[Solved] Netia EvoBox: Creating Custom Channel List & Organizing Available/Unavailable Channels
etet 27468 11
Can I create my own channel list in Netia EvoBox and organize or hide the many unavailable channels?
Yes — you can create favorite and freely named channel lists, then filter the decoder so only those channels are shown, which helps hide the dozens of unavailable ones [#19201090] To add channels, use the channel list or EPG and choose the option to add them to favorites; after that, “Favorites” appears in the filtering menus [#19201090] To make the favorites filter the default after startup, switch to Favorites in one of the channel list views and then select a channel with WATCH; that saves the setting [#19207650] You can also reorder channels inside a favorites list: open the selected list, choose a program, press Options on the remote, go to Actions → Order, move the channel, then confirm [#19428508] The interface is described as unintuitive, and the available list views can be confusing; besides custom ordering, lists can also be sorted alphabetically or by original channel numbers [#19241312]
  • Custom channel list on Netia EvoBox unavailable
    #1 19135253
    etet
    Help: 5
    Rate: 65
    Hello. Is it possible to set your own channel list in evobox from netia? At the moment, the order is random (more precisely, it is set by the operator) and I have mixed 80 channels available with 200 unavailable. I've dug through all the options and I'm 99.99% sure it won't work. But maybe it's somehow buried like that? At the moment I watch at most the first 20 channels because searching 300 (of which 220 unavailable) is a drama.
  • #3 19135850
    etet
    Help: 5
    Rate: 65
    Something was configured there on 1 startup and that's it. There is nothing in the configuration to indicate the possibility of adding or removing a channel. There is a FAVORITE button on the remote but I don't know what it does. Nothing to see.
  • Startup setup only; no channel list editing
    #4 19135866
    sosarek
    Help: 9320
    Rate: 15529
    So maybe you should read the information that appears on the screen and not choose to search for all channels?
    I suggest you look at something called INSTRUCTIONS.
    Z
    Pka, Poznań, 60-850
  • Startup configuration only, no channel add/remove option
    #5 19135892
    etet
    Help: 5
    Rate: 65
    1. it so happens that the technician from netia turned it on
    2. it so happens that for several months I had all the channels available, so it was advisable to select them (although I do not know if it was possible to choose anything at all)
    etet wrote:
    There is nothing in the configuration to indicate the possibility of adding or removing a channel. There is a FAVORITE button on the remote but I don't know what it does. Nothing on the eye.
    I suggest you look at something called INSTRUCTIONS.[/quote]
    I suggest not to write nonsense.
  • #6 19135929
    sosarek
    Help: 9320
    Rate: 15529
    I suggest taking the remote control in your hand and going through the options available in the menu instead of whining that you can't.
    Z
    Pka, Poznań, 60-850
  • #7 19157848
    etet
    Help: 5
    Rate: 65
    I don't know, but I'll tell you.
  • Tips for adding and filtering favorite channels
    #8 19201090
    sebastianm
    Rate: 15
    I have had Evobox from Netia since December 2020. Since then, I have made several attempts to set up my own channel list. I did not find practically any descriptions in the manual or on the Internet, what was left was what someone suggested in this thread: the remote control in hand and click through the options in the decoder.
    For now I managed to define a list of favorite channels and when viewing the channel list I know how set the filter so that only your favorites are visible . You can also define your own freely named channel lists. They appear for selection when filtering next to "Favorites". There is no way to change the channel order.
    In my opinion, evobox support in terms of favorite channels, named channel lists and filtering is unintuitive. There are four different views of the channel list, each is handled a little differently, it's easy to get lost.
    Now I'm throwing in a short basic tips for favorites. If there is anything unclear or more interest, I will take pictures of the TV screen of key places.
    Tips:
    * filtering by list of favorite channels is not visible anywhere in the evobox start interface. Only after adding the first channel to favorites, this option becomes active, i.e. "Favorites" appears in various places of various channel filtering options. Previously, there is only "All", "Information", "Movie", etc.
    * adding a channel to favorites can be done from several views, for example from EPG (EPG button on the remote control). There, when browsing the options, there is "Add to favorites" (or something like that)
    * then, after adding one or more channels to your favorites, you just have to click various buttons on the remote control when you are in one of the several available views of the channel list. Up/down/right/left arrows to switch between subviews, 'options' button, sometimes OK
    * as I mentioned, I still get lost in the multitude of options. You can view the channel list in several ways from different places. In one of these views, you can set default filtering. At the start, the default filtering is "All". There, I switched the filtering to "Recently viewed" and ... that's what I left in the decoder :-) I don't know how to go back to that view and change it to "Favorites" permanently.
    To sum up: I added selected channels to the list of favorites, thanks to which I can switch to "Favorites" filtering in the EPG view. I don't know yet how to set "Favorites" filtering permanently as default. It's probably just a matter of time and re-clicking to accidentally get back to that screen where the default filtering is set.
  • #9 19201230
    etet
    Help: 5
    Rate: 65
    Thanks for the detailed answer. It's not good news though. I wonder what the person who designed one of the most important functions in this way was thinking. But maybe I should be glad anyway that I didn't have to install any suspicious app on my phone, the channels are not stored in the Chinese cloud and you don't need a Facebook account to watch.
  • Setting favorites filter as default on EvoBox
    #10 19207650
    sebastianm
    Rate: 15
    To close the thread: I was able to set my favorites list as default. Now, immediately after turning on the decoder, you can see only the channels that I previously marked as favorites, the lists are not cluttered with dozens of unavailable items.
