[Solved] Getting PIN Out of 2019 Citroen Jumpy BSI EL3 CEM00 Without Import Keys Using Autel IM508
matik185 6072 8
  • #1 19660321
    matik185
    Help: 13
    Rate: 75
    I have a Citroen Jumpy from 2019.
    The car came without import keys.
    PIN needed ..
    Autel IM508 will not embrace this BSI in the absence of keys.
    Maybe someone knows how to get the pin out of this BSI?
    • ST95128_BSI.rar (3.13 KB) You must be logged in to download this attachment.
  • #2 19660503
    adam7009
    Help: 656
    Rate: 1635
    and the pin from the engine? what driver?
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
    melas
    Help: 138
    Rate: 689
    You have bsi with LOCK unreadable only SMOK and the cheapest option is service and ordering a label with a code.
  • #4 19661992
    matik185
    Help: 13
    Rate: 75
    EDC17C60
    I bought KTAG ... I will read the EEPROM from the ECU, I hope that I will get the PIN from it
  • #5 19666855
    matik185
    Help: 13
    Rate: 75
    I enclose the EEPROM from the ECU ..
    ECU EDC17C60
    Jumpy 2019
    Please, take out the PIN?
    • psa_bosch_edc17c60_bench_fullbackup_41480909d3e3261e100c002011000000_20211021115930_int_eeprom.bin (256 KB) You must be logged in to download this attachment.
    krzydan
    Help: 19
    Rate: 24
    I can help you with the VIN pin, write to priv
    melas
    Help: 138
    Rate: 689
    You have no longer be like this: SNMZ. If it doesn't match the order of the letters, I hope you know what to do.
  • #8 19673755
    matik185
    Help: 13
    Rate: 75
    Thank you molasses, but I can read it from the ECU, I didn't write anything here for lack of time ..
    Of course the PIN is correct :)
  • #9 19673758
    matik185
    Help: 13
    Rate: 75
    Added after 46 [seconds]:
    PIN read from ECU
The discussion revolves around extracting the PIN from a 2019 Citroen Jumpy's BSI (Body Control Module) without having the import keys. The user initially inquires about methods to retrieve the PIN using the Autel IM508, which is unable to access the BSI without keys. Responses suggest alternative approaches, including reading the EEPROM from the ECU (EDC17C60) using KTAG, as well as the possibility of obtaining the PIN through service options or specific tools like SMOK. The user later confirms successful retrieval of the PIN from the ECU.
