Low volume of Internet broadcasts on the Play TV box now 2 decoder
filip.warecki 46584 6
  • #1 19567766
    filip.warecki
    Rate: 71
    Hello. I recently got a decoder like the one in the title. The problem I have is that the volume of everything transmitted over the Internet is low. The TV received by the antenna has the correct volume.
  • #2 19568527
    andken999
    Help: 58
    Rate: 167
    Volume on the decoder remote control
  • #3 19568953
    filip.warecki
    Rate: 71
    The volume is at max. The sound is quiet when playing something over the Internet. The antenna is ok.
  • #4 19569351
    sosarek
    Help: 9320
    Rate: 15532
    Well, the web application doesn't have a separate volume control?
    Z
    Pka, Poznań, 60-850
  • #5 20040114
    WincentaW
    Rate: 55
    Hello. I had the same experience. The sound from the amplifier was quiet; after connecting to the TV, it was the same. Resetting the remote control settings helped. To restore the remote control to factory settings, press and hold OK and Home (Play Now). And that's it. Good luck.
  • #6 20172709
    michash7
    Rate: 22
    I had exactly the same symptom and this combination of buttons on the remote control solved the problem immediately.
  • #7 21695411
    sunmoon
    FYI, the same symptom occurred on the new Play Box TV decoder I received these days. In addition, the volume control and mute (from the remote control, of course) did not work. I OK Home helped immediately. Years later, thank you for the solution.
The discussion concerns low audio volume on Internet-based broadcasts played through a Play TV Box / Play Box TV decoder, while antenna TV audio remains normal. Suggested checks included the decoder remote volume setting and whether the web application has its own volume control. The issue was ultimately resolved by resetting the remote control to factory settings using the OK + Home (Play Now) button combination, which restored normal volume and mute control for Internet playback.
