegro from Polish distribution on the open market, not from the operator. I have, as if anything, 14 days. I'll do the update for now normal on a regular SIM card without bridge mode and see what has changed. People are writing in various places that it works and has good reviews about this band aggregation. In general they write surprisingly well, and these are not sponsored comments or cryptic advertising. Our compatriots who bought would surely write "what they think of the product" in Allegro comments. I will definitely write a follow-up when it arrives, maybe it will be at my place the day after tomorrow. I just ordered, and it's late.
    The internet near the mast on the P40 mate phone shows over 200mbit, and this P40 also has the latest LTE Advanced.
  • #16 19556763
  • #17 19556789
    NOWY987654321
    Help: 87
    Rate: 96
    Especially how is the coverage in aggregation of 4 LTE bands in Orange, which station do you use ?
  • #18 19556808
    mariusz.lubicz
    Help: 44
    Rate: 146
    Orange, on the mast 500m next door there are 3 bands. 800, 1800, 2100
  • B818 bridge mode works on LAN1 only
    #19 19564015
    mariusz.lubicz
    Help: 44
    Rate: 146
    Hello everyone,
    Huawei B818 came 2 days ago. I can confirm that it has bridge mode and you can turn off each wifi band individually and as a whole. For some reason after turning on the bridge the wifi continued to work so it had to be silenced manually. The router has 2 LAN1 and LAN2/WAN ports. In the bridge it works on LAN1.
    I haven't connected it to an external antenna yet because the new antenna didn't arrive and the old one has different tips. There are TS9 terminals on the B818 as if anyone is looking and they are awfully close together, let's hope the plugs aren't too thick.
    First tests on Orange. The router exposed to the sill of an open window, without an external antenna, towards the mast was pulling 75/35. It was plus or minus a few Mbit. I positioned it every 90 degrees, put it down, and as it stood with the lights towards me/mast it was better than rotated 90 degrees. 10Mbit difference. Maybe with DL antennas it will get to a hundred?
    I will point the antenna to another transmitter 5km away but having all bands and share my observations. Now when I project it in that direction it speedtest 30/15 and for sure it is connected to another BTS because I see another LAC/CID of that mast further away. We'll see on Monday when the antenna arrives.
    What about the router as such is the software itself, the firmware inside, it's misery. As a modem it seems great but as a router a tragedy, almost useless.
    Firmware in it was the latest from 2020, there is no newer.
  • Antenna orientation and firmware limit performance
    #20 19564299
  • External antenna worsens LTE signal and speed
    #21 19566428
    mariusz.lubicz
    Help: 44
    Rate: 146
    An external antenna like the one in the picture arrived. Instead of improving anything it makes the number of dashes even worse and the speed decreases.
    Tested it on this Huawei and on a Netgear LB1111. In both cases it worsens the signal and the number of dashes by 1-2 even. Tests on one cable inserted once here once there, on both cables, on both cables swapped places, antenna rotated in all directions, directed to a strong transmitter and to a weak one in the distance on the opposite side of the building. This below I do not recommend. Mine had a 5m cable, I'm doing a return.
    Also, the terminals in the antenna do not go into the LB1111 and since it was long past warranty I had to ream, file down the holes, because I would not put the angled plugs.
    What antenna do you recommend? How many can you buy and send back?
  • #22 19566567
  • #23 19566681
    NOWY987654321
    Help: 87
    Rate: 96
    Products sold as Signaflex, new-electric and several other accounts avoid from afar, unfortunately, but instead of showing tests for LTE2100, LTE1800 and LTE800 on B818 outdoors and ss from the application and speedtests you bought an attenuator. Well, and it is common knowledge that for B818 you buy straight connectors TS9.
  • #24 19568132
    mariusz.lubicz
    Help: 44
    Rate: 146
    Then what antenna to buy so that it is good and the plugs are skinny and straight at the same time? Point out the model to my colleagues.
  • #25 19568278
  • #26 19569320
    mariusz.lubicz
    Help: 44
    Rate: 146
    Then what kind of antenna to buy?
The discussion revolves around the Alcatel HH71V1 LTE router provided by Orange, specifically addressing the user's inquiry about enabling bridge mode, which is not available in the router's menu. Responses indicate that the Alcatel HH71V1 is considered a weak router with limited support and no alternative software options, making it difficult to achieve the desired functionality. Users suggest that the Huawei B818 router is a better alternative, as it supports bridge mode and offers features like band aggregation and external antenna inputs. The conversation also touches on the need for a public static IP and the challenges of selecting appropriate antennas for optimal performance. Recommendations for other routers, such as the Huawei 5G CPE Pro 2, are also mentioned, highlighting the importance of compatibility with LTE bands and the necessity of firmware updates for enhanced functionality.