    It is done in such a way that on one of the few (in my opinion unintuitive) lists of channels, you need to select filtering by favorites, and then - and this is the key step - with such filtering, select a channel, actually switch to it by ' WATCH'. Then the filtering setting is saved and only the default channels are shown.
  • No custom sorting beyond alphabetical or original numbers
    #11 19241312
    etet
    Help: 5
    Rate: 65
    I confirm the above. Especially sentences with the word "non-intuitive" and all its variations. You can do exactly the same thing 15 times and each time it's a problem to get to a specific menu.
    I will add (because I don't think it was) that it doesn't necessarily have to be a "favorites" list. There you can do more of these lists.
    Well, it's not possible to sort the lists according to your own whim. You can either alphabetically by channel names or by original numbers.
  • Manual channel reordering via favorites and actions menu
    #12 19428508
    pjak1
    Rate: 25
    It is possible to set your own order of programs in the evobox, but it is not easy and pleasant.
    In the selection of the channel list, select FAVORITES on the selected list, select the program, then the physical button on the remote control Options, select ACTIONS, select ORDER, enter and the program you want to move to another position, confirm OK and move to the selected position. Press OK and then be sure to CONFIRM.
    And this is how we can make life easier for ourselves and others ?.
The discussion revolves around the Netia EvoBox and the challenges users face in creating a custom channel list. Users express frustration over the inability to reorder channels, as the default setup is determined by the operator, resulting in a mix of available and unavailable channels. Some users have discovered that while a favorites list can be created, the process is unintuitive and cumbersome. A solution was shared where users can set their favorites as the default view by filtering the channel list and confirming the selection. However, the overall experience is described as non-intuitive, with limited options for organizing channels beyond alphabetical or original numbering.
TL;DR: Evobox has four channel‑list views; setup is “unintuitive.” Use Favorites and named lists to filter channels and cut clutter. Add your first favorite to unlock filtering. [Elektroda, sebastianm, post #19201090]
Why it matters: This FAQ helps Netia Evobox users quickly organize channels, hide unavailable ones, and make everyday navigation faster.
How do I add channels to Favorites on a Netia Evobox?
Press the EPG button. Highlight a channel and choose Add to favorites. After you add the first favorite, “Favorites” appears as a filter across channel‑list views. Navigate using arrows, Options, and OK to manage lists. [Elektroda, sebastianm, post #19201090]
How do I set Favorites as my default channel list after power on?
Use this 3‑step method:
  1. Open any channel list view and set the filter to Favorites.
  2. Highlight a channel from that filtered list.
  3. Press WATCH to tune it; the box saves Favorites as default. This keeps only your selected channels visible by default. [Elektroda, sebastianm, post #19207650]
Where did the Favorites filter go? I can’t see it.
It remains hidden until you add your first favorite channel. Before that, filters show only groups like All, Information, or Movie. Add one favorite, and “Favorites” appears across the channel‑list views. Then you can filter to show only selected channels. [Elektroda, sebastianm, post #19201090]
Can I create multiple custom lists besides “Favorites”?
Yes. You can define your own, freely named channel lists and then filter by them. These lists appear alongside Favorites in the filtering options. It’s handy for separate kids’, sports, or news sets. [Elektroda, sebastianm, post #19201090]
Can I reorder channels in my list?
Yes, but it’s “not easy and pleasant.” Open your Favorites list, select a program, press Options, then Actions > Order. Choose a channel, press OK, move it to the desired position, press OK, and Confirm to save. Repeat for additional moves. [Elektroda, pjak1, post #19428508]
What sorting is available if I don’t manually reorder?
Without manual ordering, lists sort alphabetically by channel name or by the original operator numbers. Free drag‑and‑drop isn’t available outside the ordering function. Choose a sort that matches how you browse. [Elektroda, etet, post #19241312]
Evobox keeps reverting to All or Recently viewed. How do I make Favorites stick?
Set the filter to Favorites and then WATCH a channel from that list. This action saves the filtering as the default view. If you don’t tune a channel, the setting won’t persist across views. “WATCH” is the key step here. [Elektroda, sebastianm, post #19207650]
Why do I see so many unavailable channels on Evobox?
The operator lineup may include many entries you can’t watch. One user reported 80 available mixed with 200 unavailable, totaling 300 channels. This clutters browsing and slows navigation. Filtering or favorites help reduce the problem impact. [Elektroda, etet, post #19135253]
How do I hide unavailable channels from the list?
Mark the channels you actually watch as favorites. Switch the filter to Favorites, then WATCH a favorite channel to save this filter as default. After that, the list shows only your favorites by default. This removes the clutter of unavailable entries. [Elektroda, sebastianm, post #19207650]
The remote’s FAVORITE button does nothing. Is that normal?
Yes, until you add at least one favorite. The Favorites option isn’t visible anywhere before that. After adding a favorite, the Favorites filter appears in channel‑list views, and the feature becomes usable. [Elektroda, sebastianm, post #19201090]
Is the Evobox interface intuitive for channel management?
“Evobox support … is unintuitive,” and there are four different channel‑list views that behave differently. Expect to click around a bit to find options. Once favorites and filters are set, daily use improves. [Elektroda, sebastianm, post #19201090]
Can I manage channels via a phone app or cloud account?
Users report no extra app, cloud storage, or social login is needed. Channel management happens directly on the decoder. This keeps setup simple and local to your box. [Elektroda, etet, post #19201230]
The installer selected all channels during setup. Can I still customize later?
Yes. Regardless of initial setup, you can add favorites, create named channel lists, and apply filters from the decoder. These controls are available in the on‑screen menus anytime. [Elektroda, sebastianm, post #19201090]