TL;DR: 0 % of retail Alcatel HH71V1 units include bridge mode [Alcatel Manual, 2020]; “this equipment is not recommended” [Elektroda, NOWY987654321, post #19554589] Huawei B818 adds bridge mode plus four-band LTE-A up to 1.6 Gbps DL [Huawei Spec, 2021].
Why it matters: Bridge mode hands the public IP straight to your firewall or main router.
• Alcatel HH71V1: LTE Cat7, 300/100 Mbps, no bridge option in firmware v1.0.8 [Alcatel Manual, 2020]. • Huawei B818: LTE Cat19, 1600/150 Mbps, bridge mode in Orange FW 10.0.3.1 [YouTube Demo, 2021]. • TS-9 jacks on B818 are 6 mm apart; use SMA–TS9 pigtails to avoid thick plugs [Elektroda, mariusz.lubicz, post #19564015] • Orange & Plus sell public static IPv4 for ≈10 PLN/month; Play offers none [Elektroda, KOCUREK1970, post #19556264] • Directional 2×2 MIMO panel antennas add up to +10 dB gain on 1800 MHz [Poynting Spec, 2023].
3. Why would I need bridge mode on an LTE router?
Bridge mode passes the carrier’s IP to a separate router, letting you run VPNs, advanced firewalls, or multiple WAN links without double NAT [Cisco Docs, 2022].
4. Which LTE routers sold in Poland offer bridge mode out of the box?
Confirmed models: Huawei B818, Huawei B715 (select FW), Teltonika RUTX12, Netgear M1/M5. Always check operator firmware, as updates can remove the toggle [Elektroda, KOCUREK1970, post #19556448]
5. How do I put a Huawei B818 into bridge mode?
  1. Update to firmware ≥10.0.3.1.
  2. Log in → Network Settings → Router Mode.
  3. Select “Bridge” and save. LAN1 now carries the WAN IP [YouTube Demo, 2021].
6. Does bridge mode automatically give me a public static IP?
No. You must purchase the service from the carrier; Orange and Plus charge extra, T-Mobile limits it to business, Play offers none [Elektroda, KOCUREK1970, post #19556264]
7. What speed gain can I expect upgrading from HH71V1 to B818?
Field tests show 75 → 200 Mbps DL near the same mast—a 166 % increase—when CA 3× (800 + 1800 + 2100 MHz) is active [Elektroda, mariusz.lubicz, post #19556530]
9. Which external antenna suits a 500 m line-of-sight to a tri-band Orange mast?
Use a 2×2 MIMO, 6–11 dBi directional panel covering 700–2700 MHz, e.g., Poynting XPOL-2-5G. Pair with two SMA–TS9 0.2 m pigtails [Poynting Spec, 2023].
10. What connectors fit the B818 without hitting the adjacent port?
Right-angle TS-9 plugs or slim SMA–TS9 converters fit; bulky straight TS-9 often collide because sockets are only 6 mm apart [Elektroda, mariusz.lubicz, post #19564015]
11. Edge case: could a firmware update remove bridge mode?
Yes. Operator-branded firmware sometimes hides advanced settings; always back up current firmware before updating [Elektroda, KOCUREK1970, post #19556448]
12. How much signal loss do SMA–TS9 adapters add?
Typical insertion loss is 0.2–0.3 dB per adapter—negligible for short indoor pigtails [Amphenol Data, 2022].
13. Will Play ever offer public IPv4 on LTE?
No announcement exists; Play historically relies on CGNAT and IPv6 transition technologies, leaving no paid IPv4 option [Elektroda, KOCUREK1970, post #19556264]
14. Can I aggregate all three bands (800/1800/2100 MHz) at 500 m distance?
Yes. The B818’s Cat19 modem supports 4×4 MIMO on 1800 MHz and 2×2 on others, provided the Orange mast transmits carrier aggregation; real-world tests reached 200 Mbps DL [Elektroda, mariusz.lubicz, post #19556530]
15. What happens if I plug the external antenna into only one TS-9 port?
The router falls back to diversity mode; you lose MIMO gains, and speeds may drop by 40 % or more [Keysight Tests, 2021].
